for all you EDIS freaks that need a Tach
61 replies to this topic
#1 importwarrior
  • 18,362 posts
Posted 13 August 2008 - 05:44 AM
NOTE! Diodes in pic are NOT the proper diodes. the part numbers are listed in the first picture.
PN= 1N4004 - 2 of them
also you need a  15 to 18 volt Zener Diode
Pn= 1N4746A
Diodes Explained:
http://www.evilmadsc...o-zener-diodes/
QUOTE
Hi,
I was wondering how you wired up the stock tach with your EDIS 4 setup?
http://www.megamanual.com/ms2/EDIS.htm
i had to do this. no other way worked. it lists the part numbers you need. simply solder
them together and make sure the bottom 2 do not touch each other. shrink wrap them
or use liquid electrical tape then slide heat shrink ofer them. then shrink them down while
liquid electrical tape is wet. once it dries the heat shrink will not slip around.
another pic:Posted Image
from the above pic i hooked one of the double end side (D-1) to wire 12 (below pic)
and the other (D-2) to wire 10 (below pic) on the EDIS connector. either one can go to either negative coil wire.
the single side (D-3) from top pic goes to cars harness white connector wire shown below.
http://i17.photobuck...ro-cu/CU-47.jpg
to save you the hassel of making one. i know that the 1990 only Eclipse turbo cars had one on them.
you will also have to go to a real good electronic store to get your diodes. radioshack had nothing.
if you can not find them i can get them for you and make them up as well.
Edited by importwarrior, 05 October 2014 - 08:28 AM.
#2 importwarrior
  • 18,362 posts
Posted 13 August 2008 - 05:47 AM
i know the connector is white and goes to a brass colored resistor then comes out black, then goes to NEG on coil. there is no longer a coil. that is where i hooked it up.
Edited by importwarrior, 13 August 2008 - 05:48 AM.
#3 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 13 August 2008 - 06:14 PM
Would it be possible for you to post a pic of the completed diode setup? I'm confused as to how to solder the diodes together. I found a few good sources for diodes on ebay.
#4 importwarrior
  • 18,362 posts
Posted 14 August 2008 - 05:12 AM
ok in pic 1 above, you see the short line right above the triangle near D1. it goes horizontal. also there is a short line right abovethe triangle near D2 also horizontal. that represents the gray stripe on the diods you see in pic 2
D3 zener diode has the line horzontal below the triangle. the gray stripe pointis towards the other 2 diodes in the pic.
basically twist them together solder
so
turn D3 up side down and solder the end circled to the other 2 diodes circled in RED.  all gray stripes should face each other.
in the picture below this is not a Zener Diode. the pic is only to show proper orientation when soldering them together
make sure to heat shrink any exposed leads. that way nothing will arc to ground.
Edited by importwarrior, 22 September 2014 - 05:33 AM.
#5 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 14 August 2008 - 11:40 AM
Awesome explanation IW. I'm going to try to get this going and I'll report my results.
#6 importwarrior
  • 18,362 posts
Posted 14 August 2008 - 12:07 PM
#7 notfried
notfried
    fluffy nuggets of gold power my car
  • 4,066 posts
  • Interests:God, MoParBishi, Cummins, and HD
Posted 14 August 2008 - 02:59 PM
thanks,IW...i vote for FAQ
#8 importwarrior
  • 18,362 posts
Posted 15 August 2008 - 05:01 AM
the first gen 1990 eclipse "ONLY" had one of these on it. if you can find one.
it is just easier and a ton cheaper to build it yhourself.
#9 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 01 September 2008 - 09:54 PM
I just installed the diodes by following the instructions above and the stock tach is working perfectly. This should be made a sticky in the mpi section maybe. Thanks importwarrior for the help.
#10 importwarrior
  • 18,362 posts
Posted 02 September 2008 - 05:35 AM
thanks for the update!
#11 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 02 March 2009 - 01:57 PM
So....Does the Positive side...going to the white wire on the harness.....Does it "tap" into the existing line...? I don't understand this or What the (D-3) is? You got anything for me Importwarrior?
87 Starion 2jz
#12 spoolinturbo
spoolinturbo
  • 3,516 posts
Posted 02 March 2009 - 06:38 PM
i vote sticky in faq
1974 vette stingray
1991 3000gt vr4 (2011 autox season starter)
1991 galant vr4
1988 starion fiji SHP (gone)
2006 colorado 4x4
2010 suburban z71 black CIA replica
2012 silverado z71 black
active duty airforce
#13 jinx
jinx
  • 2,013 posts
Posted 03 March 2009 - 10:28 AM
same question... I think?
do yo retain the stock brass color thing and connect to where the coil negative
terminal used to be.... or connect the free end of diode D3 straight to the stock
white wire/white connector shown above ?
yeah, this sorts stuff should be in the FAQ
side note:
**ALSO** a megasquirt fuel-only
AND a megasquirt mpi with distributor & timing
AND a megasqurt EDIS. CaliConquestAlex comment saying "how EZ it is", stuck in my
I really gotta study his and buttons' threads.
Button documented switching between TBI to MPI... made it seem real ez
I gotta read over those threads .....before they dissappear
#14 travs87tsi
travs87tsi
    learning everyday
  • 1,185 posts
Posted 03 March 2009 - 12:37 PM
to satisfy my curiosity did hooking the pip signal straight to the tach not work?
#15 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 03 March 2009 - 12:55 PM
I re-read this again....So....There is nothing hooked up the the black side of the gold box anymore? The gold box is gone right? I'm pretty sure I understand now. D-3 is the completed neg side for the tach signal....and it goes to the white wire. I gotcha...i think.
87 Starion 2jz
#16 substock
substock
  • 3,993 posts
Posted 03 March 2009 - 02:57 PM
test it with the gold filter still attached, you may or may not need it.
BOHO did you end up getting the megajolt?
'89 Conquest
#17 jinx
jinx
  • 2,013 posts
Posted 04 March 2009 - 09:25 AM
QUOTE (importwarrior @ Aug 13 2008, 10:44 AM) <{POST_SNAPBACK}>
do you know where it is physically located on the 90 DSM ?
I'd think the non turbo 2.0 may have them also as its the same electronics ? ...so
more 1990s to choose from
I'll build the circuit as u kindly posted, but I may actually be able to find a 90 2L DSM quicker than I can get those diodes smile.gif
#18 BOHO
BOHO
    Sucks at life
  • 5,102 posts
Posted 05 March 2009 - 01:21 AM
QUOTE (substock @ Mar 3 2009, 03:57 PM) <{POST_SNAPBACK}>
I picked up a megasquirt II and am just going to ditch the FIP computer all together. Going to swap over on Friday.
87 Starion 2jz
#19 jisleyjr
jisleyjr
  • 1,286 posts
Posted 23 November 2009 - 11:34 AM
I am having trouble identifying the correct wire in my situation. I have a red arrow pointing to the item i think it is.
I soldered up the diodes how i thought they should be and used the red arrow wire. No tach signal.
I am a little confused to what the little symbols mean on each diode, does the way the arrow points mean something. I see white/black lines on one side of the diodes i bought, is that the 'output' side? I am not sure if there is an 'input' and 'output' side to these things.
1988 Conquest, Fiji with blue/grey cloth interior. Magna MPI/MS2/EDIS-4, D2's, td05h/s16g
1987 Starion, Black Ext and Black Leather, parts car :(
1983 Starion, Black Ext and grey cloth interior, driveway queen
2006 Acura TL, Anthracite Ext with Black Leather, rolling on 18's.
#20 SQF
SQF
  • 6,568 posts
Posted 23 November 2009 - 03:19 PM
Diodes are like check valves.  They only let electrons flow in one direction and that is what the band is indicating (and why an LED or light emitting diodes only "lights" when wired correctly).  The two lower diodes in the diagram are regular diodes.  The top Diode is a Zenner which blocks current flow until it hits a certain level and then allows it to flow in the reverse direction.  Think of the bottom two as a traditional door, it only opens one way.  The top diode (being a zenner) is like a door that swings both in and out, however it only swings out when the room reaches its maximum capacity and required it to do so.
Fir Na Dli
I sold my soul to make room for all this sarcasm.
