pagemo Posted January 2, 2010 Report Share Posted January 2, 2010 I'm also running 75lb injectors. your req fuel should be 5.4 req fuel should be something you set once then never touch again.I agree it should be set and you shouldnt need to change it again, but depending on base line fuel pressure, fuel line size and type of injectors required fuel could be different for similiar set ups. i am running 6.9 required fuel with 750cc injectors and 25psi base pressure. just indreasing your base fuel pressure 5 psi could make a big change in the required fuel. Braden, tech is right get a datalog it will eliminate most of the guess work. getting moisture in the block sounds bad though do pressure test on coolant system.GL Scott Link to comment Share on other sites More sharing options...
BOHO Posted January 3, 2010 Author Report Share Posted January 3, 2010 Guys, I got a laptop that I just knew would work and I couldn't get it to connect either. I bought the usb to serial cable that DIY sells but I don't think that mine is anygood. It doesn't make sense. But.....I made some more changes and I actually drove the car about 50 miles yesterday. :) No fouling plugs...No breaking down No losing tach signal I wish I could datalog but I don't have the money to buy anything else and I definatly don't have the money to put the car on the dyno...But I just wanted you guys to know it was coming along..I guess. I'm going to take some pictures of the car NOT in my driveway just so you believe me...LOL!!! Braden Link to comment Share on other sites More sharing options...
tim si Posted January 3, 2010 Report Share Posted January 3, 2010 glad to hear youe getting some seat time in it. Link to comment Share on other sites More sharing options...
pure_insanity Posted January 3, 2010 Report Share Posted January 3, 2010 why is it that it wont connect ? so you cant even view megatune? Link to comment Share on other sites More sharing options...
BOHO Posted January 3, 2010 Author Report Share Posted January 3, 2010 why is it that it wont connect ? so you cant even view megatune? I don't know grant..?? I've only got this old POS Toshiba that I can get to connect. But I can't do anything else with it...The only problem I have is a itermittent miss at cruise....It doesnt miss at all under accel...I'm going to work on getting a used laptop that has a true Serial port. Link to comment Share on other sites More sharing options...
pure_insanity Posted January 4, 2010 Report Share Posted January 4, 2010 i dunno, that sounds like one to hit up the ms forums about. im not really good with the whole computer/connectivity end of things. you need a better nerd than me for that stuff. jah-jah(kyle) is pretty decent with that stuff. he may be able to help. worth a try. Link to comment Share on other sites More sharing options...
Funky Phil Posted January 4, 2010 Report Share Posted January 4, 2010 How does it rev with no load??Are you running ignition control?Have you verified that your timing advances with rpm increase?Can you post screen shots of your constants/enrichments/VE table/Ign table??Is the lean out momentary or does it continue to lean out uncontrollably with boost?If you took of your hood would you be able to see your FPR gauge from the pass seat?? If so try that. You may have a bad pump or clogged fuel filter.If its an issue with your tune theres really no way to help you til you post up the screen shots. phil Link to comment Share on other sites More sharing options...
jahjah Posted January 4, 2010 Report Share Posted January 4, 2010 Well if you get it drivable enough that you wanna bring it up here... I'll gladly take a look over everything for ya. I'm still jobless, and i punctured a hole in my lower rad hose so i'm not driving anywhere anytime soon. But if i get a job and replace that hose i might be able to find a day to convoy down there and take a look at ur car. Link to comment Share on other sites More sharing options...
BOHO Posted January 4, 2010 Author Report Share Posted January 4, 2010 Kyle, I'll figure out something so I can head up there. Phil, I will take some screen shots with a camera..LOL...I have a mechanical fuel pressure gauge mounted on the cowl so I can see it all the time. Its raising properly. No I cannont control Ignition. Its running just off Distributor and Vac. Advance. Its a fuel only car right now. It Does advance properly now. The car revs great with no load. Not a sputter one. Thanks Braden Link to comment Share on other sites More sharing options...
pure_insanity Posted January 4, 2010 Report Share Posted January 4, 2010 yea, and if you can get it up here, either to my house or kyles, we only live like 15 or so miles apart. so it would be no problem for all of us to get together and jump on your car to figure out whats up. surely between the 3 of us we can send you home in decent shape. Link to comment Share on other sites More sharing options...
jahjah Posted January 4, 2010 Report Share Posted January 4, 2010 yea, and if you can get it up here, either to my house or kyles, we only live like 15 or so miles apart. so it would be no problem for all of us to get together and jump on your car to figure out whats up. surely between the 3 of us we can send you home in decent shape.agreed Link to comment Share on other sites More sharing options...
quikconq Posted January 4, 2010 Report Share Posted January 4, 2010 yea, and if you can get it up here, either to my house or kyles, we only live like 15 or so miles apart. so it would be no problem for all of us to get together and jump on your car to figure out whats up. surely between the 3 of us we can send you home in decent shape. teamwork,,,thats where its atkeep this post goin for the next guys,,,,,including me,some day good luck,sounds like your real close Link to comment Share on other sites More sharing options...
Funky Phil Posted January 5, 2010 Report Share Posted January 5, 2010 How do your plugs actually look though. You need to truly read them.Hows the ring? White/Black/Brown??Porcelin? Peppered/black?Electrode? heat mark at half??What gap?Also, you say your fouling the #1 plug. Have you checked the distributor/rotor/wires?Did you check the block for flatness. I see you said it was clean. phil Link to comment Share on other sites More sharing options...
BOHO Posted January 5, 2010 Author Report Share Posted January 5, 2010 (edited) I took some pics. This is Plugs... 4 3 2 1 ...left to right They are NGK 7's gapped at .038 http://img705.imageshack.us/img705/6479/49894845.jpg settingshttp://img705.imageshack.us/img705/3226/42108411.jpg http://img705.imageshack.us/img705/788/96507059.jpg http://img705.imageshack.us/img705/4747/64356315.jpg http://img705.imageshack.us/img705/4882/71709080.jpg Sorry for the Shotty pictures. Plug wires all ohmed pretty close to the same thing. I'm going to get a new cap just to be safe. Edited January 5, 2010 by BOHO Link to comment Share on other sites More sharing options...
Funky Phil Posted January 5, 2010 Report Share Posted January 5, 2010 Above 80kpa you need to put in some fuel. Should be in the 100's @ 130kpa and up.Req fuel is too high. Im at 6.4 with a 60mm turbo and 750'sIm also running different PWM.Im running 100% limit and 25.5ms threshold Id also close down the plug gap to like .028-.030 Let me know if that helps. Link to comment Share on other sites More sharing options...
Funky Phil Posted January 5, 2010 Report Share Posted January 5, 2010 At idle im in the mid 13 afrs and during hwy cruise mid 14's to mid 15's Link to comment Share on other sites More sharing options...
BOHO Posted January 5, 2010 Author Report Share Posted January 5, 2010 Phil...Does that mean you have High impedance injectors? with those setups? I do need to turn the req. back down where its supposed to be. and just change VE. Chad also mentioned shortening the gap a little bit. I will do it and report back. I'll post new pics of plugs after a fresh set and some more tuning. I used the autotune feature for my cruise. It really seemed to help out. running 14's to low 15's Link to comment Share on other sites More sharing options...
BOHO Posted January 5, 2010 Author Report Share Posted January 5, 2010 My smile is getting a little bigger day by day. I still havn't done a WOT pull or even come close to it...I just want to take it slow. For some reason my boost controller had come loose and I saw 22 psi....Didn't miss a beat though....I turned it back down and I'm about to go back out for some more. Idle is MUCH better. Cruise is good...and It pulls 10-15 psi and afr's are in the 11's. I will report back and let yall know.... It's actually getting there.... Link to comment Share on other sites More sharing options...
quikconq Posted January 6, 2010 Report Share Posted January 6, 2010 It's actually getting there.... sweet,,,that number 3 plug looks a bit suspicious also the number one plug looks like its a bp6 or 8might be the angle of the camera to the plug,,,but i see alot more porcelain sticking out keep it up Link to comment Share on other sites More sharing options...
Funky Phil Posted January 6, 2010 Report Share Posted January 6, 2010 Thats great news! Just remember, start out on the rich side and work your way lean. I shoot for mid 11's under boost. And keep your timing conservative til you can get on a dyno and watch it with the gun. Lots of popped motors due to too much advance.Best way to read plugs is to install new ones and make a full WOT pull and then shut it down. Pull the plugs on the side of the road. Otherwise the readings are thrown off by by idle and accel enrichments.You want clean porecelain. NO PEPPERING! and a Dark Gray ring. So tune it on the plugs you got and when your ready to see how its set up put in the new plugs. Good Luck!phil Link to comment Share on other sites More sharing options...
BOHO Posted January 8, 2010 Author Report Share Posted January 8, 2010 Well...I'm sure my "miss" is not in the tune. It's got to be spark related. I'm going to try a different distributor and coil just to eliminate things. For short bursts it doesn't matter but trying to ride out a wot pull it becomes noticible...starts bucking...I don't want to blow anything. AFR's will be steady and all the sudden go crazy..but the fuel map doesn't reflect whats happening. Tach signal is very steady. I don't know what else could be causing it. Link to comment Share on other sites More sharing options...
Funky Phil Posted January 9, 2010 Report Share Posted January 9, 2010 how much boost and what is you plug gap and base timing?? Link to comment Share on other sites More sharing options...
Funky Phil Posted January 9, 2010 Report Share Posted January 9, 2010 (edited) Also, not enough advance under boost will also induce missing. If you already have descent base timing (10-12deg) try turning down the boost and see if it goes away. Edited January 9, 2010 by phinko Link to comment Share on other sites More sharing options...
slowquest Posted January 9, 2010 Report Share Posted January 9, 2010 I took some pics. This is Plugs... 4 3 2 1 ...left to right They are NGK 7's gapped at .038 http://img705.imageshack.us/img705/6479/49894845.jpg Double check that #4 plug, as mentioned above, it looks like a different plug. I can see that #3 actually says it's a 7, but the center of that 4th one looks like it's longer..... Link to comment Share on other sites More sharing options...
quikconq Posted January 9, 2010 Report Share Posted January 9, 2010 thats wat i thought....didnt i??? but its the #1 plug,,as in the engine number onenumber four in "chronic"alogical order..... ,,in the picture might be camera angle tho? Link to comment Share on other sites More sharing options...
