383chevelle Posted December 3, 2013 Report Share Posted December 3, 2013 I am in for a short throw shifter, suspension bushing set, and a set of hub bolts. Ill look at the car agin I might add the rear end mounts and torque tube mounts. Quote Link to comment Share on other sites More sharing options...
sellerfeller Posted December 4, 2013 Report Share Posted December 4, 2013 paid in full... thanks!! Quote Link to comment Share on other sites More sharing options...
importwarrior Posted December 4, 2013 Report Share Posted December 4, 2013 (edited) iwould like the short shifter and a bushing if it is needed. 1 - Short Shifter1 - Bushing Question... do you have any pics of the shifter? even form the past Group purchases?is it an angled shifter? Thanks, Edited December 4, 2013 by importwarrior Quote Link to comment Share on other sites More sharing options...
STARION_NORTH Posted December 5, 2013 Report Share Posted December 5, 2013 Put me down for one suspension bushing kit, motor mounts, and a pair of hub bolts. Quote Link to comment Share on other sites More sharing options...
quikconq Posted December 5, 2013 Author Report Share Posted December 5, 2013 iwould like the short shifter and a bushing if it is needed. 1 - Short Shifter1 - Bushing Question... do you have any pics of the shifter? even form the past Group purchases?is it an angled shifter? Thanks, Here is what I could find of a already assembled shifter. It comes as a kit some partsAre used from the stock shifter. It is available angledhttp://i179.photobucket.com/albums/w316/conquest232/b1ad58e3.jpg Quote Link to comment Share on other sites More sharing options...
383chevelle Posted December 5, 2013 Report Share Posted December 5, 2013 I vote for the angled version!! Quote Link to comment Share on other sites More sharing options...
quikconq Posted December 5, 2013 Author Report Share Posted December 5, 2013 Put me down for one suspension bushing kit, motor mounts, and a pair of hub bolts. The "free shipping" is limited to the lower 48states. But will discount the flat rate off of the total shipping to you,,,,so whatever shippingIs to you minus $13.00ish for the standard flat rate. Quote Link to comment Share on other sites More sharing options...
STARION_NORTH Posted December 5, 2013 Report Share Posted December 5, 2013 I understand about the shipping costs, I am still in. Quote Link to comment Share on other sites More sharing options...
Scotty Dont Posted December 6, 2013 Report Share Posted December 6, 2013 Payment sent Quote Link to comment Share on other sites More sharing options...
kidjc Posted December 6, 2013 Report Share Posted December 6, 2013 (edited) Brian... hey dude... pretty sure it was a 17 degree angle on the shifter if that matters to anyone/helps. (definitely the angled version, smoother) Edited December 6, 2013 by kidjc Quote Link to comment Share on other sites More sharing options...
Malykaii Posted December 6, 2013 Report Share Posted December 6, 2013 Brian... hey dude... pretty sure it was a 17 degree angle on the shifter if that matters to anyone/helps. (definitely the angled version, smoother) Helps me plenty... now is there any way someone can tell me the length of the shifter from the base plate? I want to put this into my montero... problem is the seat is much higher than in a quest.. and I have a 2inch body lift putting the tranny 2 inches lower/further away. Any way I can get the shifter raw without the threading and as much metal on the end as possible? If not I'll have a welder lengthen it. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted December 6, 2013 Report Share Posted December 6, 2013 Great then put me down for a Short ANGLED Shifter and one Bushing. Thanks, Short ANGLED Shifter Bushing Quote Link to comment Share on other sites More sharing options...
quikconq Posted December 6, 2013 Author Report Share Posted December 6, 2013 UPDATE:::::: the molds have been shipped expected delivery is on the 11th. Would have ordered the urethane today but the "urethane people" didn't call meBack till this afternoon. I do have the products in mind. And have to setup an account. Should have it ordered on Monday. Delivery date on that isn't clear,,but I'm sure ill have some ideaOn Monday when I make the order. Quote Link to comment Share on other sites More sharing options...
Starion86ESI Posted December 7, 2013 Report Share Posted December 7, 2013 (edited) UPDATE:::::: the molds have been shipped expected delivery is on the 11th.Would have ordered the urethane today but the "urethane people" didn't call meBack till this afternoon. I do have the products in mind. And have to setup an account.Should have it ordered on Monday. Delivery date on that isn't clear,,but I'm sure ill have some ideaOn Monday when I make the order. What color will the eurathane be? Are there options? Because I like the red non-OEM look haha. If i go through the trouble of replacing the bushes I want that to be somewhat visible. Because I know much more time will be spent under this car haha. Also would help in the resale in case someone doesn't use them and decides to get rid of them, a different color helps set them apart from black. But if its black i will make do. Also fully paid up. Edited December 7, 2013 by Starion86ESI Quote Link to comment Share on other sites More sharing options...
quikconq Posted December 7, 2013 Author Report Share Posted December 7, 2013 What color will the eurathane be? Are there options? Because I like the red non-OEM look haha. If i go through the trouble of replacing the bushes I want that to be somewhat visible. Because I know much more time will be spent under this car haha. Also would help in the resale in case someone doesn't use them and decides to get rid of them, a different color helps set them apart from black. But if its black i will make do. Also fully paid up. Very good points. And I have been thinking in the same lines of you. Here is the issue,,not a very big issue but an issue nonetheless, the metal platesOf the mounts have to be painted and normally painted black. That is why I think that black works best. The urethane can be cleaned/taped off,,if say" the platesAre paint black and the urethane is red. This is what I was thinking,,running the 85 durometer in red and 75-70 durometer in black. The 75-70 durometer being closer to a stock "feel and look" Not sure on durometer selection yet,,, 95duro being rock hard stuff. 85 being the normal Stedebani flavor. I know I'm buying 85 durometer As for a color change unsure if that is a wise choice "so late in the game"Maybe we can get some feedback on what members think. Also there probably is an extra charge for different colors. Not positive on thatAs if I remember right "urethane" is naturally creamy white color. And the colorIs added. Not 100% on that,but if memory serves me correctly. Quote Link to comment Share on other sites More sharing options...
Starion86ESI Posted December 7, 2013 Report Share Posted December 7, 2013 So was 95 ever produced? I personally don't care about them being soft. I prefer stiffer. Quote Link to comment Share on other sites More sharing options...
KIDMEN Posted December 7, 2013 Report Share Posted December 7, 2013 I vote red. i will pay a little extra for red it will match the other red stuff on my suspension. Quote Link to comment Share on other sites More sharing options...
psu_Crash Posted December 7, 2013 Report Share Posted December 7, 2013 (edited) Count me in for suspension bushings 100% Payment Sent! Edited December 7, 2013 by psu_Crash Quote Link to comment Share on other sites More sharing options...
Turbo Cary Posted December 8, 2013 Report Share Posted December 8, 2013 Color does not matter so much to me as does rigidity and longevity. But if you could color them, I'm fond of the green Tien uses 1 Quote Link to comment Share on other sites More sharing options...
importwarrior Posted December 8, 2013 Report Share Posted December 8, 2013 Payment sent.in full.please let me know ETA when ya get them done. Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted December 10, 2013 Report Share Posted December 10, 2013 Sent payment minus shipping fee. Quote Link to comment Share on other sites More sharing options...
quikconq Posted December 10, 2013 Author Report Share Posted December 10, 2013 (edited) Sent payment minus shipping fee. Huh,,, not sure what you mean minus shipping fees?? That made me chuckle a little. Hehe Diff mounts ,109.00TT mounts,,, 39.00PayPal 3%,,,,,,,4.44Total is,,,,,,,,,152.44 No shipping fee if paid before the 13th. EDIT::::: all is good,,,, just the wording "minus shipping" thru me for a loop. Edited December 10, 2013 by quikconq Quote Link to comment Share on other sites More sharing options...
BuGG Posted December 10, 2013 Report Share Posted December 10, 2013 Payment sent. Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted December 11, 2013 Report Share Posted December 11, 2013 Huh,,, not sure what you mean minus shipping fees??That made me chuckle a little. Hehe Diff mounts ,109.00TT mounts,,, 39.00PayPal 3%,,,,,,,4.44Total is,,,,,,,,,152.44 No shipping fee if paid before the 13th. EDIT::::: all is good,,,, just the wording "minus shipping" thru me for a loop.LOL sorry man. It's all good, I didn't notice the no ship fee on the previous page. Quote Link to comment Share on other sites More sharing options...
STARION_NORTH Posted December 11, 2013 Report Share Posted December 11, 2013 I need a total including the extra shipping costs to Canada so I can pay up. Postal code is N1G5A4 Quote Link to comment Share on other sites More sharing options...
