Turbo Cary
7
Everything posted by Turbo Cary
Kev why don't you use FCP Euro instead of ECS? That's where I get parts for my M6
83’ Starion powered by Chevy 2.2 Turbocharged engine
Turbo Cary replied to JERSEY ARTFORM's topic in Newbie Introduction
What kind of Roll Tide Alabama cousin lovin stuff is this????- 14 replies
I doubt it will have found a home. When's the next time you'd be coming down?
It's close enough. Just trust him.
Why would I get rid of the balance shaft..
Turbo Cary replied to Mike7447's topic in Just plain ol' B.S.
Balance shafts are to reduce the vibrations that 4 cylinders naturally have. Not all engines have them though. My old Honda didn't, my Miata doesn't. It really depends on displacement. I'd say that anything over 2.0L usually has them as the Ecotec engines have them. I removed them on my old Conquest. It revved up easier, had better oil pressure, and made the timing chain system simpler. There is also the weight loss you can do on the block itself by using a freeze plug and cutting off the balance shaft chamber under the intake manifold. It isn't required but it does free up room to work. -
Come pick it up. Better to have a spare for future issues. Especially considering how hard are to find these days.
Located in Charleston SC. I found an old short block in the shed. Free to anyone willing to come pick it up. Don't ask me the condition. I didn't look hard enough at it. I'm pretty sure the crank is there along with the main caps and maybe pistons/rods
Been a while since I've posted. For my winter projects I have a few. Getting my RHD Miata painted in a few weeks. Gotta strip the interior out and remove panels for my dealerships body shop to do the paint. I'll be Alcantara wrapping part of the dash and door panels while also replacing the carpet. It's really expensive to get a carpet set since it's gotta be ordered from a UK company. I also got my uncle's 07 GT500 Cobra last year in September after he passed away. Had to cash one of my 401ks in but this car had 3k miles on it when I got it. Now it's at 7k after driving it back from California to South Carolina and some misc in town driving. Installed a CAI and muffler delete. I have HPTuners so I'll unlock it's ECU and tune it soon. Haven't done anything with my DA Integra with a turbo B20 swap. I'll probably sell it soon. Installed a train horn and some other misc stuff to my Silverado. Finally got my Pro Features cable from HPTuners so I can find tune that truck. Other than that it's just home improvements and spending time with the family.
My advice is to fix the engine and turn around and sell the car to break even. There is no investment in it. You'll find parts supply is dwindling and even if you swap it you'll never get all the money invested back out. Sorry it happened to you.
When installing the rear cam plug be sure to give it a good coating of RTV. I prefer using Three Bond 1217H RTV. We use it on GM vehicles where I work. Good stuff and very oil resistant.
Nice car! GLWS. Would you be interested in trades at all or is it just a cash only situation?
You need to go over and check all of your grounds. Every single one on the car. Get yourself a 9004 headlamp bulb, a socket for it and some test leads. Solder it up to make a heavy duty test light. I also highly recommend buying a power probe tool. Then go over and test every 12V power into the trouble components and see if they can light the bulb. Test it between the components power and ground and also the battery negative itself. If the bulb is dim or not lit between the components power and ground then it could be high resistance causing the lack of full function.
It really does suck you lost your thread about your car. The amount of good pictures during the build process was awesome.
Cars looking great dude!
M5x1.0 or M5x0.8?
Ideal swap? Inline 6 such as 1JZ or 2JZ. Car was basically made to fit something like that. The G54 is a good engine but has it's drawbacks. Going MPI really opens it up. The bottleneck of an intake system on these cars robs it of power. A good tubular manifold and big turbo you can make some serious power on the G54. Even with a TD06 16G turbo on TBI I made 300hp 400tq at 18 psi. That isn't even a large turbo. Joe's conquest with MPI and a big turbo was insane to drive. I did some tuning with the Haltech before he went to MS and I had that thing flying.
Good how have you been?
Windshield Clip and Trim replacement / installation
Turbo Cary replied to techboy's topic in Virtual Mechanic
Fwiw I had a similar issue where a windshield company had not put the trim back in well and it came off. They actually paid me money to go find a parts car and get the trim! In any case the clips were broken and they said something about using clips from a Jeep which worked.. I don't know what year or model but maybe that can help someone in the future when looking. -
DG-5 Coilovers from Japan
Turbo Cary replied to StarionTroy's topic in eBay/ Craiglist notices and alerts
2200 is a decent price. Especially if they are good quality coilovers. -
Nothing wrong with hypotheticals. EVs have come a long way since they first began. There is a lot more to them now than there was before.
GM EV specialist here. You "could" use a Bolt battery pack but it takes up the entire undercarriage of the car. The motor is in the front but you could fab it up to be in the rear like a Tesla. Another option is to just use a Tesla motor/battery pack. The pack can be configured vertically or horizontally depending on space limitations. So if you wanted to use the former engine bay for the battery pack you can. GM uses batteries that are broken down into sections within the packs. Each cell has about 3.2V but when put in series makes a much higher rating. You'd need a controller to monitor battery heat, charge, and regenerative braking. Not too difficult but it is possible to wire up. You will also need to run a coolant pump for the charging port if you decide to use a GM charge adapter. Coolant is circulated through the battery pack on GMs as it is a sealed unit. We can open them up to service certain cells but it's a very specific procedure you don't want to get wrong. I only suggest going with a big manufacturer of EV cars cause they have it figured out. Makes it the best option for charge distance, parts service etc. Someone on the interwebs did a Tesla swap to an old BMW 3 series. I'll try and find the link to give you an idea of what they did.
Realistically the only option is to change the whole front suspension to 240SX setup with coilovers etc. That would be the most cost effective swap as I think the 300ZX calipers bolt right to them. Nissan's are a lot like Honda where the parts are interchangeable between models. if someone with a Conquest parts car knew someone with a 240 to do a quick mock up of the factory 240 parts as a comparison it would help confirm fitment.
DYNO VIDEO—My 1JZ Conquest is finally done
Turbo Cary replied to Preludedude's topic in Just plain ol' B.S.
I know I'm going to get slammed for this but consider a K Series swap. 4 cylinder and a company makes a RWD kit that can be paired with a Mazda Miata or BMW transmission. -
I'm gonna need to take a drive up your way to see this thing -
What car projects did you get to over the Xmas break?
Turbo Cary replied to kev's topic in Just plain ol' B.S.
I had to go with the plastic rear window because of my roll bar setup. The Hard Dog Double Diagonal doesn't allow for a glass rear window. I don't mind it actually cause it will last longer than the glass window. The weight of the glass causes the seams to tear over time. My only gripe is that I can't tint the plastic. In the summer whenever I do drive it I usually have the top down. Do you still have the old top? If so I could use it to make a bikini top for my Miata. Such as this
