16
Everything posted by JAinsworth
http://www.starquestgarage.com/manuals/service/conquest/1986/86_conquest_service_nav.html
Yep
Britt, I've been thinking of you and wondering what you would do once the team shut down. Best of luck with the powder coating and finding another job. If there is anything I can do, let me know. Jimmy
Thanks all. I had a good b'day, just taking it easy and doing what I wanted to. Jimmy
Great to hear it. Put the cigs down and breathe again.
Cams Forum moved to the Modifications forum
JAinsworth replied to JAinsworth's topic in Just plain ol' B.S.
I changed the permissions. For those interested, see if you can see it/post there and let me know. Jimmy -
Try it now. I have changed the permissions. Jimmy
My bad. I moved it to the Modifications forum. Jimmy -
There has been interest in adding a forum for Cams. It has been added to the FAQs and How To's Forum. Please let me know of any issues with it. Jimmy
It has been added to the FAQs and How To forums. Jimmy
terd got terd...um i mean FIRST ! - wait what ?
JAinsworth replied to IntercooledFlatty's topic in Just plain ol' B.S.
What placed first and second? Jimmy -
Unfortunately, there is little you can do. If you still owe them money, tell them you can't afford to pay it. They will ask you how much can you afford; tell them 5 dollars a month is all you can spare. You can drag it out for years and in the end the admin costs for them outweighs your payments. Small satisfaction but you can make them lose money in the long run by doing this.
Post your route, there are a lot of starquesters that could help you out if you run into trouble.
Make sure your tires are straight also.
Be sure to re-grease the wheel bearings.
Thanks. I ordered the one John recommended. Jimmy
I'm looking into a sound bar for my TV and need recommendations. Jimmy
Have a good one!
A/C relays by Mike C The A/C system has a whole slew of relays... those relays on the black metal bracket next to the ignition coil. One relay for the compressor. (Green+white, Yellow+white, Black+white, and blue+red wires) One relay trips the larger (primary) radiator fan. (green+white, black, black, blue+white wires) One relay trips the smaller (secondary) radiator fan. (green+white, black, black, and white wires) Those three relays are driven together/simultaineously by the A/C computer. The green+white wire is the +12volt ON signal from the A/C computer, the smaller black wires are the grounds. The yellow+white wire on the compressor clutch goes to the overheat temp sensor (top of thermostat housing, it's the smaller temp sensor) to get grounded. Another relay (blue+black, black+yellow, black, blue+yellow) trips the front pusher fan if/when the A/C is ON and the refrigerant pressure gets rather high... i.e. hot days. Note these a/c relays are totally different from the relays that the cooling system temp sensors drive (those are the relays underneath the air filter box). So each engine-side fan has two different relays that can run it: the A/C relay OR the cooling system relay. mike c.
From MikeC A/C diagnostic connector is a small 2-wire connector hanging under the dash. Generally it's taped to the wiring harness behind the stereo: * Remove the passenger side "knee panel" (under-dash panel); don't bust the sensor clipped to this panel. * Remove the carpet/trim panel on the side of the stereo console. Look at the back corner area of that carpet/trim panel for a couple 2-wire connectors - one goes to the sensor on the knee panel; next to is the diagnostic port. It'll have green and black wires. The glove box connector (where the ECU diagnostic port is) also has a pin for the a/c: PPkkPPP PPPPPGP "P" is a spot for a pin - may or may not be used, "k" are the two empty spots that "key" the connector, and "G" is the green diagnostic wire. Typical a/c problems: * on the thermostat housing there is a small temp on/off switch; this sensor should read 0 ohms to ground on a cold or warm engine. On an overheating engine it'll read infinite ohms. This sensor fails regularly (infinite ohms) killing the compressor. You can just ground the wire going to it as a test - a yellow+white wire. * Dual pressure switch - one of the sensors in the refrigerant lines near the receiver/dryer. This thing senses too little refrigerant pressure before letting the compressor run (if the "resting" refrigerant pressure is too low the won't be any oil for the compressor; this switch prevents the compressor from running in that condition). It also senses too much pressure and kills the compressor before a/c hoses explode. It's rare for this switch to fail, you can unplug the connector and jumper the wiring harness though to simulate a normal sensor: green+yellow and green+white wires. * Inside the evaporator box (under-dash box that actually cools the air) is a temp sensor that the a/c computer uses to prevent freeze-ups. If this sensor reads too much resistance, the computer thinks the air is colder than it really is and the compressor gets turned off. Look for yellow+blue and red+green wires (coming from the big black plastic box; the connector will be near the diagnostic connector actually), unplug the connector. Using an ohmmeter, measure the sensor resistance: it should read about 1000 ohms on an 86 degree day; about 5000 ohms on a 50 degree day. If the resistance is above 5000 ohms the a/c computer will be thinking "very cold air, don't need the compressor." Have you looked for error codes from the a/c computer - it's in a 2-pin connector in the wire bundle near the stereo & passenger knee panel. It's often confused for the knee panel temp sensor connector by the way; it should have a green and a black wire. If the a/c computer is "happy" you'll have a constantly flashing/blinking 12volts-0volts-12volts cycle. Otherwise it'll spit codes. I'd also put a voltmeter on the a/c condensor relay coil wires and see if the computer is trying to turn it on at all... lately I've seen a couple that only spit out 3 volts or so... rather than 12. Bad a/c ECU. Otherwise you've already covered the usual suspects. The a/c ECU, relay, and fuse #7 are about all that is left. A/C compressor is affected by a couple thermoswitches and the pressure switches: * the small 1-prong thermoswitch on the thermostat housing itself is the GROUND for the compressor relay. This temp sensor often goes bad. Easy test: disconnect the wire going to it and ground the wire instead. If the compressor runs properly, the sensor is shot. It's supposed to be an on/off switch - not a variable resistance sensor like the sensor feeding the dash temp gauge. On an engine that is NOT overheating, the sensor prong is shorted to ground (so the compressor relay and compressor work normally). On an overheating engine, the sensor "opens" killing the a/c compressor. Usually this sensor rots internally and NEVER completes the ground (often you can rotate the connector tang when this happens) so the a/c compressor never turns ON at all. A rapidly cycling compressor usually isn't caused by this switch - that'd be a funky failure mode for this switch/sensor. * teeny thermosensor wedged against the evaporator underneath the dash. The a/c computer uses this sensor to monitor the refrigerated air temps; mostly making sure it doesn't get cold enough to start ice formation. Also, when the a/c system is working correctly on AUTO, you'll notice the fan doesn't run at full speed until the air gets cold... this temp sensor feeds the a/c computer that info. To replace this sensor, you have to drain the a/c refrigerant and remove the evaporator box from underneath the dash... not fun. It's resistance CAN be checked though easily; it's a simple two-wire connector coming from the evap box. Unplug the connector and stick an ohmmeter on it. An overcharged system will result in too-cold air temps causing the computer to cycle the compressor more often. * refrigerant "dual pressure switch" that kills the compressor if the refrigerant pressure is too low (no refrigerant or most has leaked out) or too high (about to burst the a/c hoses because of too much refrigerant, problems with the fans on the front of the car, front radiators blocked with dirt/leaves, etc). Typical dash vent temps (center vents) are around 50 to 54 degrees on a working R134a converted StarQuest a/c. mike c.
Who has owned their Starquest (continuously) the longest?
JAinsworth replied to Austin88ESiR's topic in Just plain ol' B.S.
lol, not a whole lot of babying it for Ken. Just great maintenance. Jimmy -
You had the go pro....post your stuff up...you are asking for everyone else to post but you are not contributing. Come on Curt..man up. Jimmy
General
Check the connector that leads to the fusible links. The plastic ignitor on the 87s are known for going bad. Try gently tapping on it. (Long shot) Jimmy
Going to PF ? ...are you ready ?
I have the FSM for all years if somebody needs one. If I don't hear from anybody, I'll be leaving them at home. Jimmy
