nextgenquest Posted May 28, 2013 Report Share Posted May 28, 2013 Just got done replacing some bad valve seals and put 100lb valve springs. Installed the head made sure everything was at tdc, double checked connections and the car isnt getting spark now. Any ideas? Link to comment Share on other sites More sharing options...
SnohoQuest Posted May 29, 2013 Report Share Posted May 29, 2013 Correct grounds and power routed on you coil?? Also double check that plug wires are seated all the way. I just replaced a dead coil because i had no spark so theres a few things to think of. Hope it helps! Link to comment Share on other sites More sharing options...
techboy Posted May 29, 2013 Report Share Posted May 29, 2013 (edited) There's a small wire coming off the bottom of the coil that leads to white plastic clip and then to a ground. If that comes unplugged, or ringlet breaks off the ground, it won't start. I had this once when I was replacing the battery. Baffled me for a whole afternoon. Check that. Edited May 29, 2013 by techboy Link to comment Share on other sites More sharing options...
nextgenquest Posted May 29, 2013 Author Report Share Posted May 29, 2013 I Checked the obvious grounds but ill have to check grounds again and the grounds for the coil. Thanks for the suggestions! Link to comment Share on other sites More sharing options...
nextgenquest Posted May 29, 2013 Author Report Share Posted May 29, 2013 Triple checked everything this morning and all grounds are good but stil no start Link to comment Share on other sites More sharing options...
vbrad511 Posted May 29, 2013 Report Share Posted May 29, 2013 Go back over everything you touched. Wiggle the fusible links too. What year is it? Link to comment Share on other sites More sharing options...
JAinsworth Posted May 29, 2013 Report Share Posted May 29, 2013 Does it turn over but not start or not turn over? If it doesn't turn over check the small wire on top of the starter. If it turns over but won't start, does the tach bounce as the starter turns over? If not, your problem is there. If the tach bounces but it won't start, check the fusible links There are more things to check, just post back on what you find. Jimmy Link to comment Share on other sites More sharing options...
nextgenquest Posted May 30, 2013 Author Report Share Posted May 30, 2013 Its a 89 and it turns over but doesn't start and the tach does bounce when trying to start. Link to comment Share on other sites More sharing options...
averse Posted May 30, 2013 Report Share Posted May 30, 2013 (edited) Unplug the coil wire between the coil and the distributor (at the distributor end), then with your hood propped up you should be able to hang the wire over the side of the car (so the end rests about an inch or so from the fender/frame) where you can see it from the driver's seat and crank the engine. You are checking to see if you are getting spark there, (the end of the coil should spark from the coil wire to the frame/fender, easier to see at twilight/night/in shade) as that will tell you if your spark is at least making it to the distributor. If it is, then next is checking the dizzy or spark plugs and cables. If not, then your problem is at the coil or sooner. Feel free to correct me anyone else if I misspoke. Edited May 30, 2013 by averse Link to comment Share on other sites More sharing options...
Caliber308 Posted May 30, 2013 Report Share Posted May 30, 2013 (edited) A inline Spark checker is in order!!!Pull a Spark Plug and check to see if it is fuel soaked. If so,dry it off with a heat torch or lighter, ground it to the Engine Block and turn the engine over. Do you have spark? If so, you have spark. If you see no fuel on the Spark Plug but have Spark, Check the Fuel Pump, Fuel Filters and Fuel Injectors for flow.Disconnect Throttle body coupler and crank the engine, see fuel? if not,Check the Fuel inlet at the Throttle Body and crank the engine over. Do you have fuel? If not, your going to have to check the Main Fuel Filter under the hood. Still no fuel, check the Fuel Pump outlet for flow. No fuel coming into the Fuel Pump, check your in-tank Fuel Filter. If all my suggestions fail, Go here: Engine will not start: Incorrect ignition timing:Adjust Timing.Ignition coil faulty:Inspect Ignition Coil.Igniter faulty:Inspect Igniter.Distributor faulty:Inspect Distributor.High tension cord faulty:Check Spark plug wires Spark plugs faulty:Inspect and Clean Spark plugsIgnition wiring disconnected or broken:Inspect Wiring. Also:No Fuel supply.Injection problems.Vacuum leaks.Low compression. Download the Factory Service Manual here: http://www.starquestgarage.com Then you would know what you need to check when your car won't start. Bill Edited May 30, 2013 by Caliber308 Link to comment Share on other sites More sharing options...
nextgenquest Posted May 31, 2013 Author Report Share Posted May 31, 2013 I appreciate all the help and suggestions. Checked a few things today with no found problems. Still have to check a few things just wanted to get some ideas. I do have a 89 service manual. First thing I bought and I have read it and go back to it for help when needed. Thanks all! Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted June 1, 2013 Report Share Posted June 1, 2013 hey I just got the same problem. it turns over, no spark at the plugs but intermittent spark at dizzy, no consistent power to coil. But I have a blaster 2 with the 8214 ballast resistor installed and I read http://www.starquestclub.com/forum/index.php?showtopic=111000&hl=+blaster%20+coil%20+problem&do=findComment&comment=1079638 and the resistor isn't necessary and can cause problems Link to comment Share on other sites More sharing options...
speed racer Posted June 1, 2013 Report Share Posted June 1, 2013 make sure you don't have a broken wire to either + or - side of coil.i discovered that yday luckily after checking everything.Te blue wire with white stripe had a bad connection to the eyelet I used to replace the original.it would run ok sometimes then wouldn't start at all....lots of weird problems.Is why my problem went from intermitant to all te time and no start at all.finally he wire broke.it's too short to reach coil now so gonna extend a bit so it doesn't get pulled loose again.just sayin don't forget to check the easy stuff first before assuming it's something complicated.happens often. Link to comment Share on other sites More sharing options...
