KT Posted September 22, 2015 Report Share Posted September 22, 2015 I pulled my Quest out of the garage today to find a rear caliper leaking fluid. As far as I know, there isn't a rear upgrade brake kit (please correct me if I'm wrong). So, what is everyone using as a replacement? I'd prefer new, or near new, but if the answer is to rebuild the stock caliper, then I'll do that. Anyways, links to parts or rebuild kits would be appreciated. My car isn't fast, but if it won't stop, I'll have to learn body work... Thanks! KT Link to comment Share on other sites More sharing options...
importwarrior Posted September 22, 2015 Report Share Posted September 22, 2015 Rockauto has stock calipers Link to comment Share on other sites More sharing options...
scott87star Posted September 22, 2015 Report Share Posted September 22, 2015 And stock rebuild kits. Link to comment Share on other sites More sharing options...
KT Posted September 22, 2015 Author Report Share Posted September 22, 2015 Rockauto prices range from $63-$93. Is there any real difference? Link to comment Share on other sites More sharing options...
87redcat Posted September 23, 2015 Report Share Posted September 23, 2015 I paid about 90 a piece for rebuilts from O'reilly's. that was about 4 yrs ago Link to comment Share on other sites More sharing options...
tsi_tom Posted September 23, 2015 Report Share Posted September 23, 2015 On one set I saw they used needle bearings for the e-brake lever. The other set used a bushing for the lever. Link to comment Share on other sites More sharing options...
MikeMeyerhoff Posted September 23, 2015 Report Share Posted September 23, 2015 Metal bushing? With the amount of force in that shaft, its hard to believe any plastic bushing would hold up. All the ones I've seen had bearings. Link to comment Share on other sites More sharing options...
tsi_tom Posted September 23, 2015 Report Share Posted September 23, 2015 I think it was metal. Link to comment Share on other sites More sharing options...
Starfighterpilot Posted September 24, 2015 Report Share Posted September 24, 2015 Ya should Strongly consider also replacing the "rubber" brake hoses to all of your brake calipers. They are as old as the calipers - if not older. For What It's Worth. KEN 1 Link to comment Share on other sites More sharing options...
KT Posted September 24, 2015 Author Report Share Posted September 24, 2015 I've had Goodrich SS lines for years, but it looks like the rear calipers are due for a refresh. Link to comment Share on other sites More sharing options...
techboy Posted October 7, 2015 Report Share Posted October 7, 2015 If you do it through RockAuto like most people mentioned I'm pretty sure you have send a core back in. (That's if you do the whole caliper, not just the rebuild kit). I called Dorman once directly since they are local to me, but they wouldn't rebuild for me individually if I dropped them off, they said I had to go through a distributor/vendor - BOOO!!. I need to make friends with someone who works there Link to comment Share on other sites More sharing options...
CaliConquestAlex Posted October 7, 2015 Report Share Posted October 7, 2015 Beware ordering replacements from rockauto. I ordered both sides and the pssenger side one had broken ebrake linkage and didn't work. I cleaned up my stock one and put it on and it was fine. Link to comment Share on other sites More sharing options...
importwarrior Posted October 7, 2015 Report Share Posted October 7, 2015 yes also rockauto sent me the proper caliper but not the bracket. i used my stock bracket with the new caliper. Link to comment Share on other sites More sharing options...
mbruneaux Posted October 18, 2015 Report Share Posted October 18, 2015 (edited) I ordered through Rock auto and Amazon and most were wrong. Eventually i got the right ones, Amazon has a better return polocy if i remember correctly. Don't send in your core unt you know it's correct. Edited October 18, 2015 by mbruneaux Link to comment Share on other sites More sharing options...
