sleeper tsi Posted January 23, 2013 Report Share Posted January 23, 2013 What's the best rear end gear oil for our cars and how much fluid does it take to fill it? Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted January 23, 2013 Report Share Posted January 23, 2013 http://www.starquestclub.com/forum/index.php?showtopic=80029Rear axle: 2.7 pints of GL-5 gear oil WITH added "friction modifier" for cars with the limited slip differential (LSD) (there is a warning sticker on the door jam of LSD equipped cars that warns about jacking only one rear wheel up and then running the engine). Mitsu dealers sell a one gallon can of pre-mixed stuff that is great... but pricey too. Chrysler dealers sell "MOPAR Hypoid Gear Lubricant" (part no 4318058) plus the friction modifier (part no. 4318060) Link to comment Share on other sites More sharing options...
jszucs Posted January 23, 2013 Report Share Posted January 23, 2013 I pretty much always go with Amsoil now that I found a guy who is a dealer right by me. Link to comment Share on other sites More sharing options...
TopDawg_43 Posted January 23, 2013 Report Share Posted January 23, 2013 Royal Purple is what I have in my tranny and rear end. You can buy a tube of the addative at Advance for a few dollars. Buit I know the Royal Purple already has it. Link to comment Share on other sites More sharing options...
Convette Posted January 23, 2013 Report Share Posted January 23, 2013 I'm using Royal Purple also, takes a beating, pricey, but good stuff. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 23, 2013 Report Share Posted January 23, 2013 (edited) I personally have only used Sta-Lube GL-5 Gear Oil (Compatible with Limited-Slip Differentials) in my 1987 ESIR Limited-Slip Differential since 1989. Never had to replace or repaired my rear end Stock off the boat!!! And, the tires still catch on wet corners straightening the car out. 152,000 miles on the car....That tells me this: You really don't need Mitsubishi Genuine Gear Oil Part no. 8149630EX. Proof is from 24 years of driving this Limited-Slip ESIR for 120,000 miles using only Sta-Lube GL-5 80wt Gear Oil. Limited-Slip additive?.......They just want your money " I don't mind getting screwed if I get something out of it, If I don't....I'm not a happy camper" Paying a astronomical price for LSD additive you don't really need........Well, you decide In the end...Read the FSM............. It says: Mitsubishi Genuine Gear Oil Part No.8149630EX....or EQUIVALENT!!!! Get it. Mitsubishi is wanting you to believe that you can only use part no. 8149630EX. When in reality, you could use a equivalent. This is why I used the EQUIVALENT!!!! Instead of paying for a rear differential additive from Mitsubishi that I really didn't need Equivalent doesn't mean the same thing. It only means that the product has the same properties as the other. If Mitsubishis LSD Differential gear oil is the same (equivilent) to Sta-Lubes GL-5 80wt Gear Oil. Then, those members who professed to using only Mitsubishi Diaqueen Gear oil were WRONG!!!! To those I say......READ THE FSM. Bill Edited January 23, 2013 by Caliber308 Link to comment Share on other sites More sharing options...
IntercooledFlatty Posted January 23, 2013 Report Share Posted January 23, 2013 Royal Purp here as well drain the diff then fill it til it comes out of the fill hole, flog your quest as usual not worrying about the rear end breaking Link to comment Share on other sites More sharing options...
ucw458 Posted January 23, 2013 Report Share Posted January 23, 2013 Limited slip additives are for fiber clutch plates. SQs have small metal clutch plates so the additive is not needed. On fiber LSD setups straight gear oil will make them slip too much rendering the LSD useless. The additive is a friction modifier that allows the fiber clutches to do their job. Link to comment Share on other sites More sharing options...
sleeper tsi Posted January 24, 2013 Author Report Share Posted January 24, 2013 Sounds like i'm gunna go with the royal purple. What weight though? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 24, 2013 Report Share Posted January 24, 2013 Another vote for Sta-Lube GL-5 Gear Oil. I have Amsoil in there right now from the extra i bough to put in my rebuilt 5-speed. Everything else i had sta-lube in. Even my 4x4 has it in the transfer case and 5 speed.There is a test where Royal purple gear oil failed against some others so i went with Amsoil. http://www.starquestclub.com/forum/index.php?showtopic=124098&hl=amsoil&do=findComment&comment=1208230http://www.syntheticharleyoil.com/gearoilcomparisontest.html Link to comment Share on other sites More sharing options...
Shelby Posted January 24, 2013 Report Share Posted January 24, 2013 Conquest LSD uses fiber and steel platesthe actual job of the adative is to coat all plates to stop metal to metal rubing , you know that shutter hopping and jumping as you turn a tight corner need'd or not need'd useing the adative deff won't hurt any thing ,,but if it don't stink to high heaven it's no good Link to comment Share on other sites More sharing options...
white quest ky Posted January 24, 2013 Report Share Posted January 24, 2013 I'm an amsoil vendor too Link to comment Share on other sites More sharing options...
jszucs Posted January 24, 2013 Report Share Posted January 24, 2013 Sounds like i'm gunna go with the royal purple. What weight though? Most makes make diffrent weights like 75-100 or 80-120 ect. IIRC the Amsoil I used was 80-120 Link to comment Share on other sites More sharing options...
sleeper tsi Posted January 24, 2013 Author Report Share Posted January 24, 2013 Thanks. Link to comment Share on other sites More sharing options...
