Killaphil HX35 Dyno
FunkLab Meth Injection HX35 Megasquirt
53 replies to this topic
#21 CaliConquestAlex
CaliConquestAlex
    The Wrench
  • 2,388 posts
  • Interests:BOOOST!
Posted 24 June 2015 - 01:03 AM
Does it feel laggy? Not much power below 4500 rpm...how's the boost response? Post a video of a pull 1st-3rd?
#22 jinx
jinx
  • 1,920 posts
Posted 25 June 2015 - 09:45 PM
stock cam + 'decent' sized turbo normally peak 400 ft=lbs ~4000rpm (from my observations)
performance cam looks like it shifted tq peak 1200 rpm higher and fought off the nose dive
was the holset 12cm exhaust housing used ?
luv seeing these solid 54 builds. Good stuff
#23 jinx
jinx
  • 1,920 posts
Posted 25 June 2015 - 10:08 PM
Quote
My yellow one did 440 at 16 psI with a 35r. Would  say that is pretty good for that size Turbo!
Quote
good for you....... you should make a post
sounds interesting. SQC could use more of those types of posts (on builds/dyno)
#24 Funky Phil
Funky Phil
    Super Pooper
  • 6,444 posts
Posted 25 June 2015 - 11:21 PM
stock 12cm housing fitted with an external wastegate.
#25 creakyjoints
creakyjoints
  • 1,939 posts
Posted 26 June 2015 - 04:39 PM
Would like to see the timing table if possible.
#26 Funky Phil
Funky Phil
    Super Pooper
  • 6,444 posts
Posted 26 June 2015 - 05:17 PM
Edited by Funky Phil, 26 June 2015 - 05:19 PM.
#27 lionbull
lionbull
  • 3,274 posts
  • Interests:DUH
Posted 26 June 2015 - 05:47 PM
HAHAHAHAHAHAH...
Edited by lionbull, 26 June 2015 - 05:48 PM.
View Postvettekiller593, on 09 September 2011 - 10:20 AM, said:
Lol you guys must be blind. He would of won if the supra didn't give him a 1/8 mile start. Lol you guys kill me.
View Postlionbull, on 07 September 2011 - 02:26 PM, said:
ALSO this is not a HP race. It is a race. You dyno queen guys need to remember this. I am not speaking to anyone in particular but you know who you are!
#28 movin on
movin on
  • 939 posts
Posted 26 June 2015 - 07:11 PM
Oh my.......
#29 scott87star
scott87star
  • 4,999 posts
Posted 26 June 2015 - 10:50 PM
Looks like 8 past 10, excellent!
#30 creakyjoints
creakyjoints
  • 1,939 posts
Posted 28 June 2015 - 10:08 AM
Nice table. You should deliver to my house.
#31 stariondreams
stariondreams
  • 421 posts
Posted 28 June 2015 - 06:13 PM
I have yet to see any  of the top Running guys ever post their timing or fuel maps .I understand why it is blood and sweat some guys work very hard on tuning and make their money that way.I coach little league but after i am finally getting down to my brothers shop to make alot of pulls on dyno I will post everything.The nicest thing is it will be on a dynomite dyno so i think a starquest first maybe.
#32 Funky Phil
Funky Phil
    Super Pooper
  • 6,444 posts
Posted 28 June 2015 - 06:23 PM
dynoMIIIIIITE!
#33 scott87star
scott87star
  • 4,999 posts
Posted 28 June 2015 - 07:28 PM
And you shouldn't see any Dionell, its not all about the blood sweat and tears that went into it although that is part.  It's more about the fact that tuning is better defined as calibration.  You calibrate the motor for the induction/exduction pieces it has on it as well as the fuel quality being used, and your build/fuel/workmanship is not the same.  Might be better, bigger, tail wagging badder but it isn't the same and using someone else's maps is kind of like using their underwear.
I see it all the time on the generic tuning sites, "I need a base map for a xxyyzz"!  My answer is always the same, no you don't.  It just leads to broken parts.  You can post your maps and they may be interesting to look at but if anybody follows your recipe they won't be happy.
#34 Funky Phil
Funky Phil
    Super Pooper
  • 6,444 posts
Posted 28 June 2015 - 10:30 PM
^ exactly
#35 DieHARDmitsu.
DieHARDmitsu.
  • 1,854 posts
  • Interests:Star Orion
Posted 29 June 2015 - 10:35 AM
Maps/Tables are shown here http://www.starquest...showtopic=51144
These can be used as base maps to get a car running but please don't go WOT with someone else tune.
Tuning maps will vary on each motor even if they are built with the same specs; elevation, air temps, knock, and humidity are some of the major tuning factors. I've screwed around with a number of cams, turbos and exhaust on my car. Re-tuning was necessary each time I changed a part that altered the flow of the engine.
#36 IntercooledFlatty
IntercooledFlatty
    Get Sum
  • 14,378 posts
Posted 29 June 2015 - 04:33 PM
indeed, but what you don't see is that it's PM, if you tried to use it as AM....... BOOM !
          MOPAR POWERED
#37 Technology
Technology
    TheNerdyProfessor
  • 11,391 posts
  • Interests:Lots of boost!
Posted 29 June 2015 - 08:56 PM
#38 scott87star
scott87star
  • 4,999 posts
Posted 30 June 2015 - 06:57 PM
Andrew, I've looked at this three times now, I'm going with my initial reaction which was "wow, is that retarded".
#39 stariondreams
stariondreams
  • 421 posts
Posted 30 June 2015 - 07:58 PM
Please do not take my post as a shot at any I do understand. On a side note I have had help by Funky phil over the phone and help from scott In which believe it or not I always give you guy credit in my parts here. I wish i was close to Tx i would have phil tune my car and pay every bit for it.
#40 G54Bstore
G54Bstore
    SQC Commander
  • 5,162 posts
Posted 02 July 2015 - 05:53 PM
You think a hx35 on a tbi would make good power?
The wastegate it came with is set for 24psi.
I love this build though ..excellent job Phil!
W18 Rocky White Starion
Daily Driver
Also tagged with one or more of these keywords: FunkLab, Meth Injection, HX35, Megasquirt
