Everything posted by notfried
Sold. Thank you.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Deposit received, sale pending the balance.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Check local junk yards for a '94 Rodeo LS, or your parts stores/stealerships. It's the exact same sunroof as a factory SQ one.
Bump. May negotiate some.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
ToTheTop, BatDude.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Replied
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Yessir.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
I will. And no, not Mark's hood. Like the head, it's from the first ever GP done by Gary.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
I may split them up. I don't want to just yet, though. I'd rather have it all go to one spot, but ya never know.
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Sound like you should be shopping at the junk yard for an '84 Caravan head. Cheapest way to get a njv head.
the sunroof for a 1994 Rodeo is the exact same.
http://www.starquestclub.com/forum/index.php?showtopic=147054 Close to new/unused
The black one does need this, Harry. Is that my old '87 auto you picked up from Devin years ago?
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Hey all. I have a Spain casting Marnal head with 500 miles on it that I am no longer needing. It is gasket matched ported on the exhaust side, using a flow bench, has 1mm over-sized stainless steel valves, Schneider heavy-duty springs, and was made for a high-lift cam. The cam is a Tim C. Monsta Banshee Roller cam (INT Duration @.050: .207° Seat-To-Seat: 265°, EXH Duration @.050: .196° Seat-To-Seat: 262°, INT Lift: .480 w/1.6 ratio rockers;, EXH Lift:.459, Lobe Center Separation: 111.5°, Degree intake Lobe to 107°, Power Range: 2500-6500RPM), the rockers are 1:6 3000GT rollers, and the gear is a MK1 from Mookeeh. All the intake/exhaust hardware came from Dad, along with lifters and Fel-Pro 9116 head gasket set. This head was bought from the "Marnal GP OG", Richie_Rich, back in the day, sat in a box on a shelf most it's life, and got finally strapped to an engine that the machine shop installed the rings upside down in. Hence the 500 miles and the soot in the chambers. I included a pic of the soot because underneath it it is perfectly clean, and it falls off easily. I have over $1500 invested in this head/cam set-up and am looking to get $950 shipped and insured (continental US). Here's some pics. Thank you and have a blessed day. http://i85.photobucket.com/albums/k61/notfried/19126_946004952086033_1300947645577761121_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11127877_946004912086037_6125106262711539536_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10420280_946004895419372_7337388523279718732_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081046_946004882086040_5515029591966322676_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081437_946004858752709_9131302519937521197_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11084270_946004835419378_1518888447213133192_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11133708_946004805419381_6383342337114360845_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081361_946004792086049_8695328717371600265_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10502486_946004465419415_5358873570842221190_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11134147_946004538752741_4518085174317736082_n.jpghttp://i85.photobucket.com/albums/k61/notfried/18915_946004768752718_4311894291661751461_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11081498_946025185417343_692370248185311202_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11082594_946025798750615_5697647407571953883_n.jpg
- 16 replies
- Roller Cam
- Cam
(and 3 more)
Tagged with:
Like I said, they need paint. The horns on the bov have a couple small dings on them. I got them all from a fellow member years ago used for a lot more than I'm asking. Here's a few pics http://i85.photobucket.com/albums/k61/notfried/10422920_940443422642186_2584002324660954613_n.jpghttp://i85.photobucket.com/albums/k61/notfried/1797491_940443509308844_7284299027719360915_n.jpghttp://i85.photobucket.com/albums/k61/notfried/11080954_940443575975504_8734066235409301690_n.jpg
Sold. Thank you, drive through.
Hey all, I have the 1st gen steel hard-pipes for the factory intercooler with a Mookeeh ovcp and a knock off RFL bov that I don't need. They need paint, but that is it. The blow off valve holds 28psi with no leaks, all day, every day, can probably do plenty more, is very loud, and is easily adjustable. All clamps (minus two that you can just reuse from your current set-up, unless I can find them before I ship) and couplers included. No cutting or modifying of anything needs to be done to use these except an '86 and down would need a bung added in the ovcp. $175 shipped/insured is the lowest I'll go. I'll get some pics up in a bit. Thanks.
Sold. Thank you, come again.
I don't have the original box, nor instructions. It is hard-wired into the factory harness.
I have an '88/'89 computer in an '87 case in case anyone may be interested. $85 shipped. Thanks
$100 shipped
$300 Shipped
Hello all. I have a maft set-up that I no longer need and figured someone else may want/need it. I have a 1g translator, MK1 ahp with couplers and clamps, GM 3" maf. K&N filter, and LowerShores 650/950 injectors, all for $250 shipped. That's basically half price. Here's some pics and thank you for your time. http://i85.photobucket.com/albums/k61/notfried/11001837_922049394481589_8547687891461887246_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10993404_922048811148314_3977346650138666445_n.jpghttp://i85.photobucket.com/albums/k61/notfried/10994173_922048907814971_8876933626204765876_n.jpg
