psu_Crash Posted May 13, 2010 Report Share Posted May 13, 2010 Well I said the new setup would find the weak link in my drivetrain ... and it did. I just thought it would be the clutch first Getting on it a little coming off a light and when I hit second gear .. BANG! ... no go. Engine was still running and no matter what gear I put it in all I hear is some faint grinding sounds. Haven't got under it yet to see if it's the trans/clutch or rear end. No fluid dumping all over so that's good. Waiting on my uncle who owns a rollback to call me back so we can go get it. I am not even really that bummed because THANK GOD IT'S NOT THE ENGINE!Kind of a funny coincidence that I just found a local guy selling multiple trannys and rear ends. Link to comment Share on other sites More sharing options...
Killtodie Posted May 13, 2010 Report Share Posted May 13, 2010 didnt see anything snapped visually? Link to comment Share on other sites More sharing options...
psu_Crash Posted May 13, 2010 Author Report Share Posted May 13, 2010 didnt see anything snapped visually? Nope, but all i really did was reach under and grab the driveshaft to make sure it was still connected. Link to comment Share on other sites More sharing options...
jahjah Posted May 13, 2010 Report Share Posted May 13, 2010 yeah... I'm just waiting for the exact same thing to happen to me, seriously. shift to 2nd and pop. only a matter of time. Link to comment Share on other sites More sharing options...
mstieg Posted May 13, 2010 Report Share Posted May 13, 2010 sounds like a tranny Link to comment Share on other sites More sharing options...
psu_Crash Posted May 13, 2010 Author Report Share Posted May 13, 2010 Well, it's home and in the garage now. My uncle seems to think I ripped the center out of the clutch since it doesn't really make any noise when you put in in gear, jsut a slight rubbing noise. It tries to move ever so slightly like a fried clutch would do. Had him look under while i tried to put it in gear and the driveshaft doesn't move. So I think the rear end is ok. I'll pull off the inspection plate tomorrow and get a look at the clutch. Link to comment Share on other sites More sharing options...
dmyers151 Posted May 13, 2010 Report Share Posted May 13, 2010 (edited) I'll pull off the inspection plate tomorrow and get a look at the pieces of clutch. Like you said man, at least it wasn't the motor. Also, I've been looking into AutoX like we talked about, I found some stuff. We'll talk about it. Edited May 13, 2010 by dmyers151 Link to comment Share on other sites More sharing options...
BrazilBoy Posted May 13, 2010 Report Share Posted May 13, 2010 Its sounds like the trans...or most likely its..http://forgottenliberty.com/wp-content/uploads/2009/10/Bush_Fault.gif Link to comment Share on other sites More sharing options...
NotStock88 Posted May 13, 2010 Report Share Posted May 13, 2010 I hope its just the clutch Link to comment Share on other sites More sharing options...
Indiana Posted May 13, 2010 Report Share Posted May 13, 2010 You're doing this to an 86 transmission? Link to comment Share on other sites More sharing options...
bha280 Posted May 13, 2010 Report Share Posted May 13, 2010 mine just did that a few weeks ago, stripped almost all teh teeth off second gear on the main an about a quarter of the counter shaft. Link to comment Share on other sites More sharing options...
BC_99 Posted May 13, 2010 Report Share Posted May 13, 2010 Let us know what ya find when you get it apart. Can you put the car in gear when its not running? If yes, does the car move if pushed when its in gear and not running? Just curious for more symptoms. BC_99 Link to comment Share on other sites More sharing options...
rosengrant826 Posted May 13, 2010 Report Share Posted May 13, 2010 Like you said man, at least it wasn't the motor. Also, I've been looking into AutoX like we talked about, I found some stuff. We'll talk about it. please fill me in on this.... and um mike this better be ready for charlies meet Link to comment Share on other sites More sharing options...
psu_Crash Posted May 14, 2010 Author Report Share Posted May 14, 2010 Indy yep it's an '86 trans. I knew this was coming. I can put it in any gear I want (including reverse) running or not and push the car around. I can shift it like this without using the clutch too. Tomorrow I should have time to tear it apart and see what's going on. Link to comment Share on other sites More sharing options...
ucw458 Posted May 14, 2010 Report Share Posted May 14, 2010 Not trying to be nitpicky but fyi the movie quote in your avatar should be "never cross the streams" Link to comment Share on other sites More sharing options...
starquestJOE Posted May 14, 2010 Report Share Posted May 14, 2010 (edited) its the clutch. my black 89 did the same thing. in the end there was no pads left on the clutch disc. let me know if you want to upgrade to 88-89 lightened flywheel Edited May 14, 2010 by starquestJOE Link to comment Share on other sites More sharing options...
Indiana Posted May 14, 2010 Report Share Posted May 14, 2010 I've seen 88/89 lose 2nd and an 86 lose three gears on a 1-2 hard shift, I'd say you are looking for a new tranny. Its not hard to drop the pan on the tranny and you might be well to flush it out if its not dead and that's quicker than pulling the whole thing out. Link to comment Share on other sites More sharing options...
strang3majik Posted May 14, 2010 Report Share Posted May 14, 2010 my original one in my car lost second, then 1st and reverse in short order afterwards. It would go into any gear, but, as soon as I let the clutch out in 1st, 2nd, or reverse, it would go about 1ft then lock up.3rd through 5th worked great though...lol And...that was the trans. If you can put it into any gear without using the clutch while the engine is running...sounds clutch related to me. Either that, or the shifter fork broke...which I doubt...lol But, I would think if it was something in the trans, at least one of the gears would keep you from putting it in gear whilst the engine running. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 14, 2010 Author Report Share Posted May 14, 2010 (edited) Just ordered a 6-puck ACT HD clutch. I am leaning heavily towards that being the problem since I lost all gears all at once, and when shifting it things feel fine. Even if it's not I need a new clutch since I could get the currently installed clutch to slip a little. I think it is an XTD stage 2 in there right now. BTW this did not happen on a hard 1-2 shift, by no means was I leaving the light like it was a drag tree. Shifted nice and easy into 2nd then hit it and at about 4k RPM ... well ya know Edited May 14, 2010 by psu_Crash Link to comment Share on other sites More sharing options...
quikconq Posted May 15, 2010 Report Share Posted May 15, 2010 Indiana is 100% correct,,,change that old fluid that's probablyoverdue,,,and that too will tell ya if it's the tranny. from my experience when a trannylet's go,,,it makes quite a bit of noise.Good luck Link to comment Share on other sites More sharing options...
Coke Posted May 15, 2010 Report Share Posted May 15, 2010 I vote blown clutch disk. It's happened to me. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 Got it on jack stands tonight and pulled the bell housing inspection cover.... small twisted metal pieces ... Tranny drops in the morning. Link to comment Share on other sites More sharing options...
Komeuppance Posted May 15, 2010 Report Share Posted May 15, 2010 Stripped the input shaft...?? LOL... -Robert Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 Stripped the input shaft...?? LOL... -Robert Always the optimist aren't we? Link to comment Share on other sites More sharing options...
Komeuppance Posted May 15, 2010 Report Share Posted May 15, 2010 LOL... well no one suggested that as a problem... someone had to. -Robert Link to comment Share on other sites More sharing options...
