MikeMeyerhoff Posted August 4, 2013 Report Share Posted August 4, 2013 Like the title says: Where is everybody mounting thier ecus? Link to comment Share on other sites More sharing options...
19cturbo Posted August 4, 2013 Report Share Posted August 4, 2013 i had mine in the glove box Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 4, 2013 Author Report Share Posted August 4, 2013 How often do you need to get to the unit itself? Not just the serial connection? Link to comment Share on other sites More sharing options...
psu_Crash Posted August 4, 2013 Report Share Posted August 4, 2013 (edited) Mine is also all tidy in the glovebox as well as all associated fuses and a terminal block. Since I use bluetooth to connect I never need to get to it anymore. But for any issues or upgrades it's a plug, vac line and 4 bolts to remove it. I see a lot of guys mount in the stock ecu location but I wanted easier accessibility. Edited August 4, 2013 by psu_Crash Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 4, 2013 Author Report Share Posted August 4, 2013 I don't know if I can remove the stock ecu just yet. It does fit in the glove box pretty well. The usb adaptor I have is a 4" monster that sticks out of the serial port, but even that still fits. It looks like there is a spot it would fit under the passenger seat, too. I've also got some plx modules I need to bring into the cabin somehere close to the ECU. Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted August 4, 2013 Report Share Posted August 4, 2013 I have my megasquirt mounted in the stock ECU location as I am using the relay board which is mounted in the glove box. Link to comment Share on other sites More sharing options...
TopDawg_43 Posted August 7, 2013 Report Share Posted August 7, 2013 I run a Haltech E6k. Mine is tucked into a crack, right beside the steering colum. If I remember correctly, its kinda wedged in there, and the bottom cover on the dash keeps it from moving or falling out. I put the hole on that side as well, as I didn't want ot run the wires on the exhaust side. I has a serial port that hangs out at the bottom of the cover, whenever I need it. Link to comment Share on other sites More sharing options...
scott87star Posted August 7, 2013 Report Share Posted August 7, 2013 I moved mine to under the passenger seat. Link to comment Share on other sites More sharing options...
NikoFab Posted August 9, 2013 Report Share Posted August 9, 2013 I moved mine to under the passenger seat. Will that work with the setup you made me Scott? Link to comment Share on other sites More sharing options...
Funky Phil Posted August 9, 2013 Report Share Posted August 9, 2013 Stock ECU location. Easy cable access aswell as clear view of LED. Link to comment Share on other sites More sharing options...
Doctor_Drift Posted August 9, 2013 Report Share Posted August 9, 2013 Stock location for me as well. I just have not put the cover back in yet but i made a slim serial cable with a 90 deg plug on it. The cable will stay under passenger seat for now. Link to comment Share on other sites More sharing options...
tux Posted August 9, 2013 Report Share Posted August 9, 2013 stock location as well. Link to comment Share on other sites More sharing options...
ucw458 Posted September 4, 2013 Report Share Posted September 4, 2013 AEMs EMS-4 is small and fits perfect in the stock location. It even has an USB bulkhead so I mounted the USB port in the kick panel. http://i463.photobucket.com/albums/qq352/ucw458/MPI/DSC03834.jpg http://i463.photobucket.com/albums/qq352/ucw458/MPI/DSC03835.jpg Link to comment Share on other sites More sharing options...
importwarrior Posted September 5, 2013 Report Share Posted September 5, 2013 (edited) mounted it on the back of the glove box http://i139.photobucket.com/albums/q299/I-W/M%20P%20I%20project/MPI-5.jpg http://i139.photobucket.com/albums/q299/I-W/M%20P%20I%20project/M-P-I-06-1.jpg Edited September 5, 2013 by importwarrior Link to comment Share on other sites More sharing options...
Funky Phil Posted September 5, 2013 Report Share Posted September 5, 2013 ucw, I gotta give props man. Your work always looks well thought out resulting in a clean install. Link to comment Share on other sites More sharing options...
ucw458 Posted September 5, 2013 Report Share Posted September 5, 2013 ucw, I gotta give props man. Your work always looks well thought out resulting in a clean install. Thanks dude. Your engine bay looks pretty good too. Link to comment Share on other sites More sharing options...
ZacMan Posted September 5, 2013 Report Share Posted September 5, 2013 Don't want to spam too hard, as these are already in my build thread... But I did this for the ECU: (the trim mounting tabs still need to be added) http://i750.photobucket.com/albums/xx141/ProZac83/P8290003_zpse50ce283.jpg With this for the Ignition, ECU, and Fan relays, and the fuses: http://i750.photobucket.com/albums/xx141/ProZac83/Starion%20Project/P8280007_zpsbf6d5b1c.jpg http://i750.photobucket.com/albums/xx141/ProZac83/Starion%20Project/P8280002_zps632bb664.jpg My car is ofcourse RHD, but the idea should be pretty 'flippable'. The EVO V ecu shouldnt need to be touched once it's installed, as you can access everything through the mitsy debug, and the ODBII connectors, which will get put under the glovebox. Link to comment Share on other sites More sharing options...
BORIQUEST87TSI Posted September 22, 2013 Report Share Posted September 22, 2013 running haltech F-9 on stock ecu location... Link to comment Share on other sites More sharing options...
aconro Posted September 22, 2013 Report Share Posted September 22, 2013 I was able to mount my ecu and ignition behind the glove box, but i took my a/c condenser out. Its a tight fit but still gave me all my glove box space. getting to it is just a matter of flipping the glove box down. Im running the stock 1jz ecu Link to comment Share on other sites More sharing options...
substock Posted September 28, 2013 Report Share Posted September 28, 2013 I have been meaning to put these up for a few weeks now, just kept forgetting to. Scott modified an FIP ecu I had so I mount it and the relays in the stock locations. Also my cigarette lighter just stopped working (have a new one just need to install it), so for the current time so that I can use my laptop I mounted a constant +12v in the glove box http://i97.photobucket.com/albums/l225/substock/Conquest/0928131050_zpsb9a9b3fa.jpghttp://i97.photobucket.com/albums/l225/substock/Conquest/0928131048_zps9580d37a.jpg Link to comment Share on other sites More sharing options...
ESIrType? Posted September 28, 2013 Report Share Posted September 28, 2013 I mounted mine above the glove box where there's a cross member. I think I will be moving it to the stock location since I am connecting through bluetooth now. Shawn Link to comment Share on other sites More sharing options...
