lets walk the diesel talk
65 replies to this topic
#41 Dave-O
Dave-O
    Mediocre At Best.
  • 2,854 posts
Posted 29 April 2012 - 05:15 PM
I love that all the diesel Starion talk and action is coming from Utah. You in Vernal, another guy in Spanish Fork, I thought about it when I was in SLC ... great stuff.
Maybe one day I'll do a Conquest with a Merc inline-5 turbo diesel.
View Postdmyers151, on 08 June 2010 - 07:29 AM, said:
I see you got that Limited Edition ish.
#42 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
  • Interests:keeping the starion running, music, golf, so on and so on.
Posted 06 May 2012 - 05:49 PM
sorry for the time that has passed, but here you go!!!
its running! no exhaust.
better vid. coming soon.
Edited by zmcreynolds, 06 May 2012 - 05:51 PM.
#43 Technology
Technology
    Addicted Starquester
  • 10,957 posts
  • Interests:Lots of boost!
Posted 06 May 2012 - 07:30 PM
The tone is the same as a gas engine, haha!
#44 Dave-O
Dave-O
    Mediocre At Best.
  • 2,854 posts
Posted 06 May 2012 - 09:15 PM
This is intense, I'm so down with it. Nice work man, and in a flatty no less! Flatty Love! :wub:
#45 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 17 May 2012 - 02:25 PM
update,  the motor is running good. getting new exhaust mon. morn. then i can get it street legal and have a new vid coming to yall asap.
#46 87quest_stv
87quest_stv
  • 770 posts
  • Interests:Run it till it burns!
Posted 17 May 2012 - 07:57 PM
Interesting :huh:
#47 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 25 June 2012 - 11:15 AM
so the TDStarion is doing great. i have done about 500mi so far and not a problem one. the diesel has made it a new car ( power band and all) it eats up the mount. roads like it aint no thang.the hp is nothing to brag about, but the tq. is bout the same as stock and i think more fun with the way it comes on.  i will have a vid a.s.a.p. just wating on a few lil fix ups.
#48 wrngwae
wrngwae
    Always Smooth like Keith Stone
  • 1,662 posts
  • Interests:trying to keep this motor under the hood, and off the engine stand
Posted 25 June 2012 - 11:44 AM
you got to turn up that boost and adjust the fuel pump......
1989 Conquest .20 over block. Wiseco pistons.new Marnel head w/ 1mm over sized ss valves. TEP hydraulic 272 cam. Holeset HE341 at 20psi. Stainless log manifold, hurricane MPI intake manifold. 75lb injectors. 3" exhaust. 3bar map sensor. Ajusta Head gasket. ARP head studs. FIP updated by Scott87star to control spark, running MSEXTRA. XTD stage 3 clutch. also running Scott's thermal barrier ceramic coating on the piston tops and the underside of the head, the thin film lubricant coating on the piston skirts, valve stems, cam, cam bearing journals, turbine shaft, turbo bearings, main bearings and rod bearings.  The thermal barrier blue on the exterior of the turbine housing and CHRA and an undercoating of thermal barrier ceramic on the turbine housing and CHRA.  I'm likely forgetting something.
http://www.oemmitsubishiparts.com
http://www.enginemachineservice.com
http://www.starquestgarage.com
Scotts the man! check out his store.
http://www.26liter.u....php?board=48.0
#49 strang3majik
strang3majik
    Hi
  • 5,787 posts
  • Interests:Life, the universe, and everything.
Posted 25 June 2012 - 09:29 PM
This is awesome.  Trade you a new built gas engine that has no oil pressure for it...hahahahaha.
Would go better with my airplane theme as it sounds like one :ph34r:
I'm assuming this is almost direct bolt in?
Edited by strang3majik, 25 June 2012 - 09:30 PM.
#50 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 28 June 2012 - 01:28 PM
got the boost up to 15. have not tuched the fuel screw yet and it pumps out the black smoke. going to put a e.g.t. in this weekend then start tunning more. and  strang3majik. yes it was  old motor out new diesel in. all i had to mess with was oil pan, and starter, since the diesel came from a auto 4wd. other than that strait swap.
#51 wrngwae
wrngwae
  • 1,662 posts
Posted 28 June 2012 - 02:16 PM
i had to extend the oil pickup too for the swap i did. did you?
#52 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 07 July 2012 - 01:37 PM
i had to swap oil pans, put in a oil return on the starion oil pan for the vac. pump on the alt. and then cut off the flang of the diesel oil pickup tube and weld it to the starion oil pickup tube. but now its down, putting in a new rad., e.g.t., front one piece bumper and other lil nit noids.
#53 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 19 July 2012 - 12:53 PM
Back on the road and doing great. going out o town for the weekend. will put pics up when i get back.
#54 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 18 August 2012 - 05:48 PM
here ya go!
#55 Technology
Technology
  • 10,957 posts
Posted 18 August 2012 - 08:02 PM
sweet!
#56 zmcreynolds
zmcreynolds
  • Pip
  • 37 posts
Posted 26 August 2012 - 05:38 PM
so the TDStarion is doing great.  i have done a few 3hr highway runs with no problems.water and e.g.t.'s stay low, boost comes on almost instantly and just pulls to the rev. limit.  the only problem i have is people in my way. i went through the injection pump on fri. and tuned it for more fuel, im now pushing 20psi like it aint no thang. stock was 10, gonna keep playing with it and probably stop at 25. but now i have a really really fun car. tossing out smoke, squealing tires, trq out the wazoo, guessing 35+mpg(caint keep my foot off the throttle) and its fairly quick too.  now its time for paint
#57 Technology
Technology
  • 10,957 posts
Posted 26 August 2012 - 07:25 PM
Haha! this is awesome! 20 lbs is good, you should get a slightly larger turbo!
#58 Metric-man
Metric-man
    Stoichiometric
  • 3,926 posts
  • Interests:Astronomy
    Electrical engineering
    Suspensions
    BBQ
    Surfing
    Trucks
    Weather
Posted 27 August 2012 - 08:03 AM
Hoonage
#59 kyle's89quest
kyle's89quest
  • 414 posts
  • Interests:2jz gte, precision 6765 turbo, no traction! :)
Posted 27 August 2012 - 10:31 PM
Yeah this is awesome. Congrats man!
Posted Image   Posted Image
  What the heck is a conquest???.... Your Bout To Find Out!!!
#60 Skullzaflare
Skullzaflare
  • 3,213 posts
  • Interests:Computers, hotrods, ratrods
Posted 27 September 2012 - 10:44 AM
what do these motors come in?
