MIDNIGHT.EMPIRE.CONQUEST87
Everything posted by MIDNIGHT.EMPIRE.CONQUEST87
I got a cam from him very fast! thanks for the help getting another one back on the road
when car is under accelaration it getts flooded very bad.? i have 650cc and 1150cc injectors i think they are to big when i go down the road in gear it leaks gas out my exaust and floods very bad. i have the origonal injectors will they fix this problem? it used to have a safc2 on it but was wired ugly so i removed it. mabie has something to do with it?gona change oil and try ur guyses suggestions. and if its easer message me on facebook. beastyboy199@yahoo.com joseph hoonigan pickett.
87 conquest project part out
MIDNIGHT.EMPIRE.CONQUEST87 replied to i2tall4abike's topic in Parts for sale
are u selling the engine wiring harness. the one that hooks to the cpu? and the cpu? -
rescue^ it did not run before I removed safc I put new fuel pump new fuel lines fuel filter injectors injector clips and new computer and it didn't run but I just stripped the harness and found broken wires so im going to fix it the correct way. and thank you all for the help im so glad I have someone to ask for help. im new to fuel injection so it is annoying trying to help me I know but I do listen and try all sugestions. and jw do I have to take the dash out to re install harness?
im not sure if the computer is bad either. I bought a 88 computer and it still didn't work. and the mass air flow sensor but I think its different because the harness has 6 wires and the plug wired into the mass air flow sensor has 7 wires. and the wiring harness I want is all original just so u know. I don't know if its the ecm or a sensor somewhere.
yes it has a md109 knock senson and the wiring harness is pulled apart but a guy on here is selling one with the knock sensor and the relay I think I should buy it will make my life easer than trying to go and take the whole harness apart. and it has a mass air flow sensor but it don't go to the car and its wired wrong.
I think I got them all hooked up right I just don't know what sensor is bad causing my fuel injectors to not get any ground. if u guys know what sensors control fuel injection ground please tell me ill do anything to test it or scrounge up money to buy a new one. I need to get my car running soon so I can get it tittled. thanks
will u do any type of trade or mabie lower price a bit I have a bad harness and there impossible to come by. plz message me back.
- injector resistor
- injection harness
(and 2 more)
Tagged with:
ok thanks and no still no ground and someone has messed with the harness coming out the top of the ecu so idk if its rite or not it had a super airflow converter on it but I took it off he had wires cut everywere I hooked them back up but idk there is a odd big brown wire with a whit wire inside of it and idk ?
heyy im indy just wondiring if u can help me with my 1987 conquest
