psu_Crash
    59
psu_Crash last won the day on May 14
psu_Crash had the most liked content!
About psu_Crash
  • Birthday 08/05/1980
  • Interests
    400+ WHP 450+ WTQ!!
    Decatur TN
  • ICQ
    8311157
  • Website URL
    http://
  • AIM
    Reganator80
    37322
    ESI-R
    1986
  • Factory Color
    Sarajevo White
    Dark Red
    Restoring
33197 profile views
psu_Crash's Achievements
Grand Master
Grand Master (14/14)
  • Very Popular Rare
  • Dedicated Rare
  • Conversation Starter Rare
  • Reacting Well Rare
  • First Post Rare
Recent Badges
110
  1. Looks like they are available O'Reilly. https://www.oreillyauto.com/shop/b/brakes/brake-drums---rotors/brake-rotors/d133f11235f8/v/a/7062/automotive-car-1987-mitsubishi-starion?q=brake+rotors
  2. I have used nothing but Redline MT90 in the trans. This thread talks about the rear end oil. I can't remember what I used there. https://www.starquestclub.com/forum/index.php?/forums/topic/135294-recommended-rear-end-gear-oil/
  3. Rebuild may be the best bet. If it is just the damaged cable, then that is a relatively easy fix.
  4. I knew someone would know! Thanks for the info Steve
  5. I remember someone here doing that a long time ago. Maybe a search would show something.
  6. I agree. It looks like a quality job on the swap. I bet it's a blast to drive!
  7. Ok, who is it? I'm sure we know this guy https://bringatrailer.com/listing/1987-mitsubishi-starion-9/
  8. Welcome! 10AWG is way to small. Especially with the 14AWG link. 10 is good for 30 amps. 14 is only rated for 15 amps. While charging you will see well over 50A up to 75A depending on the year alternator and condition, as well as the battery condition. #4 copper or 2 AWG aluminum is what you need for that load. Sounds a lot like a bad ground somewhere. If you take a meter to the + side of the relay when it should be energized and the other meter lead straight to the battery, does it read 12V? If so, it's definitely a ground issue. A lot of items are a switched ground setup. Meaning the 12V side is hot when the car is on and the ground switching is what turns on the relay. There should be a heavy ground from the block to the battery. I would check that first. Start taking resistance readings from the - battery terminal to different ground points and see what you get. Should be low resistance. Ideally single digits.
  9. Just 3rd gear? I would suspect other items are also needed. I would just swap the entire transmission. It's been a few years since I needed one, but they were always around. Maybe a localish member with a spare can hook you up.
  10. I deleted my rear wiper long ago, so no need for me. I see you are in Chattanooga though. I work in Cleveland, so hello neighbor!
  11. I don't have any narrow body parts, unfortunately. Car is looking good though! That paint will be a different animal once you cut and buff. I'm in the middle of doing just that to mine, also with fresh paint. I'll look forward to updates 🙂
  12. I saw that too. Pretty cool. Someone has way more ambition than I do!
  13. Glad to hear all is well! Looking forward to your updates
  14. Sold for $13,850. I really thought it would go closer to 20k.
  15. I have also been watching this. Especially since I have an 87 Valencia in the garage 😄
