The problem with used cars...
CaliConquestAlex
Here's a little venting... I purchased a 2006 Dodge Magnum last year and I'm just now getting around to doing an oil change on it. I drive the car up on ramps and take the underbody panel off to reveal this rounded off mess of a drain plug that was also leaking a bit:
http://i1050.photobucket.com/albums/s415/apordes/382D4EBC-8431-4014-AE74-42C56C3ECB05-7837-0000026EA60A88B7_zpsabd81fff.jpg
Queue the repeated expletives. Of course I tried to take a stab at it with a socket, wrench, vice grip, and a pipe wrench. All of these tools couldn't grab onto it well enough to put force on it to loosen it. I did some reading and found this set of bolt extractors:
http://www.amazon.co...p/dp/B0000CCXVZ
They were in stock at my local autozone so I picked a set up. After a couple tries I managed to get the drain plug off. THANK GOODNESS! I did the oil change and replaced the drain plug with a new one from autozone.
http://i1050.photobucket.com/albums/s415/apordes/31B8431F-2700-4656-BC3F-E253FF99DC99-7837-0000026EB968378F_zps7db668d9.jpg
Moral of the story, next time you buy a used car check these types of things out for extraordinary wear to perhaps get the seller to repair the damage or knock the price down.
Edited by CaliConquestAlex
you bought the vehicle last yr , this is the 11th month of this year , sort of over due for that oil change don't you think ;)
Lolll!
I have problems with buying cars used aswell, there will always be a part where i say,WHAT? WHY?!??? WHO DOES THAT!? Those bolt extractors are the best! Here in montreal with the snow and salt, cars tend to rust up very bad and so do the brake lines, its the only tool that will remove a rusted brake line fitting out of a piston or caliper. I have a snap-on set that remove lug nuts, they work really well to remove the security nuts that you lost the tool for
It's the 5.7 Hemi engine. Yes it definitely was overdue for the oil change at about 8k miles since purchase. It's got 95k on it. I'm going to change the tranny fluid and filter next. The car overall is in good shape and runs very well. I plan to keep it for awhile and do some upgrades like suspension and wheels eventually. Edited by CaliConquestAlex
Consider the alternative ... buy a new car ... drive it off the lot, have it significantly depreciate on your drive home and they pay ridiculously on it for the next 5 years. Or worse, pay a more financially manageable amount for 3 years, be limited on how many miles you can put on and own nothing in the end.
Used cars aren't so bad, just shop wisely. ;)
This is very true. I know car collectors who will it buy a new car even if they can get it cash up front. They prefer low mileage lease trade ins as they have depreciated enough but yet are still almost like new.
I also know people who like being in perpetual debt with lease vehicles. They drive them til lease is up and go back to the dealer to get into debt for another. I've noticed they ate people who don't like to service or maintain cars. That's why they prefer leases.
a guy i know leases cars and only tops off the oil for the lease term.
i dont think he ever changed the oil on any of his leased cars.
Buy something newer (2005+ typically) and invest in a good scan tool. Can scan everthing about newer cars, ever service interval has to be reset ect. Just did that with my current buy, and at 18K and every dealer record for the car I coudn't find a single issue.
Edited by jszucs
Alot of those mopars use that small 13mm head drain plug and are always beat up. Looks like someone used visegrips on it, seen it plenty of times working in a shop that does lofs.
-Dave
The replacement Dorman plug used a 5/8" head instead of the 13mm. Eventually I'll replace with a fumoto valve.
The first time I saw one of those fomoto valves was when one of my newbie coworkers at the shop was all... "What the hell kinda drain plug is this??" So I went to look at what he was talkin about, and I never seen one before, looked at it for a sec and was like, "Whaaat! That's hella cool!" I then realized it was a mini ball valve, cracked it open and drained away. My coworker was like, "That is cool, why doesn't every car have these?!" Super cool!
-Dave
Yeah, gooled it as well. Looking into it for my commercial truck, 6 gallons of oil every oil change. Would sure make it easy for me to stop drain process after filling 5 gallon bucket and switcing to an empty one for the remaining oil.
I have one of these on my 88:
http://ecx.images-amazon.com/images/I/31wMa97NDIL._SL500_AA300_.jpg
but I like the idea of the brass ball valve better (but why is the outlet port so small, when the ID of the ball is about 1/2 full port valve)
-N8
