42
tux last won the day on February 14
tux had the most liked content!
new jersey
6646451
AIM
tuxmask2k
08753
tux's Achievements
Ultimately, it will be up to you what you decide and what you choice should be inline with your goal
Just make sure to route after maf and before turbo
I picked up some of Jan’s stuff. i wanted to send him my jdm louvers to have them cast but i don’t trust shippers enough for something i will never find again and if i do they wouldn’t be new in box
I’m running a vintage hks bpv. The air recirculates after maf but before the turbo inlet. Here’s an example of a bov that can recirculate https://tialsport-outlet.com/products/tialsport-qr-series-recirculating-blow-off-valve-1-1
So, with a MAF setup the classic knowledge is you have all this metered air, that is now gone. The ECU doesn’t know that air is gone so you’ll end running rich, throwing off your AFR’s. I run a BPV on my stock setup. Note there’s many BOV’s that can be plumbed to recirculate essentially activing as a bypass valve, if you use a bov as recirculating or use a bpv, you should just plumb that air back in after the MAF. My take is that this doesn’t matter that much for fueling, but the work was already performed to compress that air, so if you care about spool, put the air back. Rally cars recirculate to help keep the spool going.
Perfect thank you! my heater hose barbs are mangled so I may be forced to come up with a a way to have bulkhead 90 elbows anyway
oh @techboyi see on DSMtuners you have a 99 dsm is the cam sensor on the 99 slimmer than a 1g CAS?
The kiggly is for the crank, the Kia one bolts to wher me the 1g dsm CAS goes but it’s super thin. I spoke with a buddy who was a Kia tech and he said there was an exciter ring but he doesn’t remember if it was pressed onto the cam or if it was bolted on. he checked with the parts guy and they could not find any info. shame there’s no pick a parts anywhere near where I could check. i think I could just block off the sensor location and use wasted spark. But ya know… if you do something do it right
Yes, I’m planning to do the kiggly crank trigger and figure out a solution for cam home. That’s why I’m looking for options like that Kia sensor (uses a g4cp engine based on 4g6x). It’s super slim, but I’m not sure how it’s triggered. I found the FSM for he kia, and it completely ignores that sensor And I hear you. I wish i didn’t already start down this road. 4g6x parts are harder than I thought would be to come by and more expensive than i thought, given how popular this darn engine was. For my 4g54, i went with a modified distributor shafted mated to an AEM EPM, which allowed me to do sequential.
Ya I’m wondering about solutions that don’t involve a custom drive shaft. i think a 2gb cas may work or some other solution. im going to be cutting off the throttle body flange to clear the booster
I found this Kia sensor from their DOHC Sirius variant, I wonder if it can work for the cam phase. I'm not sure if it requires a trigger wheel of some kind though or if it reads a magnet embedded in their cam.
I’m putting together a 4G64/4G63 hybrid for a RWD Starion swap and have a few CAS / trigger questions that I haven’t been able to find a clear, first-hand answer to. Setup: • Wide-block 4G64 (Asia-sourced short block) • 1G 4G63 DOHC head (bare head) • RWD application (Starion chassis) • Bosch DBW Throttlebody • Honda K-Series smart coils • MaxxECU Race ECU • Still sourcing cams, lifters, cam pulleys, timing components, rockers, pistons, rods, etc From what I’ve read, the 1G CAS on the back of the intake cam may interfere with the firewall in a Starion. Some posts say it will hit unless the engine is moved forward and a custom driveshaft is made, while others say it does clear but is very tight. Questions: 1 Has anyone here run a 1G CAS on a DOHC head in a Starion without moving the engine forward? If so, how tight is the clearance in practice? 2 Are there alternative cam/crank trigger setups that work cleanly with a 1G head in a RWD chassis? 3 I understand the 2G CAS won’t work on a 1G head — but can a 2G crank trigger/sensor be adapted to a wide-block 4G64 for engine position, with a different cam signal? 4 What are people actually running for crank + cam phase on this combo when firewall clearance is a concern? I’m open to OEM DSM / Hyundai / Kia solutions or aftermarket trigger setups, just trying to understand the real-world options before committing to engine placement. Pictures are greatly appreciated. Thanks — any firsthand experience is appreciated
Occasionally you see one in Seinfeld parked on the street
Oh man that’s a pipe dream
