psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 (edited) I just changed fluid in the tranny and rear end not 100 miles ago, and yes I used the right stuff. So I got it on the stands and started it up. Put in gear and the rear tires spin ... WT!? Apply the parking brake and they stop without putting any load on the engine. I look under and the driveshaft is still turning but the wheels .. nothing. Not making any odd noises what-so-ever. Turn the car off and grab a tire. I can turn either tire separately and the other doesn't move at all, neither does the driveshaft. Seems like the clutch/tranny are functioning So you were all wrong! It's 100% in the rear end. Man, I JUST had that all out to do poly bushings!!! The couple small pieces of metal i found in the bell housing still have me a little concerned though ... Edited May 15, 2010 by psu_Crash Link to comment Share on other sites More sharing options...
Big Al Posted May 15, 2010 Report Share Posted May 15, 2010 SOunds like you've got a couple of problems brewing all at once. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 SOunds like you've got a couple of problems brewing all at once. yep, new clutch is already on the way so out comes the tranny anyways. O boy! lol Link to comment Share on other sites More sharing options...
Big Al Posted May 15, 2010 Report Share Posted May 15, 2010 So when the wheels are spinning and you hit the e-brake did you actually check the driveshaft to see if it was still spinning as well? Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 So when the wheels are spinning and you hit the e-brake did you actually check the driveshaft to see if it was still spinning as well? Yes and it is turning without the tires moving at all. Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 15, 2010 Report Share Posted May 15, 2010 Snaped an axel or i have heard they can pop out once in a while. Or mabe a tourqe tube. Time for a 6 bolt Some body in New York had one for sale. http://i237.photobucket.com/albums/ff45/StarquestRescue/DSC00194.jpg Link to comment Share on other sites More sharing options...
Indiana Posted May 15, 2010 Report Share Posted May 15, 2010 (edited) This happened to someone last year, don't remember what it was though Edited May 15, 2010 by Indiana Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 Got the axles out and they look fine. Got it all loose and realized I should have listened to the service manual and took the torque tube off. Thought I could pull the diff with that still attached. Looks like I was wrong. Link to comment Share on other sites More sharing options...
ucw458 Posted May 15, 2010 Report Share Posted May 15, 2010 Got the axles out and they look fine. Got it all loose and realized I should have listened to the service manual and took the torque tube off. Thought I could pull the diff with that still attached. Looks like I was wrong. You can pull the diff with the torque tube still attached but you have to remove the driveshaft flange first. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 15, 2010 Author Report Share Posted May 15, 2010 You can pull the diff with the torque tube still attached but you have to remove the driveshaft flange first. Thought about that but I haven't come up with a good way to hold the flange solid so I can break that nut loose. Setting the rear parking brake like the service manual says is out since the rear is broke somewhere Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 15, 2010 Report Share Posted May 15, 2010 In pack gun long extension and a universal can usually get the hard to get tt bolt. Or take the front and rear sub frame nuts loose and let the sub frame hand down in front. Might have to move your jack stands to just in fronf of the front mount. Use a board there. Link to comment Share on other sites More sharing options...
Dave-O Posted May 15, 2010 Report Share Posted May 15, 2010 here's to hoping it's not the torque tube shaft itself. Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 15, 2010 Report Share Posted May 15, 2010 (edited) http://www.starquestclub.com/forum/index.php?showtopic=81527&st=30 Its easier to unbolt the tt, but that can be hard to do if the diff bolts are out and it flopping around. Eagerly awaiting pictures of the carnage. I have a couple of 4 bolt rears laying around. I could re stack a lsd nice and tight for you. Edited May 15, 2010 by StarquestRescue Link to comment Share on other sites More sharing options...
ucw458 Posted May 15, 2010 Report Share Posted May 15, 2010 Well that's how I do it anyway. With the driveshaft flange out of the way that gives you the extra inch needed to do the job. (I know someone is gonna comment on that last sentence.) An impact gets that nut off and if the splines aren't rusty you can pull the flange off by hand. If they are rusty then a steering wheel puller will do the trick. Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 16, 2010 Report Share Posted May 16, 2010 (edited) Well that's how I do it anyway. With the drive shaft flange out of the way that gives you the extra inch needed to do the job. (I know someone is gonna comment on that last sentence.) An impact gets that nut off and if the splines aren't rusty you can pull the flange off by hand. If they are rusty then a steering wheel puller will do the trick.Lots of ways to skin a cat. Never thought of your way. Maybe he does not have an impact gun. A bar with two holes in it could be bolted to the flange to hold it. That's how i hold a flywheel to torque it. Crash will figure it out. Git r done, we have a race to run. I think i can whoop you. Edited May 16, 2010 by StarquestRescue Link to comment Share on other sites More sharing options...
psu_Crash Posted May 16, 2010 Author Report Share Posted May 16, 2010 Well ... I got it all apart. Not so much carnage as I think operator error Take a look at the end of both axles. I think in the course of my recent suspension work I unknowingly pulled the the circlip through the splines and it held the axle so that it got just the end of the shaft. New tires + turn up the torque = BANG! This would also explain why the wheels would move when I put it in gear while on stands. Just 2 days before this happened I can attest to it's ability to light up both tires so it must have just happened??At least that is my theory http://img291.imageshack.us/img291/194/img0834a.jpghttp://img4.imageshack.us/img4/2638/img0842ed.jpg Nothing odd herehttp://img580.imageshack.us/img580/8492/img0838h.jpg But those sure look like pieces of splineshttp://img195.imageshack.us/img195/4991/img0840f.jpg Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 16, 2010 Report Share Posted May 16, 2010 So it came out part way and just stripped the end? I could send you an axel, but those chips should be cleaned out of there. Maybe a magnet could get them out. Do the side gear splines look ok? Link to comment Share on other sites More sharing options...
psu_Crash Posted May 16, 2010 Author Report Share Posted May 16, 2010 So it came out part way and just stripped the end? I could send you an axel, but those chips should be cleaned out of there. Maybe a magnet could get them out. Do the side gear splines look ok? Side gear splines look ok. I'll have to try a magnet but I still think it needs a thorough cleaning. Who knows what happened to the pieces I don't see. Happen to have 2 4-bolts laying around? Link to comment Share on other sites More sharing options...
Komeuppance Posted May 16, 2010 Report Share Posted May 16, 2010 So I WAS right... stripped the input shaft... on the axles. LOL... Good thing those shafts are still fairly easy to get, I think even Autozone sells remans. -Robert Link to comment Share on other sites More sharing options...
psu_Crash Posted May 16, 2010 Author Report Share Posted May 16, 2010 (edited) A quick shop around shows that I can only get the non-intercooled axlesI know the 88-89 axles were different but IC versus non IC??? Hmm .. Ebay Axles Edited May 16, 2010 by psu_Crash Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 16, 2010 Report Share Posted May 16, 2010 Side gear splines look ok. I'll have to try a magnet but I still think it needs a thorough cleaning. Who knows what happened to the pieces I don't see. Happen to have 2 4-bolts laying around?Axles?, Yes i have them. Why two? If you take the ring gear off the diff housing be sure to put a mark on the ring gear to line up with the mark on the diff haves for reassembly. If you take the diff housing apart to get the chips out do not hesitate to ask questions. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 16, 2010 Author Report Share Posted May 16, 2010 Well the more I look at the LSD the more I am avoiding taking that apart. It looks like the pieces stayed pretty much in the splines of the diff. I'll clean it up to the best of my ability.Do I even need new half axles? Doesn't that circlip go on the inside of the splines anyways? Or is there a groove that is sits in?I said 2 because both of them are stripped on the end. Link to comment Share on other sites More sharing options...
Indiana Posted May 16, 2010 Report Share Posted May 16, 2010 Clean the ends up with a file and use them. I would remove the circlip and test fit before final assembly. You can flush the gear oil out with solvent and as long as the LSD isn't being turned since the axles are out the oil will stay in there then just put it back together. Link to comment Share on other sites More sharing options...
psu_Crash Posted May 16, 2010 Author Report Share Posted May 16, 2010 Now that's what I like to hear! I'll be working on it in the morning and report back if I have problems. Thanks to everyone for the advice! Link to comment Share on other sites More sharing options...
Big Al Posted May 16, 2010 Report Share Posted May 16, 2010 Ok I'm confused what I'm looking at here. First, are you saying those circlips are supposed to be there at all? Second, I'm assuming that shot of the LSD is from the rear with cover removed correct? So then what exactly is the last shot of? And looking at the inside of the LSD, even if you can't see metal bits, seeing that nice hole there in the center, looks like a prime place for nasty little shavings to hide. As much as I hate my sperm donor, there is one thing he used to say before he disappeared that stuck with me. If you're going to do something, do it RIGHT or don't do it at all. It'll save you hassle and headache in the long run. Link to comment Share on other sites More sharing options...
