Shelby Posted June 29, 2010 Report Share Posted June 29, 2010 very late on this but you do not align theengine and trans straight down the center of the car,, the trans normaly has the tail slightly off tothe pass side to make a working angle for the drive shaft u joint Link to comment Share on other sites More sharing options...
button Posted August 3, 2010 Author Report Share Posted August 3, 2010 Hello.I am a scientist from far away and realized you dont have any pink engine bays.enjoi.http://www.ilostmymind.com/upload/dscn4220.jpg Link to comment Share on other sites More sharing options...
BOOSTED88tsi Posted August 3, 2010 Report Share Posted August 3, 2010 LOL. What paint is that haha way better than the yellow/black combo. Link to comment Share on other sites More sharing options...
button Posted August 3, 2010 Author Report Share Posted August 3, 2010 (edited) its 2 coats gray primer, 1 coat white low gloss, 2 coats rustolium flourescent pink, 4 coats kystal clear.all from a can. Edited August 3, 2010 by button Link to comment Share on other sites More sharing options...
Crazy larry Posted August 3, 2010 Report Share Posted August 3, 2010 http://img267.imageshack.us/img267/3152/2010pink.jpg Sweet... I like Link to comment Share on other sites More sharing options...
Crazy larry Posted August 3, 2010 Report Share Posted August 3, 2010 http://yfrog.com/jx22301j 2nd choice Link to comment Share on other sites More sharing options...
button Posted August 4, 2010 Author Report Share Posted August 4, 2010 oh, don't worry larry, you cant have florescent pink without green. Link to comment Share on other sites More sharing options...
blue_crush Posted August 4, 2010 Report Share Posted August 4, 2010 Damn Jay! Now that's nice. Link to comment Share on other sites More sharing options...
button Posted August 20, 2010 Author Report Share Posted August 20, 2010 http://www.ilostmymind.com/upload/imag0030.jpgThe motor is a 2.3L stroker from FFWD Connection.I am running a commetic multi layer head gasket with arp head studs this year.The cams are King Kams, again from FFWD with Fidanza Limited Edition cam gears.I have a 2g head with 1mm over stainless valves and crower springs and retainers. Link to comment Share on other sites More sharing options...
dmyers151 Posted August 20, 2010 Report Share Posted August 20, 2010 Your engine bay looks like what I'd imagine a hooker's... lady parts... look like. Mostly pink, with some odd green bits here and there. Love the build BTW. 1 Link to comment Share on other sites More sharing options...
starquestJOE Posted August 20, 2010 Report Share Posted August 20, 2010 LOL ^ Link to comment Share on other sites More sharing options...
button Posted August 29, 2010 Author Report Share Posted August 29, 2010 http://www.ilostmymind.com/upload/imag0045.jpghttp://www.ilostmymind.com/upload/imag0046.jpghttp://www.ilostmymind.com/upload/imag0047.jpgIn these pictures you will see the 4g63 nestled into the engine bay with a stock 4g63 water pump that has the conquest pipe welded onto it.It has been paired with a ball bearing T67 (aka GT3788R) in the T4 footprint with ceramic coating and water cooling. The center cartridge is clocked 20° for optimal cooling.It is fed from the oil filter housing and will have a oil pressure gauge after the restrictor and pre-turbo.The fact that I can blow into the exhaust housing and spin the turbo makes me all warm and fuzy inside. Link to comment Share on other sites More sharing options...
button Posted October 19, 2010 Author Report Share Posted October 19, 2010 http://ilostmymind.com/upload/imag0072.jpgnew intake manifold, the first one i just wasnt comfortable with the thin plenum.the new one is 1/8" steel, and 5.9L with the runners. Link to comment Share on other sites More sharing options...
button Posted March 17, 2011 Author Report Share Posted March 17, 2011 (edited) http://www.ilostmymind.com/upload/2011-03-16%2021.16.55.jpg now, what we gots here is a twin 58mm t-body, and i hacked the end off the water to air ic to make a 4" outlet on it coupled to the t-body elbow, and a 2.5" ic pipe off the turbo, and I'm using ~02 dodge neon plug wires. I had to put a brace on the t-body elbow cause it kept blowing off at 30psi. now it holds over 60psi. not enough lip on the throttle body itself. sorry, my new phone makes the paint look like a bass boat... Edited March 17, 2011 by button Link to comment Share on other sites More sharing options...
BOHO Posted March 17, 2011 Report Share Posted March 17, 2011 This is one of the coolest bays I've ever seen...Awesome... Link to comment Share on other sites More sharing options...
button Posted May 22, 2011 Author Report Share Posted May 22, 2011 (edited) it runs!http://ilostmymind.com/upload/camera/87conquest/2011-05-22%2014.32.09.jpghttp://ilostmymind.com/upload/camera/87conquest/2011-05-22%2014.31.47.jpghttp://ilostmymind.com/upload/camera/87conquest/2011-05-22%2014.31.21.jpghttp://ilostmymind.com/upload/camera/87conquest/2011-05-22%2014.33.52.jpghttp://ilostmymind.com/upload/camera/87conquest/2011-05-22%2014.32.33.jpgThe filter in the back was going to be crank case evac, but I need to revisit that because it doesnt seem to be pulling any vacuum.. but it hasnt seen high rpm yet. (over 4k)You can see my turbos water feed and return.I'm running full sequential msIII on a v3.0 board.The tach output works, but it seems choppy.. it could be the 35 dollar tach I'm using.It appears I am running about 100psi oil pressure as well, on my 3rd oil change with 10w30 at 195* coolant temp.I think that is fairly high pressure for idle.. then again it could be the 35 dollar gauge. Edited May 22, 2011 by button Link to comment Share on other sites More sharing options...
BOHO Posted May 22, 2011 Report Share Posted May 22, 2011 What are your plans for this car? HP..Drag.. Nice work man... Link to comment Share on other sites More sharing options...
button Posted May 25, 2011 Author Report Share Posted May 25, 2011 according to my engine/cams/head/turbo specs, on the dektop dyno, over 600hp at the wheels on 30psi, at 8000rpm.no idea on 1/4 cause its a fat biznatch.I'll post results as I make them. I just got my idle stuff working decent on ms3/x and pulled it out of the garage and backed in so I can work on the pc mount and dash stuff easier.so as of today, it runs, and drives. ! . woooohoo Link to comment Share on other sites More sharing options...
Technology Posted May 25, 2011 Report Share Posted May 25, 2011 This is awesome. Link to comment Share on other sites More sharing options...
button Posted May 30, 2011 Author Report Share Posted May 30, 2011 (edited) having an idle control valve is so nice.I can start it without touching the gas... ahhh it's nice. bout f'in time. Edited May 30, 2011 by button Link to comment Share on other sites More sharing options...
button Posted June 5, 2011 Author Report Share Posted June 5, 2011 I had what felt like a rev limiter at 5200 rpm.after checking into it, it was a hardware problem. I hadn't adjusted the potentiometer enough on the ms3x board.now, the rev limiter is whatever I set it at. next is replace my busted windshield while finishing my pc mount. Link to comment Share on other sites More sharing options...
Funky Phil Posted June 5, 2011 Report Share Posted June 5, 2011 doesnt buschur or someone make a tstat provision to eliminate that redonculous coolant line issue?? Im jealous of your cars badawesomazingness Link to comment Share on other sites More sharing options...
screemin eagle Posted June 6, 2011 Report Share Posted June 6, 2011 your high oil pressure is from not running balance shafts. you can port out the pressure regulator in the oil filter housing to lower it. there is a write up on dsm tuners or dsm talk about it.you can leave it too if you have no issues but ive seen cars push out seals in the front cover and b low oil seals in the turbo too. also jay racing sell the front exit coolant housing. car is very cool btw. Link to comment Share on other sites More sharing options...
button Posted June 12, 2011 Author Report Share Posted June 12, 2011 Is it cool if I build 22psi on a free rev?Well I mean it is cool, but is it ok with you guys if I do it and tell you about it? http://ilostmymind.com/upload/22psifreerev.jpg Link to comment Share on other sites More sharing options...
blue_crush Posted June 13, 2011 Report Share Posted June 13, 2011 So not cool. I think you should of checked with us first. Shame on you. Link to comment Share on other sites More sharing options...
