15
Everything posted by Fuze
Hey if you're happy nothing else matters. When I said more modern I'm thinking of newer Haltechs or Link products. I've seen the MS stuff around the Starion world since the 90's when there were few options, but I never hear about ppl running it on a a Toyota, Nissan or LS motor. But I 1UZ swapped mine so that's where my head's at.
Definitely tried all those Tokico/lowering springs, GC sleeve-over conbos, etc, they are far inferior to even a cheap coilover set. You lose too much travel with the old methods if you lower the car, parts weighs a ton, and damping isn't adjustable. Basically this problem was solved with coilovers, everything before that was just old 90's era solutions because there wasn't a better option. You can get whatever spring you want and it'll fit if you're not happy with what the coilover you have comes with. I've been running D2's forever and wouldn't even think of not using them. Everything else is a compromise and it feels like it.
Just realized I haven't posted a pic on here in 10 years. Battlemagnet is still around, it's got a 1UZFE Lexus V8 swap now, super wide custom Work rims, Lazorack Motorsport widebody, and a bunch of aero I fabricated, along with all of the other carbon fiber stuff it had before.
Wait, what engine is in this car? All G54B's have the vac advance unless it was removed for standalone ignition, or something like that...
First things first, if you're running a stockish size turbo you don't need more fuel pressure, and Delphi's don't like pressure over 45PSI they start to act strangely, stock level is about 35-38PSI. If you're running something bigger than a Super16-G at high-ish boost (15+PSI) the MAF-T can help change the fuel curve a bit to accommodate. Use the 1G DSM (Eclipse/Talon) box with a 3" or 3.5" GM Corvette MAF sensor. If you're going big turbo, or going with an MPI intake then yeah you need to go standalone. Megasquirt is a popular SQ option, but there are more modern options now. But I must say, for the money you'll be into to make that happen, you can swap a different motor and have more power and more options. Just my .02.
is anyone running D2 coilovers and MK1/mookeh rear camber plates?
Fuze replied to Mech's topic in Advanced Virtual Mechanic
The parts should be able to be combined, but you're not going to have access without taking out the interior covers either way. I sold a set of those MK1 adjusters on here years ago. Also the stock body opening is small, so adjustment is pretty limited as you're using the strut top bolt to secure it. -
I've had this kit for many years. It fits fine, mine uses redrilled BMW rotors. The alternative is to swap your knuckles, coilovers and LCA's for S13 Nissan parts, and then you've got access to a lot more options including Z car parts, Cadillac caliper swaps, etc.
Your problem is likely related to a bad Vacuum Advance module on the distributor. When you make boost, it retards the timing. When they fail, the car hiccups when you start to make boost. To test it, pull it off and push the plunger in and hold your thumb over the nipple. If the plunger moves out, it's bad. As for lifters, I switched to mechanical lifters when I still ran the G54Bt as they're just more reliable, however they do work best with the mechanical cam. good luck
D2 coilovers front, do i have them on the correct side?
Fuze replied to Mech's topic in Just plain ol' B.S.
That's correct. You want the hat closer to the rear of the opening, closer to the firewall so your caster is right. -
Been so long since I posted real content here, tutorials and stuff like that. It's tough to judge the interest in posting certain things. Since we last talked, my Starion build is a lot different. Here's what's changed: Lazorack Motorsports full widebody kit and all associated body mods Fresh Blitz Black paint and re-cleared all carbon fiber JDM Toyota 1UZFE V8 swap with JDM Nissan S14 transmission and Collins adapter kit 17x11" custom built Work VSSS fronts and 18x12.5 Work Meister rears, 6' and 7.5' lips 3" Oval sidepipe Interior conversion/major delete Custom LED tails and fogs Sleepy Eye flip-up headlight mod Rewired whole car Once I can post images again from a web URL (my server space) I may start up a thread documenting the build for posterity. If you're on Instagram, you can find it at @battlemagnet. Cheers
After 20 years I should be a Universal Grand Master, and so should you actually. But since they gave me GM, I'm good with that though lol.
I hope this reaches the admins! Haven't been around too much but when I look at any old post I've made with images, (which are hosted on my server which has no issues,) the image URL is displayed instead of the image. To make it worse, the URLs aren't even hyperlinks, you'd need to copy/paste it to view the image. For example, this post : Can you resolve the issue by allowing hyperlinks to resolve image files inside the posts?
I hope this is a group for all the admins! Haven't been around too much but when I look at any old post I've made with images, (which are hosted on my server which has no issues,) the image URL is displayed instead of the image. To make it worse, the URLs aren't even hyperlinks, you'd need to copy/paste it to view the image.
I mean, I feel like I deserve it you know? Newbie looks kind of crazy up there! 😭
Instagram. Then FB. The old forum model is outdated for today but the OG's still know. New people aren't coming here to look for answers, not because the answers aren't here but because generations that came after us don't want to spend a bunch of time hunting for answers, they want quick gratification. Also, and this isn't new, the attitude toward noobs hasn't always been good here, the whole "search for it before posting" response and expecting visitors to read the rules before they look for help... typical forum stuff.
What do YOU think makes the starquest such a great car?
Fuze replied to 89andBlue's topic in Newbie Question and Answers
They're super reliable. LOL -
Mitsumark's former car-1988 Starion ESI-R on eBay auction. Lots new!
Fuze replied to stesir's topic in Just plain ol' B.S.
Trust me you don't want this POS lol. -
UUUMMMMMMMMM, you know, inflation.... I did fix it up and paint it so yeah, it doesn't have the gray spray paint on it anymore. Such a nice wall decoration (got a CF one on the car) but if you get a car, we'll talk. -
I don't think that's too expensive to fix a problem that annoying. Never mind the hassle of changing a steering box out more than once.
You can pour money into any car to make it fast, but when you include braking, handling, the full envelope you run into much more cost to stay even with modern performance cars. Depends on what you're comparing it to though. An S12 that lights up the tires in 3rd with a CA 1.8, the first question I'd ask is how old/skinny/cambered are those tires? My second question would be, how long do you think it'll last?
The T2 cooler is efficient for 80's tech, is neat and tidy, and will do the job with a hood vent. Still, it's not a bar and plate cooler so it's inherently not going to be as efficient as one that is, ebay or no. (Less internal surface area to dissipate heat.) Should do the trick it's not like you're boosting a lot or beating on it.
This is great research. I used the rollers years ago and never figured out why they ran the car so badly, I just gave up and put the slip rockers back in and was back in business. I admit not having the patience at the time to deal with all of this!
