75
kev last won the day on March 20
kev had the most liked content!
PA
Website URL
http://
17202
37818 profile views
kev's Achievements
I saw that. Someone was also selling off a few prototype versions of the hot wheels diecast on ebay. I guess they were experimental body shapes that weren't selected for the production mold (although appeared to be better representations than the one that was selected). I probably should have snagged one of those when I saw them, but I don't go out of my way for novelty items like this. Now just wait, with my luck those things will be worth like 10 grand in a few years or something haha.
No problem. It has been a long time since I did it, but I need to do this on my black conquest too. Wind noise is very noticeable without this gasket!
Use widebody calipers with the original flatty caliper brackets...that's if you can even find widebody calipers these days.
Only option right now is to buy a rebuilt distributor, which comes with the vacuum advance. But wonder how long those will be available for?
Going around the corners is a little tricky. I had to slice the back side of the U-channel of the edge trim with a razor blade to get it to fold around nice. Used a few dabs of 3M trim adhesive to hold it in position on the back side. Edge trim was sourced from McMaster-Carr. Leave the little gap on the bottom for moisture to run out...just like it was stock.
Oh, I think I saw that same picture on FB the other day. Yeah, they have a slightly different look. So, do they fit our widebodies? I'm assuming these are EU spec markers? The earlier model flatbody markers look similar but the screw hole is in the wrong spot to mount it on a widebody car. Not that you can't modify it to make it work but it doesn't just bolt on. I do like the 'line' through the light on the earlier flatbody markers. Same thing with the B-pillar panels with having the two louvers. Adds a little different look to the car...but, makes me just want another earlier model flatbody car again.
It's most likely a vacuum advance. Can test it with a vacuum pump to see if it holds but I've seen these sometimes hold vacuum but not boost. The diaphragms rot away with time. Unfortunately, the suppliers who use to carry aftermarket vacuum advances have seems to stopped. Mikie has been trying to work with them to get batches made but this has been an issue for a few years now. The only current solution is to buy the full distributer....so what was once a $15 purchase for a typical starquest 'tune-up' is now $250! it sucks but one of the things we face with these already rare cars approaching 40 years of age.
I've experienced this same issue multiple times. Can't fully explain it, electrical is not my strong point, but when the clutch is engaged, it enables the clutch switch used for the cruise control (basically like an inhibitor switch on an automatic but only used to disengage the cruise control if the clutch is depressed on a manual). I can't remember if it closes the circuit or opens it when the switch is engaged. Anyways, I've noticed that the idle is absolutely affected depending on when the clutch is depressed or not. How and why...I don't know but it is I proved it by pulling the switch off the pedal and depressing it by hand. How I fix this is to rerun the TSC/ISC reset procedure until it resolves the issue. Basically, depress the switch and run the TSC/ISC and set the idle accordingly. Then see how it runs after the switch is let go. Tweaking the idle settings between the two. For a quick fix if you don't use cruise, unplug the switch and see how it runs (or connect the leads depending on the 'normal operation'...like I said, I can't remember if the circuit is normally open or closed when the clutch pedal isn't engaged). As much as I love these cars, I hate our engine management systems especially anything pertaining to idle. I've done the TSC/ISC reset over 20 times on a single day until I got it to be somewhat what I wanted it to be during all operating conditions...and it still goes erratic at times but won't stall.
For once, I'm not doing too much work on a conquest...knock on wood. Been driving my black 88 a lot since the collision repair and really enjoying it. So much so that my blue 87 has only been backed out of the garage bay once in the past six weeks or so and pulled right back in after changing some light fixtures in the bay. I'm in the process of cleaning up my garage in preparation to actually start sheet metal work on my 68 mustang. But also have to address my broken garage heating system before the temps drop too much. kev
Do you still need the info regarding those foam inserts in the sides of the engine compartment? The ones the harnesses pass through? I ran into one the other day in my garage. It isn't the easiest thing to measure because it is cut on an angle (both the OD and the ID hole). But I can snap a few photos with a ruler in the picture if it would help?
i saw your post on FB. Welcome back!
Of course I'm going to show the finished photos! I'm very happy with the final result. All the gaps looks great, the paint looks great, the decals look great, the wheels look incredible! If it weren't for the condition of the passenger door, drivers fender, hood, and roof that are all original paint and have many door dings, this car would look brand new. Taking it out for a drive. Runs good, no vibrations from the bubble balanced wheels, etc. The rear decal appears a little 'bold' compared to stock. Line width is a little thick. But, definitely looks better than it did You can see the door dings on the passenger door in this photo. One of the future challenges for myself is to learn paintless dent repair. I have experimented with it some last year and did pull out a larger dent on the drivers fender. It's still slightly visible though. Favorite shot....still can't believe I hand pulled the frame, core support, and other engine compartment structure good enough to make all of these panels fit like this! It's very rewarding.
Assembly: This was the first time I had removed the passenger rocker panel cover on this car. I was kind of worried that I'd find a rust hole or something. But, in the nature of this car, it was great! Minor surface rust at the overlap joint, as usual. Cleaned that up and coated it. But from here on out, it was the normal assembly...of which I did like 30 times by test fitting along the process. That original black headlight cover looks a bit out of place now....of course I polished that up before the end of the day Gluing on the rubber strip on the grill. I stopped assembly at this point for a bit as I let this dry Next up were the new rims: I purchased new tires for the rear, last week, but I am reusing the fronts...for they only have a couple thousand miles on them and are like brand new. I have had a harbor freight tire changer now for several years. I had used it to change tires on my utility trailer and other projects with steel wheels. Worked good for those applications especially in that this thing was only like $35 originally. But, it would mess up alloy and aluminum wheels. So, I did what I really enjoy doing and modified it. Beefed up the bead breaker mechanism with longer and thicker pipe and reinforced breaker. And I added a homemade duckbill attachment (well, the duckbill itself was bought from amazon for like $10...plus some clamps and roller bearings which were also cheap, aluminum centering bushing, and some scrap steel). Removing the tires from the front rims: Bead breaker worked amazing! And the duckbill worked flawlessly! And installing the fronts on the refurbished rims...: The duckbill mod is so slick. Just walked the tire on the rim! The rears took a little more 'oomph' to install just because the tires were brand new compared to the fronts, but still were installed with ease Then came balancing. Cheepo amazon bubble balancer. It was hard to see the bubble at times but a flashlight helped. Used stick on 1/4 oz weights on the inside of the wheels. Worked well for what it is. Definitely not as precision as a spin balance but does the job: Photo looks like it was uncentered but it was my camera angle. Can't believe how simple it was to tackle this! No driving to a tire shop, paying $35/wheel, arguing with the guy not to use lip weights, worrying about him marring the wheels I put so much effort into restoring..etc. Decals: While I was working on installing the tires, the mailman shows up and delivered this! I went to work removing the existing decals on the hatch and drivers fender. One of those $10 vinyl decal erasers and some polishing with the buffer.... This hatch and rear spoiler is still OEM paint! And installing the decals. Used the 'wet method'. Installing and squeegeeing them smooth. Leaving the application paper on until they dried. After a half an hour or so, I peeled off the application paper. The header panel decal was the hardest being that it had the small letters and there was one area that kept lifting. It took two minutes to do all the paper on the rest but about 20 minutes of finesse getting the front one off. Also, installed the grill...didn't show photos of that...it's two screws.
Most likely BK227WS with the 24mm, with the snap ring, input bearing. The BK227AWS is for non-intercooled applications and has the 21mm bearing. Although, I have seen an 87 transmission with the flanged input shaft bearing! Maybe a fluke...maybe someone replaced the pan or something. Not sure, but it was a stamped steel pan KM132 out of an 87 and had the 88/89 input shaft bearing in it! That kit will give you the main ball bearings, syncs, and gaskets/seals needed to do a basic rebuild. It will not have the needle roller bearings that are in each gear set. It won't have the retainer or shift works as well. It does include a main shaft nut though. But, more importantly, it doesn't include the shims needed to shim your countershaft. That was the biggest **** when I rebuilt mine. Mitsubishi sold the shims individually. I ordered a few based on some quick measurements. Came from Japan, 4-6 weeks. Turns out, when I torqued everything down, I had more play than measured and needed to order a thicker shim. Ordered a few more of different sizes...again 4-6 weeks. Have no clue if they are still available or not. If I had to do it again, I think I would work with a local machine shop to have some custom shims made for it. Coupled with the lack of available parts, the disassembly is a PIA. Lots of frustrations with pulling the bearings including making custom pullers, etc. I recently added a few more photos to the end of my KM132 rebuild thread in the FAQ forum to show my custom main shaft center bearing puller. I also saw a guy on FB use a harbor freight 20T press to drive out the bearing. Not that I'm advocating a swap, I hate swaps, even if it is just the tranny....but, it may be the easier way to go (and more enjoyable/rewarding).
Yes, at least for a basic rebuild. Listed under KM 131 at cobra transmission. KM 131 Standard Transmission Parts | Cobra Transmission
