CR125 options advance auto or autozone
i have been trouble shooting dropping signal for 2 months, swapped ecus 3x...(sorry Scott) and it all boils down to get your CR125 from autozone!!!! do not have advance auto cross reference it............it wont work! unless all you want to do is idle....... it drops of about 1k rpm..... just thought i would share... i spent 300 chasing down a 35 dollar problem..... <_< its just my luck..... Edited by wrngwae
not sure why i was thinking this:http://www.bikez.com/pictures/honda/2007/24191_0_1_2_cr%20125%20r_Image%20credits%20-%20Honda.jpg
Same here Tyler. I hate advance auto. They on a consistant basis sell me the incorrect part, I just get frustrated everytime I walk in the store.
haha you silly boys,,,,,,,,its an ignition module for MegaSquirt.........lol .......RIDE RED!!!! i did for YEARS!!!!!!!!
http://www.autozone.com/autozone/parts/Ignition-Control-Module/_/N-9n80t?filterByKeyWord=cr125&fromString=search&isSearchByPartNumber=true
http://shop.advancea...GRPTUNEAMS_____
SUPPOSED to be the same,,,,,, but it is not! i cannot verify any other stores like Napa,O'Reilly ect,,,, but Advance auto is wrong.
OEM part # MD607478
if you run this, the way i understand. you dont need to run a msd8910. the 8910 boosts the signal for megasquirt to read it easily.
Edited by wrngwae
What ignition setup are you running? Generic wheel, or distrib?
I am curious, I am about to switch to a generic wheel setup and get rid of the edis module. I have been having issues since I switched to the to me ms v3 board.
Shawn
now you have to lock the weights and the vac advance.
http://www.fuelinjectionpro.com/Dist_mod/index.album/dist1?i=0
or
http://www.ilostmymind.com/distributor/
there are some debate on which is better......... i cut nothing myself.
Yeah, I checked two of his modules, both would work up to around 1000 rpm and then drop the signal to about 3000 rpm where they picked back up and were good to higher than these motors will go. Really odd but not anything you want to mess with. Stay away, only buy the Autozone online module.
Thanks Scott. i thought i was crazy when i figured this our now you have just verified it.......and that im crazy too lol
  • 9 years later...
Looking down at the module in the distributor with the module at the 12 O'clock position the left terminal is the VR+ and the right the VR- on the OEM VR pickup.  For the CR125 you run +12V to the left terminal and the right terminal is the pickup, for it to work correctly you need to add a 1K resistor between the terminals, that acts as a 12V pull up to give a 12V square wave signal to the ECU.
