Megasquirt/FIP/other standalones, harnesses
94 replies to this topic
#41 StarquestRescue
StarquestRescue
  • 4,628 posts
Posted 05 April 2015 - 07:21 PM
Scott, have you run the gps modual from efi.  https://www.efianaly...l?id=tshelp   Can I use it with ms2?
#42 scott87star
scott87star
  • 5,095 posts
Posted 06 April 2015 - 09:33 AM
I have not used it, thought of picking one up to try but haven't yet.  You can use it with any MS or other aftermarket as it communicates directly to your laptop or other device, then you just import the data into megalogviewer along with the appropriate datalog.
#43 psu_Crash
psu_Crash
  • 7,369 posts
Posted 06 April 2015 - 08:42 PM
MS Droid allows you to log GPS data along with your datalogs using the GPS already in your device, a tablet in my case. It's pretty cool. As the log progresses so does the dot on your map.
Here is an example of that it looks like
The Valencia Project
My Feedback Link
#44 ZPI28
ZPI28
  • 5,699 posts
  • Interests:Im just interested
Posted 31 May 2015 - 04:02 PM
Thats pretty sweet PSU
#45 TheDemon
TheDemon
  • 352 posts
  • Interests:Cars, Wrenching, Gaming, cars
Posted 04 June 2015 - 03:21 AM
Id be interested in a system for a 4G6x swapped SQ soon as i get my hands on the car. I like the idea of a clean new plug and play electrical system for the car.
- The Demon
89 Black Conquest TSI SHP 5-speed - Restoration
00 ford ranger trailhead
97 Red Talon ESi - RIP
#46 scott87star
scott87star
  • 5,095 posts
Posted 05 June 2015 - 08:45 AM
The plug and play systems are designed to plug into the factory wiring harness, it sounds like you want a new harness.  I have solutions there as well.
#47 D-VO
D-VO
  • 436 posts
Posted 05 June 2015 - 05:48 PM
What a thread this is... scott you are an artist man.
I'll be running a mostly stock setup for a while, but a small project I am interested in doing is adding an arduino controller to the car to add some I/O for auxiliary sensors / warning lights, and possibly even parking sensors (no airdam scrapes).
You ever work with any of that?
#48 scott87star
scott87star
  • 5,095 posts
Posted 06 June 2015 - 11:00 AM
No specifically an arduino but a controller is a controller, I've been doing chemical process control for 30 years now.  It's all the same under the hood.
#49 ZPI28
ZPI28
  • 5,699 posts
Posted 12 July 2015 - 02:03 AM
Scott I just purchased a Magna MPI and will be looking at engine controllers. Will the MS3 mounted in a stock case with a new engine harness for MPI be something you could do? You can PM with info if you like. Thanks
Steven
#50 scott87star
scott87star
  • 5,095 posts
Posted 12 July 2015 - 10:14 AM
Done it several times so yes, I can do that.  Tell me more about what part of the harness you want new as putting the new ECU in a stock case is really intended to utilize the factory wiring.  The only difference between TBI and MPI to the wiring it two more injector clips.  Unless you go full sequential injection like my MPI car and I have factory wiring solutions for that too.
#51 ZPI28
ZPI28
  • 5,699 posts
Posted 14 July 2015 - 02:57 AM
Scott I dont mind pulling a new harness to the engine. How do you like that full sequential setup? Im thinking that it would idle great and have very nice throttle response.
#52 scott87star
scott87star
  • 5,095 posts
Posted 23 July 2015 - 02:25 PM
It idles great and has very nice throttle response.  Seriously, you can tell side by side which car is sequential, much smoother.
#53 scott87star
scott87star
  • 5,095 posts
Posted 20 October 2015 - 11:25 AM
Just another example of an FIP box doing things never envisioned by Ed or Scott at FIP (I am NOT Scott from FIP if anyone is confused).  This box started life as an Ignition Pro box, I had formerly converted it to be an FC-1S running ignition control for a Starquest client.  He was running into ignition issues with EDIS and wanted to keep the crank trigger so this box was further converted to accept a VR input from the 36-1 crank trigger wheel as well as run wasted spark COP or CNP (as yet not determined) including launch control.  The four coil outputs are logic level and can run smart coils directly such as the LS2 coils or the Mercury Marine uber high output coils OR with the addition of a coil driver pack can run the two wire COP systems that I offer.
I am currently working on a mounting system for the Mercury Marine CNP coils, more to come on that in my COP thread.
#54 importwarrior
  • 18,390 posts
Posted 20 October 2015 - 12:05 PM
WoW you are awesome!
like to know the difference of the marine vs others as far as output? cost a lot more?
#55 scott87star
scott87star
  • 5,095 posts
Posted 20 October 2015 - 12:31 PM
DIYAutotune sells the coils, being a distributor I can sell them at their list price and save someone shipping fees.  I'm going to be offering a mounting system where these will sit above the plugs on top of the VC, they are much bigger than the COP systems I sell so it gets crowded but so far it looks like there is enough room.
What got my attention was DIY had them tested independently with a host of other coil options including the LS2 truck coils and a Pro Mag 44 amp coil and the only coil to outperform them was the Pro Mag.  The Pro Mag lists at $739 each at Jegs where the Mercury Marine coils are $67 each.  They are a smart coil with a built in 19 amp ignitor circuit and three (3)! grounds (trigger, block and battery).  Spark blowout will no longer be an issue.
Coil specs:
Minimum voltage output (no load, at recommended dwell): 40,000 volts
Output energy: 103 mJ
Spark duration: 2.9 ms
Primary resistance: 0.5 ohms (not directly measurable)
Primary inductance: 4.8 mH (not directly measurable)
Secondary resistance: 8,500 ohms
Secondary inductance: 22.5 H
Turns ratio: 71.1
Maximum current: 19 amps
Maximum battery voltage: 17 volts
Nominal dwell: 3.0 ms
Edited by scott87star, 20 October 2015 - 12:37 PM.
#56 importwarrior
  • 18,390 posts
Posted 20 October 2015 - 06:48 PM
Great info thanks.
#57 jimalan1989
jimalan1989
  • 89 posts
Posted 22 November 2015 - 07:23 PM
dumb questions here but  does the megasquirt work with the stock ISC.  I'm trying to delete the maf and use a map. I also want something expandable for when I'm ready to go mpi. I would like to be able to run the stock tbi for a while and just have a lil more adjustability. Also is there any other special things that I need to do or change if I was to run a megasquirt
#58 importwarrior
  • 18,390 posts
Posted 22 November 2015 - 07:38 PM
Depends if you want to manage fuel only or go fuel and spark.
Fuel only probably real easy to do.
Megasquirt can be changes to run anything from 1 to 12 cylinders. 2 or 4 stroke.
#59 scott87star
scott87star
  • 5,095 posts
Posted 22 November 2015 - 09:01 PM
No aftermarket ECU will run the stock ISC, it's an odd beast that reverses polarity.  You can run a PWM or stepper idle valve with some custom plumbing.  As far as "anything else". It depends upon what you want to accomplish with ignition and other features like rev limiters, launch control and such.  And yes you can run TBI.now and easily move to MPI later.
#60 jimalan1989
jimalan1989
  • 89 posts
Posted 22 November 2015 - 10:45 PM
thanks for the info. ill have to look around and see how others have gone about adapting something to use other then the ISC
Edited by jimalan1989, 22 November 2015 - 10:46 PM.
