87redcat Posted August 17, 2015 Report Share Posted August 17, 2015 http://i1314.photobucket.com/albums/t563/originalmoxiecat/Mobile%20Uploads/IMG_20150817_151755_361_zpslzyop65u.jpg Removed This^^^ http://i1314.photobucket.com/albums/t563/originalmoxiecat/Mobile%20Uploads/20141027_183214_zps9ndrwutz.jpg Replaced it with this^^^ http://i1314.photobucket.com/albums/t563/originalmoxiecat/Mobile%20Uploads/IMG_20150817_151802_649_zpsx2oa3drr.jpg Before this happened^^^ Link to comment Share on other sites More sharing options...
importwarrior Posted August 18, 2015 Report Share Posted August 18, 2015 I have a trunk full of SHP's on the way to drop them off in storage. Link to comment Share on other sites More sharing options...
Speedy2222 Posted August 18, 2015 Report Share Posted August 18, 2015 Picked up this off ebay for $100, checked my 87 and 88, trying to hunt a low rpm issue on my 87, randomly goes to near dieing rpm, have to hold throttle open to keep it at the right rpm, found 2 possible causes but everything was fine when i checked it. 88 checked out perfect but still only pulls 9 in hg of vaccuum. http://i88.photobucket.com/albums/k181/Speedy2222/Starquest/IMAG0483_zpsf7ygy1qh.jpg Link to comment Share on other sites More sharing options...
pcristquester Posted August 18, 2015 Report Share Posted August 18, 2015 What is it-ECI checker? Did the coozy come with it haha? Link to comment Share on other sites More sharing options...
polarisman14 Posted August 18, 2015 Report Share Posted August 18, 2015 Got the starter, inspection plate, transmission bolts all in and 3 of the 4 drive shaft coupler bolts in along with hand-beeping the whole MS harness. We found a couple miswires so that was definitely worth the time. At this point it's mounting the MS computer and battery, running heavy gauge wires for grounds, alternator, and starter, and plugging stuff in (and topping off fluids) and it'll run. Probably another day of labor and it'll run the time following that. Link to comment Share on other sites More sharing options...
Speedy2222 Posted August 20, 2015 Report Share Posted August 20, 2015 Took her to the dragstrip, only was pulling 12psi on the 14b, not sure why it's so low, however i think there may be a good sized crack in the manifold. http://i88.photobucket.com/albums/k181/Speedy2222/Starquest/IMAG0490_zpsdcji9dfk.jpghttp://i88.photobucket.com/albums/k181/Speedy2222/Starquest/IMAG0491_zpsnr2srj0g.jpg Link to comment Share on other sites More sharing options...
starquestJOE Posted August 20, 2015 Report Share Posted August 20, 2015 Very consistent numbers. Good bracket car Drove both my red mpi and my unicorn Link to comment Share on other sites More sharing options...
importwarrior Posted August 20, 2015 Report Share Posted August 20, 2015 made SS hoses for the turbo water hoses, fuel lines (PTFE) and oil cooler hoses (PTFE)all non swivel AN fittings Link to comment Share on other sites More sharing options...
polarisman14 Posted August 25, 2015 Report Share Posted August 25, 2015 The car didn't run yesterday, but everything else is done. I cranked it over but it did not start. Seems to be an issue with the signal wire coming into the ignition (which means on MS the injectors aren't firing either). That stupid signal wire has caused me so many issues. Hopefully the CR125 didn't take a dump but that's possible...And why I have a couple spares. Shouldn't be long now before another MPI'd SQ is back on the road. Link to comment Share on other sites More sharing options...
Skullzaflare Posted August 25, 2015 Report Share Posted August 25, 2015 The car didn't run yesterday, but everything else is done. I cranked it over but it did not start. Seems to be an issue with the signal wire coming into the ignition (which means on MS the injectors aren't firing either). That stupid signal wire has caused me so many issues. Hopefully the CR125 didn't take a dump but that's possible...And why I have a couple spares. Shouldn't be long now before another MPI'd SQ is back on the road.distributor for signal or crank trigger?i had issues with the serial adapter on usb extension getting way to much interference causing corrupt signals to the ecu. i fixed the issue using a serial extension with the usb adapter directly in the laptopignition power for the ecu, i ran off the black/yellow from the coil, which i think is powered off the eci fusable link Link to comment Share on other sites More sharing options...
polarisman14 Posted August 25, 2015 Report Share Posted August 25, 2015 (edited) Mine won't work regardless of the RS-232 output being connected to the laptop or not. This was a running MPI car at the beginning of the summer but cracked ring lands and piston skirts coupled with an electrical nightmare and leaking everything out of every orifice possible led me to yanking the engine and doing a full rebuild along with fixing all the MS and heavy gauge wiring while the engine was out. Just trying to get it back up and running now. I am guessing that the braid is making contact with the inner signal wire and grounding it out but I'll find out soon . Mine is powered off the ignition switch--I believe it's black with a white striped wire. That's the only accessory I have powered off of it. Edited August 25, 2015 by polarisman14 Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 26, 2015 Report Share Posted August 26, 2015 Received my first ever aftermarket rims today. http://www.starquestclub.com/forum/uploads/gallery/album_1144/gallery_2764_1144_82664.jpg Link to comment Share on other sites More sharing options...
mbruneaux Posted August 26, 2015 Report Share Posted August 26, 2015 Received my first ever aftermarket rims today. http://www.starquestclub.com/forum/uploads/gallery/album_1144/gallery_2764_1144_82664.jpg Pics of them OUT of the box? Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted August 26, 2015 Report Share Posted August 26, 2015 (edited) ok twist my arm http://www.starquestclub.com/forum/uploads/gallery/album_1144/gallery_2764_1144_78581.jpgFit is really good, no poke and about 3/8" clearance to the D2's in front (1"+ in back). Pretty happy with it so far. Edited August 26, 2015 by MikeMeyerhoff Link to comment Share on other sites More sharing options...
ucw458 Posted August 27, 2015 Report Share Posted August 27, 2015 Mine won't work regardless of the RS-232 output being connected to the laptop or not. Serial cables carry very little voltage. The cable needs to be very short. 5-6 feet max. Longer than that you get signal degradation or even no signal. I found that out the hard way when I tried to program my LC1 with a 10 foot cable. Link to comment Share on other sites More sharing options...
polarisman14 Posted August 27, 2015 Report Share Posted August 27, 2015 Trust me, that isn't the problem. I too have a 10 foot serial cable and have been using it for 4 years with no issues whatsoever along with the RS232-USB adapter that I have. The MS unit and MSD box are not blinking at all when cranking and there is already a good functional tune that Scott made that is on the MS unit. The issue lies with the signal wire, not the serial cable. Just need to find out where and why. Link to comment Share on other sites More sharing options...
Crazy larry Posted August 28, 2015 Report Share Posted August 28, 2015 replaced worn out Leaking power steering pump. Next time something breaks it's going to the crusher. Link to comment Share on other sites More sharing options...
importwarrior Posted August 28, 2015 Report Share Posted August 28, 2015 rebuilt my turbo AN hoses.new -8AN NON Swivel hose ends.took her for a spin. Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted September 2, 2015 Report Share Posted September 2, 2015 replaced a window regulator. The bushing on the end of the arm just fell apart and the window dropped while driving. Link to comment Share on other sites More sharing options...
Speedy2222 Posted September 2, 2015 Report Share Posted September 2, 2015 Drove my 87 to work( as i always do) Listed my other 87 forsale, http://i88.photobucket.com/albums/k181/Speedy2222/87questfrsle/IMAG0500_zpslaqgrtpm.jpg And finally tried to get " The pile" started.. no luck Link to comment Share on other sites More sharing options...
importwarrior Posted September 3, 2015 Report Share Posted September 3, 2015 worked on a conquest for a friend. rebuilt the -8AN hose for him with new -8 90 fitting. put the rear D2 coilovers on..front steering inner and outer tier rods and Idler arm bushings went on also. also fixed the gas tank filller rubber coupler leak Link to comment Share on other sites More sharing options...
ionstar Posted September 6, 2015 Report Share Posted September 6, 2015 Fixed a leak on my oil coolerOil changeAnd polished my rims with mothers polishOverall fun day Link to comment Share on other sites More sharing options...
Convette Posted September 6, 2015 Report Share Posted September 6, 2015 https://instagram.com/p/7RG9kQqGku/ added a muffler to muffle. Link to comment Share on other sites More sharing options...
Guest Posted September 6, 2015 Report Share Posted September 6, 2015 (edited) https://instagram.com/p/7RG9kQqGku/ added a muffler to muffle. Still sounds like it will wake the neighbors and alert the popo you are close by! But it sounds good! Is that a bolt on/off muffler? Edited September 7, 2015 by louswheel Link to comment Share on other sites More sharing options...
mbruneaux Posted September 6, 2015 Report Share Posted September 6, 2015 https://instagram.com/p/7RG9kQqGku/ added a muffler to muffle. Another sponsor? Link to comment Share on other sites More sharing options...
