scott87star Posted October 28, 2014 Author Report Share Posted October 28, 2014 Correct Bill. Link to comment Share on other sites More sharing options...
scott87star Posted November 2, 2014 Author Report Share Posted November 2, 2014 The current state of the art, MS3 pro module in a Starquest case: http://picturehosting.com/images/oblique9881/ms3proinstarquestcase.jpg Real time clock.8 Gig datalog SDcard.Accepts the Starquest Knock sensor. Yes, it does. Stock.Way too cool. So, there are 10 extra wires in a stock Starquest ECU for inputs/outputs, you can run fully sequential ignition and injection on a MPI conversion along with an idle valve, electronic boost control, flex fuel without replacing your harness........ what are you waiting for? The absolute BEST value in aftermarket ECU's anywhere. Fully installed and tuned its less than half the price of ANY off the shelf aftermarket units (that need to be installed and tuned). Link to comment Share on other sites More sharing options...
TexasQuest Posted November 2, 2014 Report Share Posted November 2, 2014 That is amazing Scott! Truly a work of art. Link to comment Share on other sites More sharing options...
importwarrior Posted November 2, 2014 Report Share Posted November 2, 2014 amazing!!!! The only problem is my stock harness is horrible. some brittle or cracking wires. Link to comment Share on other sites More sharing options...
scott87star Posted November 2, 2014 Author Report Share Posted November 2, 2014 There are solutions, pulling a new harness IS the way to go in many instances. Tim's car at TSQ2014 for instance had a short in the harness between the main relay and the fuel injector resistor pack. Really? (I said to myself in amazement after Jeff and BOHO figured it out). The SD data logging is pretty neat in the MS3, you can set it to automatically log on a software trigger, like boost level or rpm. That way you don't need to be connected and every time you go above your preset it logs, say 10 psi boost. With 8 Gig you can drive for years and if you need to review what its doing routinely above 10 psi you've got a lot of logs to look at. Link to comment Share on other sites More sharing options...
importwarrior Posted November 2, 2014 Report Share Posted November 2, 2014 Great stuff Scott!!! Link to comment Share on other sites More sharing options...
Turbo Cary Posted November 2, 2014 Report Share Posted November 2, 2014 Scott I have one or two bad ecu's that don't work. Would you want them for the cases and female connectors? I don't want any money for em and its better than throwing them out Link to comment Share on other sites More sharing options...
scott87star Posted November 2, 2014 Author Report Share Posted November 2, 2014 PM'ed you. Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted December 19, 2014 Report Share Posted December 19, 2014 as usual Scott is THE MAN ! I see that set up in the stock case for the 85.5 in my future , THE FUTURE ! ( inside joke ) i want to stay as stock looking as possible but some upgrades are just mandatory, especially when stock parts flake out Link to comment Share on other sites More sharing options...
RonnieJ Posted February 24, 2015 Report Share Posted February 24, 2015 Going to pm you in a bit. Want to get the ball rolling on my MPI Link to comment Share on other sites More sharing options...
Funky Phil Posted February 24, 2015 Report Share Posted February 24, 2015 Didnt know you needed cases Scott. I have some for you. Link to comment Share on other sites More sharing options...
RonnieJ Posted February 24, 2015 Report Share Posted February 24, 2015 I think I have 4-5 OEM ECUs in a box if you need them too Link to comment Share on other sites More sharing options...
scott87star Posted February 27, 2015 Author Report Share Posted February 27, 2015 I think I'm OK on cases for the moment, its supposed to be a core exchange thing and not everyone is good about returning stuff but some guys return all kinds of stuff. I was short on dizzy's but SOTTY helped me out. But I and I'm sure the community thank you for your offer. Link to comment Share on other sites More sharing options...
GINASQ Posted April 3, 2015 Report Share Posted April 3, 2015 So, can you build me a MS for a k-jet CIS system? It'll be for my 1988 Mercedes 560SEC. Link to comment Share on other sites More sharing options...
scott87star Posted April 3, 2015 Author Report Share Posted April 3, 2015 Sure, PM me with details. Link to comment Share on other sites More sharing options...
StarquestRescue Posted April 6, 2015 Report Share Posted April 6, 2015 Scott, have you run the gps modual from efi. https://www.efianalytics.com/products/BT-Q818XT.html?id=tshelp Can I use it with ms2? Link to comment Share on other sites More sharing options...
scott87star Posted April 6, 2015 Author Report Share Posted April 6, 2015 I have not used it, thought of picking one up to try but haven't yet. You can use it with any MS or other aftermarket as it communicates directly to your laptop or other device, then you just import the data into megalogviewer along with the appropriate datalog. Link to comment Share on other sites More sharing options...
psu_Crash Posted April 7, 2015 Report Share Posted April 7, 2015 MS Droid allows you to log GPS data along with your datalogs using the GPS already in your device, a tablet in my case. It's pretty cool. As the log progresses so does the dot on your map.Here is an example of that it looks likehttp://www.msdroid.com/img/screenshot/log_and_route_2.png Link to comment Share on other sites More sharing options...
ZPI28 Posted May 31, 2015 Report Share Posted May 31, 2015 Thats pretty sweet PSU Link to comment Share on other sites More sharing options...
TheDemon Posted June 4, 2015 Report Share Posted June 4, 2015 Id be interested in a system for a 4G6x swapped SQ soon as i get my hands on the car. I like the idea of a clean new plug and play electrical system for the car. Link to comment Share on other sites More sharing options...
scott87star Posted June 5, 2015 Author Report Share Posted June 5, 2015 The plug and play systems are designed to plug into the factory wiring harness, it sounds like you want a new harness. I have solutions there as well. Link to comment Share on other sites More sharing options...
D-VO Posted June 5, 2015 Report Share Posted June 5, 2015 What a thread this is... scott you are an artist man. I'll be running a mostly stock setup for a while, but a small project I am interested in doing is adding an arduino controller to the car to add some I/O for auxiliary sensors / warning lights, and possibly even parking sensors (no airdam scrapes). You ever work with any of that? Link to comment Share on other sites More sharing options...
scott87star Posted June 6, 2015 Author Report Share Posted June 6, 2015 No specifically an arduino but a controller is a controller, I've been doing chemical process control for 30 years now. It's all the same under the hood. Link to comment Share on other sites More sharing options...
ZPI28 Posted July 12, 2015 Report Share Posted July 12, 2015 Scott I just purchased a Magna MPI and will be looking at engine controllers. Will the MS3 mounted in a stock case with a new engine harness for MPI be something you could do? You can PM with info if you like. Thanks Steven Link to comment Share on other sites More sharing options...
scott87star Posted July 12, 2015 Author Report Share Posted July 12, 2015 Done it several times so yes, I can do that. Tell me more about what part of the harness you want new as putting the new ECU in a stock case is really intended to utilize the factory wiring. The only difference between TBI and MPI to the wiring it two more injector clips. Unless you go full sequential injection like my MPI car and I have factory wiring solutions for that too. Link to comment Share on other sites More sharing options...
