ucw458 Posted February 7, 2012 Report Share Posted February 7, 2012 (edited) Other than 4g63 or 4g64 what other mitsubishi engines would make a cool swap? I thought about a 6g72 but I just changed the water pump on one and I hated every minute of it. I'm thinking about doing another SQ but an engine swap this time. No point in doing 2 mpi builds. Edited February 7, 2012 by ucw458 Link to comment Share on other sites More sharing options...
akauf Posted February 7, 2012 Report Share Posted February 7, 2012 4b11t, you can look for the mitsu v8, the 8A8, or there are 2 diesels in the sirius family, the 4d65 and 4d68. Link to comment Share on other sites More sharing options...
MainstreaM Posted February 7, 2012 Report Share Posted February 7, 2012 The 4D55 and 4D56 will bolt up to the Starion trans. Link to comment Share on other sites More sharing options...
ucw458 Posted February 7, 2012 Author Report Share Posted February 7, 2012 Maybe I should add, no diesels, no modern engines requiring extensive computer control (variable cams etc), and nothing that will cost a small fortune to build. Link to comment Share on other sites More sharing options...
MainstreaM Posted February 7, 2012 Report Share Posted February 7, 2012 SOL Link to comment Share on other sites More sharing options...
akauf Posted February 7, 2012 Report Share Posted February 7, 2012 yeah, nothing, lol Link to comment Share on other sites More sharing options...
Turborusty Posted February 7, 2012 Report Share Posted February 7, 2012 Ford Flathead V8 meets your requirements. Turborusty Link to comment Share on other sites More sharing options...
akauf Posted February 7, 2012 Report Share Posted February 7, 2012 mitsu motor is a requirment Link to comment Share on other sites More sharing options...
ucw458 Posted February 7, 2012 Author Report Share Posted February 7, 2012 Well I don't like diesels. Diesel fumes makes me sick. I just don't want a motor that requires the stock ecu to work properly. Something that can be run on any standalone would be fine. I also don't want to have to spend 10-20k to do the swap. I had thought about a 1UZ but it's not a mitsu motor. Is the block on that motor aluminum too? Link to comment Share on other sites More sharing options...
TainterRacing Posted February 7, 2012 Report Share Posted February 7, 2012 (edited) Other than 4g63 or 4g64 what other mitsubishi engines would make a cool swap? I thought about a 6g72 but I just changed the water pump on one and I hated every minute of it. I'm thinking about doing another SQ but an engine swap this time. No point in doing 2 mpi builds. You know there is a 6g72 rear wheel drive not that ez to find tho .... 6g74 3.5L (200HP) and you could allso do 6g75 3.8L (268HP) Both N/a but would be great with a turbo. 6g74 would be the ez I think of all as they come rear wheel drive. opps no modern engines requiring extensive computer control (variable cams etc) I guess scrap the 6g75... I think you want to do the 6g74. If you have a 6g72 most of the good parts will bolt right on it. Edited February 7, 2012 by TainterRacing Link to comment Share on other sites More sharing options...
wrngwae Posted February 7, 2012 Report Share Posted February 7, 2012 pffft,,,,,, diesel swaps are easy...... no ecu required. all you have to do is power one wire to the mechanical pump and it runs. 4d56 ftw.... i thought about it.... but if you think parts for our cars are hard to find and not very cheep......... try the mitsu wideblock diesels..... back when i built mine, i had to get pistons from Australia.... for $1000 a set of 4. now there on flea bay... and of coure the old mitsu head cracking issues to boot.... so it should feel right at home. hahaha... good luck Jeff! Link to comment Share on other sites More sharing options...
TexasQuest Posted February 7, 2012 Report Share Posted February 7, 2012 There is an inline 6 mitsu built back in the 80's for their v.i.p. cars in japan but it's hard to find I'm sure. Link to comment Share on other sites More sharing options...
Guest Posted February 7, 2012 Report Share Posted February 7, 2012 Well I don't like diesels. Diesel fumes makes me sick. I just don't want a motor that requires the stock ecu to work properly. Something that can be run on any standalone would be fine. I also don't want to have to spend 10-20k to do the swap. I had thought about a 1UZ but it's not a mitsu motor. Is the block on that motor aluminum too?That would be fun to play with and believe it or not, those are relatively cheap engines to come by. But in the Mitsu family, only swap I would bother with is the 4g63/ 64 combo. There is tins of aftermarket for the 4g63s and not to mention they have been proven over and over to make reliable horse power and tons of torque. Link to comment Share on other sites More sharing options...
dmyers151 Posted February 7, 2012 Report Share Posted February 7, 2012 WWII radial aircraft engine... 1 Link to comment Share on other sites More sharing options...
Komeuppance Posted February 7, 2012 Report Share Posted February 7, 2012 The mitsu inline 6 was a 60's engine. Just put a carb on it Jeff, screw dem fancy new fangled wirezz!! -Robert Link to comment Share on other sites More sharing options...
Indiana Posted February 7, 2012 Report Share Posted February 7, 2012 (edited) Use the Mazda G6 engine. Its a slightly larger 2.6 than ours its in trucks but also vans. There is a non 4x4 5sp its just harder to locate if you don't want to use one of the Rx7 gearboxes or an automatic. Its already mpi, it has balance shafts and it has oil squirters in n/a form. The oil pump is in the timing cover its not chain drive. It also uses the same clutch. Edited February 7, 2012 by Indiana Link to comment Share on other sites More sharing options...
Convette Posted February 7, 2012 Report Share Posted February 7, 2012 why go through the effort to gain like 50hp and be about as reliable? Just put a rx8 drivetrain in it. With duct tape. 1 Link to comment Share on other sites More sharing options...
dmyers151 Posted February 7, 2012 Report Share Posted February 7, 2012 ... JB weld & contact cement... Link to comment Share on other sites More sharing options...
Guest Posted February 8, 2012 Report Share Posted February 8, 2012 The mitsu inline 6 was a 60's engine. Just put a carb on it Jeff, screw dem fancy new fangled wirezz!! -Robert Don't give him any ideas, hes really fond of carbs! Link to comment Share on other sites More sharing options...
Komeuppance Posted February 8, 2012 Report Share Posted February 8, 2012 Forget the block, and go all carbs. No pistons, crank, anything... just carbs. -Robert Link to comment Share on other sites More sharing options...
ucw458 Posted February 8, 2012 Author Report Share Posted February 8, 2012 Forget the block, and go all carbs. No pistons, crank, anything... just carbs. -Robert That makes for a very interesting mental picture. Arainged neatly or random? Link to comment Share on other sites More sharing options...
Komeuppance Posted February 8, 2012 Report Share Posted February 8, 2012 Neatly would be the most efficient. -Robert Link to comment Share on other sites More sharing options...
turbojew Posted February 9, 2012 Report Share Posted February 9, 2012 (edited) Mitsubishi has very limited engine options. You have the 4g63/64, 6g series and the 8 cylinder. Beyond that theres a few diesels and thats IT. If you wanna swap be unique go saab. You can get an upgraded ecu from them. I worked for them and one of the mechanics had a old 9-3 maybe a 900 convertible that stomped a new porsche cheyenne turbo. He told me it cost 2k to make his car that fast. and very easy. Edited February 9, 2012 by turbojew Link to comment Share on other sites More sharing options...
akauf Posted February 9, 2012 Report Share Posted February 9, 2012 WWII radial aircraft engine... +1 Nakajima Sakae 12 radial engine, 709 kW (950 hp)this engine powered the zero to a 12-1 kill ratio in dog fighting in a car I'd expect those results to double. You'd take down 96% of everything else on the roadhttp://upload.wikimedia.org/wikipedia/commons/thumb/a/a9/Nakajima_Sakae.jpg/300px-Nakajima_Sakae.jpg It may require a small cowl Link to comment Share on other sites More sharing options...
R-R-Quest Posted February 9, 2012 Report Share Posted February 9, 2012 ^^^^^ Take out 50% with the Prop alone! ^^^^^ Link to comment Share on other sites More sharing options...
