patra_is_here Posted July 12, 2013 Report Share Posted July 12, 2013 http://www.starquestclub.com/forum/index.php?showtopic=137515 READ ALL OF IT BEFORE POSTING it's mostly me trying to help but IDK seems like a lost cause. Hope I'm giving him the right info. Link to comment Share on other sites More sharing options...
wolfsquest Posted July 12, 2013 Report Share Posted July 12, 2013 Seems right to me, a 17 y.o. wantin' something fixed almost by remote-control! Your advice an conclusions seem on the money to me, also, his apparent lack of patience!! Link to comment Share on other sites More sharing options...
StarquestRescue Posted July 13, 2013 Report Share Posted July 13, 2013 Your advice is sound. A replacement 87 harness would probably fix the car, IF there is nothing else major wrong. But i would not really consider a engine harness replacement newbee stuff. But replacing harnesses is easier than fixing wiring for most people. His car likely has a 1 gm mas. 7 pins in a 8 cavity plug. Probably has a 88-89 igniter wired in as well. I wonder if it ran before the afc was removed? Link to comment Share on other sites More sharing options...
jszucs Posted July 13, 2013 Report Share Posted July 13, 2013 Nor if he doesn't have the patience is a harness swap up his ally. Wireing is the most trying slow painstaking process. Link to comment Share on other sites More sharing options...
MIDNIGHT.EMPIRE.CONQUEST87 Posted July 13, 2013 Report Share Posted July 13, 2013 rescue^ it did not run before I removed safc I put new fuel pump new fuel lines fuel filter injectors injector clips and new computer and it didn't run but I just stripped the harness and found broken wires so im going to fix it the correct way. and thank you all for the help im so glad I have someone to ask for help. im new to fuel injection so it is annoying trying to help me I know but I do listen and try all sugestions. and jw do I have to take the dash out to re install harness? Link to comment Share on other sites More sharing options...
Shelby Posted July 13, 2013 Report Share Posted July 13, 2013 repairing 4 or even 6 wires is much easier then replaceing a harness whith who knows how many repairs it may needwireing repair may not be every ones fota but it's not rocket science eather Link to comment Share on other sites More sharing options...
MIDNIGHT.EMPIRE.CONQUEST87 Posted July 13, 2013 Report Share Posted July 13, 2013 well actually I need about 200 wire connectors no exadaration its gona take all day but I can do it. its been cut completely in 4 spots Link to comment Share on other sites More sharing options...
StarquestRescue Posted July 13, 2013 Report Share Posted July 13, 2013 To replace a harness, the blower box for the hvac under the dash needs to be removed. It also snakes back behind the relays and main harness besides the battery. Link to comment Share on other sites More sharing options...
jszucs Posted July 13, 2013 Report Share Posted July 13, 2013 Will just depend on how much u have to replace. If just the sensors through pass fender then u could get away with just removing blower ect. Btw while were on the topic. I assumé that side also had the wires to the wiper motor? Trying to go legit myself stupid laws Rewireing like said is not super complex in most cases just allot and time consuming. Go slow make good conections so no future problems. You should see the wires in a pinball machine if u think a car is bad Link to comment Share on other sites More sharing options...
BC_99 Posted July 13, 2013 Report Share Posted July 13, 2013 well actually I need about 200 wire connectors no exadaration its gona take all day but I can do it. its been cut completely in 4 spots I have the entire harness from my 89 partout. It sounds like you could use it or at least some of it. PM me if you want/need it, and we can discuss getting it to you quickly and cheaply. BC_99 Link to comment Share on other sites More sharing options...
patra_is_here Posted July 13, 2013 Author Report Share Posted July 13, 2013 200 connectors? really, figure out what it actually needs. there's not even 200 wires in the entire ECU harness to begin with. there' maybe 50 wires that control the engine. Link to comment Share on other sites More sharing options...
Shelby Posted July 13, 2013 Report Share Posted July 13, 2013 ok theres a very detailed how to remove a fuel system harness in the FAQ ,now heres a bit of advice never cut a harness into , and then take it for granted all wires have a diff color code , they do NOT ,mits used the same color wire many times but each go to a diff location a newbie can replace the entire harness with in a couple hours,, after all all connectors only go one place if you pay attention to detail , removeing and replaceing the blower motor is the hardest part, and if you cut off the odd stud mount even that ain't so bad if you not real experianced at doing harness repairs all you'l do is make twice as many problem areas as you had before Link to comment Share on other sites More sharing options...
MIDNIGHT.EMPIRE.CONQUEST87 Posted July 14, 2013 Report Share Posted July 14, 2013 i know there isn't a lot of wires but it was cut completely in half in 4 places. Link to comment Share on other sites More sharing options...
patra_is_here Posted July 14, 2013 Author Report Share Posted July 14, 2013 i know there isn't a lot of wires but it was cut completely in half in 4 places. oh damn hahaha that's pretty bad. how the heck did that happen? Link to comment Share on other sites More sharing options...
Shelby Posted July 15, 2013 Report Share Posted July 15, 2013 i know there isn't a lot of wires but it was cut completely in half in 4 places. for the average mechanic this woiuld not be a big deal but from the way you worded your posts it's some thing you'l never be able to do , the car never drove or ran from the time the harness was cut so it wasn't done some time in the distant past Link to comment Share on other sites More sharing options...
JohnnyWadd Posted July 15, 2013 Report Share Posted July 15, 2013 He needs a full harness, I saw the pics of his old one. He needs connectors, and a few days of using a multimeter and soldering stuff together at the least. Link to comment Share on other sites More sharing options...
patra_is_here Posted July 15, 2013 Author Report Share Posted July 15, 2013 pics on facebook? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted July 15, 2013 Report Share Posted July 15, 2013 pics on facebook? ya he sent me some, he bought a harness from me. long story. this ain't face book and to be honest i'm geting tired of hearing the words face book , nothing against you or the OP, people as a whole are not ready for such a thing Facebook is here. Wether its here to stay or not or its merits can be debated, but as with all things in life it is what you make of it. I actually met some starion/conquest guys on there and have good relationships with them. Fixed a guys starion in my driveway tonight and posted the pics on facebook. We had a group bike ride the other day and someone Magna broke down in my town so I went out and met the other guy and gave him a jump. Its not all reposts about cats you know Link to comment Share on other sites More sharing options...
Fuze Posted July 15, 2013 Report Share Posted July 15, 2013 this ain't face book and to be honest i'm geting tired of hearing the words face book , nothing against you or the OP, people as a whole are not ready for such a thing Maybe we should just delete all the comments that mention FB? Heh heh heh Hey it is what it is, you make it sound personal. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted July 15, 2013 Report Share Posted July 15, 2013 The way I hear it works both ways, baby daddies old flames find them on facebook in the first place. Facebook drama Link to comment Share on other sites More sharing options...
Bottomout Posted July 15, 2013 Report Share Posted July 15, 2013 He should probably stick to his bicylce.... Link to comment Share on other sites More sharing options...
patra_is_here Posted July 15, 2013 Author Report Share Posted July 15, 2013 while FB lacks some things, it makes it easier to share images since there's no need for an external host and everything gets resized automatically. but it definitely doesn't match the ease of use of a standard forum like this one, with it's dedicated forums and threads. Link to comment Share on other sites More sharing options...
SeanTheConquistador Posted July 16, 2013 Report Share Posted July 16, 2013 i am sorry as i am assuming this is the wrong place to be posting this, but i have a problem with my conquest and i am a newbie myself bing 17, i cant seem to get my turbo out due to a bolt just in the perfect place to be impossible to get. but could someone message me explaining how to make a topic or find what i am looking for? thanks alot guys. Link to comment Share on other sites More sharing options...
Fuze Posted July 16, 2013 Report Share Posted July 16, 2013 i am sorry as i am assuming this is the wrong place to be posting this, but i have a problem with my conquest and i am a newbie myself bing 17, i cant seem to get my turbo out due to a bolt just in the perfect place to be impossible to get. but could someone message me explaining how to make a topic or find what i am looking for? thanks alot guys. Not sure what else to tell you except try some PB blaster, or use a torch to heat it up. Shouldn't bee too hard. If you can't reach it, you can take out the single bolt that holds the band around the middle of the turbo, seperate the compressor from the exhaust housing (tap it with a rubber mallet), and make some more room to work. Link to comment Share on other sites More sharing options...
jszucs Posted July 16, 2013 Report Share Posted July 16, 2013 i am sorry as i am assuming this is the wrong place to be posting this, but i have a problem with my conquest and i am a newbie myself bing 17, i cant seem to get my turbo out due to a bolt just in the perfect place to be impossible to get. but could someone message me explaining how to make a topic or find what i am looking for? thanks alot guys. Going to have to buy a tool that will get at it. Get yourself in a funky spot / back breaking way (come on your young still you can do it easy) apply heat, penatrant (not togethe obviously) and really just get at it. If something like that is holding you up.... this is NOT going to be the car for you. Sell it and buy a honda. These cars will not take to neglect well at all, parts are hard to come by, and there is no one that will really work on it but you. Link to comment Share on other sites More sharing options...
