obsolete
    8
obsolete last won the day on July 28 2023
obsolete had the most liked content!
    Minnesota
    55901
    1988
  • Factory Color
    Rio/Mexican Red
    Being Modded
10288 profile views
obsolete's Achievements
Collaborator
Collaborator (7/14)
  • Posting Machine Rare
  • Conversation Starter Rare
  • First Post Rare
  • Collaborator Rare
  • Dedicated Rare
Recent Badges
18
  1. This is the correct MAF-T: https://www.extremepsi.com/store/MAF-Translator-Mitsubishi-Eclipse-90-94-BLACK-FRIDAY-SALE-FTS-050DSMTRANS1G.html I wouldn't bother with it, though. Megasquirt is a way better long term solution.
  2. I think the 88+ diff has a different axle spline count; 28 vs. 25 for 87 and older, if I remember correctly. I think I remember hearing that the axle parts can be mixed and matched (i.e. use parts from both 87 and 88 axles to use an 88 diff with 87 hubs or vice versa) but I haven't tried that myself and wouldn't want to bet on it working, sorry.
  3. I have one out of an 88-89. Diff, torque tube, and axles. Unfortunately, I don't know much about it since I didn't pull it from the car; I got it with a load of other parts. I'm up in Rochester, MN and would be willing to meet you halfway to eliminate shipping. I can send you pictures/videos if you're interested.
  4. I'm not aware of a viscous LSD in a Starquest. They're all clutch packs as far as I know.
  5. That's funny, Viscous Realtime sounds they were referring to an AWD system, but the road cars never got one.
  6. There was a guy in one of the Facebook groups named James Kane who modified a Montero sender to work. Of course, because this is the way Facebook works, all the info appears to have been lost, so I can't tell you how to do it, but it is possible.
  7. The C-clips hold the studs in the hub too! For some reason known only to Mitsubishi, the studs aren't press fit into the hubs like most cars, and if the clips aren't installed, the studs can slide out and spin, which sucks. I used Loctite 680 on mine to hold them in so that I could eliminate the clips and run aftermarket wheels. Yes, the clips do go between the rotor and the wheel. The stock wheels have counterbores at the lug holes to clear the clips.
  8. Sure, RockAuto has them: https://www.rockauto.com/en/catalog/chrysler,1988,conquest,2.6l+156cid+l4+turbocharged,1062470,steering,power+steering+pump+seal+kit,7407
  9. Might try changing the fuel filter also, just to rule that out.
  10. Those wheels look great on the car! Fellow quest & C5 owner here as well
  11. You can get enough current to weld out of a 12V lead acid battery, which is more dangerous than a current-limited power supply if there might be a short in the wiring you're testing. That being said...I still just use a battery. Good luck.
  12. Cool! That's a great idea. Thanks for posting it.
  13. All my A/C experience is with R134a, but 0psi on the low side with the compressor running says to me that the system is low on refrigerant.
  14. Turbo Cary's advice above is great. Also, given all the problems you mentioned, I can't help but wonder if you have a problem with your ETACS module. I'd start troubleshooting there.
