jszucs
    3
jszucs last won the day on September 26 2013
jszucs had the most liked content!
About jszucs
  • Birthday 03/12/1979
  • Interests
    "Keep the turbo spooled!"
    Cleveland OH
  • ICQ
  • AIM
    joe+19+oh
    00000
  • Factory Color
    Rio/Mexican Red
9868 profile views
jszucs's Achievements
  • Week One Done Rare
  • One Month Later Rare
  • One Year In Rare
Recent Badges
42
  1. Wow, did not want to come back to see this. I'm glad I have seen you post after the 1st post though. Thank you for all you have done. Thank you for setting an example I could never live up to, but makes me try and be better. Thank you for your service, all you have done for the community and this platform. You will live on forever in our minds hearts and cars. Do take care and I hope to see you still posting
  2. steering wheel that is attached to something more then a wire
  3. not only does it look cool it's functional.... pretty sure all the non baby buels have done this.
  4. Click the advanced options and check / unchecked forgot which the avoid highways. You can then drag your rout around as you wish. There is alwasy going to AAA and getting a good old trip tic? do they still even have those?
  5. Raise suspension 4 or so ", Skinnyer rims and tires (mountain rated snow tires) make weight box distribute weight in said box and take out and test in slick conditions. Make adjustments to box and weight till you get it just right. Maybe adjust you mix of antifreeze, add winter washer fluid and winter wiper blades. Add MRE, blanket, flare (mainly for starting fire) shovel and other various supplies. hat gloves and change of clothing. Turn the boost down
  6. Gas is total junk now. Drain it, and refill in summer is best bet.
  7. IE BLOWS..... heck if you want IE use firefox and download the IE tab plugin and run IE in firefox with the IE tab. Personally just don't use IE at all.
  8. Well that's an epic deal then. The only thing I found that blizzaks had was a higher speed rating then other winter tires which most are rated for 70 and below. And in my exp you really don't want to go much faster then that with true mountain rated winters. As long as your not going wider then a 215 you should be fine if they throw snow and don't cake up, and are softer and don't get hard in extreme cold. Even grab just a bit of weight like 2 bags kitty liter. Then if you do get stuck you can use kitty litter for traction.
  9. They are not charging you for the light, they are charging you to remove and reinstall the light. You need to learn to read like you should have read the contract you signed. In all likely hood PDR is going to be at BEST 400 450 so really not that far off. If it were me I would be requiring an edge to edge repaint, so more then likely your going to have to live with the respray. + not sure if that is a crease or not but if creased PDR will not work. The loss of use your lucky it's that low, they could charge you full kilt on loos of use while the truck sits each day waiting for this to get sorted out. I mean really man up and take some responsibility here why would you ever secure stuff where you have to climb on the truck roof? At worst just stand in the door jam.
  10. If your going to replace with braided you might as well cut the bano bolts out of the line and use the correct adapters
  11. I had a real hard time finding shops that could mandrel bend 3". You will have to hit up big rig places till you find one that can mandrel bend 3"
  12. be cautious, the sending unit, and related are hard to come by.
  13. You don't look like your that low in your sig pic to be scraping. You might need to take a look at / rework some of the hangers / hang points on your exhaust to tuck better. They could also be causing vibration and drone. With a bit more restrictive muffler you could be just sending the right frequency at that RPM causing drone. I would 100% get that bend out of there if you can. Adding a resonator is a great idea to change the sound. Might try a different muffler designed to sound deaden VS a glass pack style muffler.
  14. ^ well someone has not been keeping up.... cuz then you would know the real deal now is running pimp stars and playing video in your rims while you drive Anyways back on topic how about brembos from g35's
  15. ^ and why not just turn into insurance..... and good luck getting it lowered..... I think you kind of passed that point when you didn't fix it before you returned it.
