87redcat Posted May 14, 2014 Report Share Posted May 14, 2014 sucked out what seemed like a full tank of varnish (I mean gas) outta the tank. GOD THAT STUFF STINKS Link to comment Share on other sites More sharing options...
R-R-Quest Posted May 14, 2014 Report Share Posted May 14, 2014 Picked up the transmission yesterday. Will continue to bead-blast suspension components when I get home this evening. Link to comment Share on other sites More sharing options...
randy Posted May 14, 2014 Report Share Posted May 14, 2014 I tried to count the amount pollen on it,but i couldn't so i hosed it off. Link to comment Share on other sites More sharing options...
87redcat Posted May 27, 2014 Report Share Posted May 27, 2014 Cleaned out the inside of the tank and flushed w/water...dried and soldered the tube for the bowl inside. cleaned up some ruts on it and painted the top and undercoated the bottom. Link to comment Share on other sites More sharing options...
Woody Posted May 28, 2014 Report Share Posted May 28, 2014 Well this isn't really what I did Today. But here it goes. 2 weeks ago, re-wired the fusible links as they were burnt out plus some of the loom. Also there was no fuse between the alternator and the battery.1 week ago got the Funk Lock installed.Last night finished rebuilding the TBI.Tonight? Firing her up again to make sure the TBI rebuild went well. Link to comment Share on other sites More sharing options...
cheesey Posted May 28, 2014 Report Share Posted May 28, 2014 Threw another Benjamin at it. Temp gauge and thermostat on its way. At least I've been able to drive it a little bit. Still some kinks to work out. Link to comment Share on other sites More sharing options...
markhansenconquest Posted May 28, 2014 Report Share Posted May 28, 2014 Found out 86 starter solenoid sticks sometimes and blows ECI fuse link....putting in my 87 starter tonight. .Been looking for 86 AIT senser for 2 weeks and found it on rockauto....Took out starter and had to remove clutch slave cyl .. Nut fell out from Inside slave cyl boot!!! was inside cyl to make rod longer !!!!!??? The motor is 89 and car is 86 and don't know what year clutch is in car??I know there is a different rod for 86-87 compared to 88-89....I don't know how someone could drive this car with fixes like that!!!!!!!!!!! The more I clean the more I find out what is wrong....SUPRISE,,,,SUPRISE,,,SUPRISE.......Everyday I find poor fixes on everything..... Link to comment Share on other sites More sharing options...
RonnieJ Posted May 28, 2014 Report Share Posted May 28, 2014 How did you mount and secure your radiator? Havnet yet. Been busy with work but ill use the upper mounts and drill holes for the tabs on the rad Link to comment Share on other sites More sharing options...
averse Posted May 28, 2014 Report Share Posted May 28, 2014 Replaced the clutch. Welded bung on intercooler pipe for Scott87Star's engine managment system install later. Threw some "stone paint" on the parts car for giggles... Link to comment Share on other sites More sharing options...
markhansenconquest Posted May 28, 2014 Report Share Posted May 28, 2014 (edited) averse what clutch did u go with ???did u pick up that car?? Edited May 28, 2014 by markhansenconquest Link to comment Share on other sites More sharing options...
bodhi Posted May 28, 2014 Report Share Posted May 28, 2014 Ordered the TEP downpipe and B pipe to get rid of the cats! Link to comment Share on other sites More sharing options...
Shelby Posted May 29, 2014 Report Share Posted May 29, 2014 starter circuit is on the IGN fuse link not the ECU fuse link may there is some rewiring has been done some where in the system Link to comment Share on other sites More sharing options...
GINASQ Posted May 29, 2014 Report Share Posted May 29, 2014 I talked about my car today. Link to comment Share on other sites More sharing options...
bodhi Posted May 29, 2014 Report Share Posted May 29, 2014 (edited) Picked up a rear strut bar last night Edited May 30, 2014 by bodhi Link to comment Share on other sites More sharing options...
creakyjoints Posted May 29, 2014 Report Share Posted May 29, 2014 My S256 arrived yesterday! Link to comment Share on other sites More sharing options...
importwarrior Posted May 29, 2014 Report Share Posted May 29, 2014 purchased some AN fittings.checked the doors to make sure it is locked.that's about it... Link to comment Share on other sites More sharing options...
sellerfeller Posted May 29, 2014 Report Share Posted May 29, 2014 yesterday, replaced a missing front brake pad retainer. charged battery. alternator pulley separated from crankshaft pulley unit so on went the MK1. cleaned fuse link connections. replaced belts with gates green stripes. tightened loose exhaust bolt. cleaned and oiled k&n air filter. overtightened another clamp bolt so replaced a t-bolt clamp lol. Link to comment Share on other sites More sharing options...
BillS Posted May 29, 2014 Report Share Posted May 29, 2014 New clutch, pressure plate, and shifter Link to comment Share on other sites More sharing options...
BillS Posted May 29, 2014 Report Share Posted May 29, 2014 (edited) Also new trans oil Edited May 29, 2014 by BillS Link to comment Share on other sites More sharing options...
BC_99 Posted May 30, 2014 Report Share Posted May 30, 2014 I finished chopping that turd up and loaded the remains in the back of my dump truck. http://i601.photobucket.com/albums/tt93/BC_99/Random%20cool%20shit/20140529_173905_zps068ce265.jpg BC_99 Link to comment Share on other sites More sharing options...
averse Posted May 31, 2014 Report Share Posted May 31, 2014 averse what clutch did u go with ???did u pick up that car?? After speaking with Jonboyb I decided to try out the Competition Clutch stage 4 ceramic and 15lb flywheel. It's been an adjustment learning the new clutch because it's so much softer and engages quicker. I did get the car from John in San Diego, along with several extra parts. The engine is rusted pretty thoroughly and will need a complete rebuild I think. Car appears to have been in an accident in back, based on the damage that includes missing half of the bumper on the passenger side. Having some fun with it before Sam and I salvage good parts off of it to keep our cars running though: Fleckstone link! Link to comment Share on other sites More sharing options...
jjohnson Posted June 1, 2014 Report Share Posted June 1, 2014 Got my nissan aluminum radiator mounts made and installed and the funklock is now off the kitchen counter and in the car Link to comment Share on other sites More sharing options...
nycain Posted June 1, 2014 Report Share Posted June 1, 2014 http://i1146.photobucket.com/albums/o538/nycain/download_20140601_123043.jpeg 1 Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2014 Report Share Posted June 1, 2014 (edited) Washed it, waxed it, hit the road did a buck twenty on the 118 fwy, saw temp needle creeping up and backed off til I got to my destination, a Mustang Club car show. Tried to sneak it in as 80's Mustang but those guys actually know what Mustangs look like. LOL Edited June 1, 2014 by louswheel01 Link to comment Share on other sites More sharing options...
cheesey Posted June 2, 2014 Report Share Posted June 2, 2014 Cleaned the engine and tranny off trying to find source of oil leak. Found some peeling paint from brake fluid on frame rail must be recent because no rust yet, cleaned that of and repainted. Pondering if I should rebuild my auto or do manual swap. My auto is slipping . Link to comment Share on other sites More sharing options...
