Contsi Posted September 5, 2023 Report Share Posted September 5, 2023 87 Quest ~ 70K miles. The engine has some oil seeping (was told it killed my alternator) I called it seepage because I may have some drips here and there on the floor, not a puddle. I notice some towards the back of the valve cover, how big of a job to replace the gasket? I see some on the front of the engine on top of the head gasket right where it sticks out between the head and the block, can't tell if it's seeping there or coming through the valve cover gasket and puddling there. Oil pan and front of transmission are also oil wet, not sure if caused by above gaskets or oil pan gasket. All gaskets are original and probably needs replacing anyway, though replacing head gasket (if needed) would be challenging for me. Any thoughts would be appreciated. Thanks Link to comment Share on other sites More sharing options...
techboy Posted September 6, 2023 Report Share Posted September 6, 2023 I would start by replacing the valve cover gasket and the half-moon on the back of the head. The VC gasket is pretty straight forward and you should be able to do that without too much trouble. The valve cover itself is only held on by the 2 large bolts in the middle of the cover. DO NOT over tighten them when you put the cover back down or you will crack it. Also, get a can of CRC brake clean and try to clean up all the residue oil in the places you are describing above. Then, monitor things from there. If you continue to see oil you know you have additional gaskets that are old and tired. If so, go to the oil pan gasket next. This one is also not too difficult to replace, however (a little hint) I find it MUCH easier to remove the pan if you undo the sway bar links so you can drop the sway bar out of the way. That way the pan can drop far enough to aviod the pickup tube. Link to comment Share on other sites More sharing options...
Contsi Posted September 6, 2023 Author Report Share Posted September 6, 2023 Thank you much techboy I haven’t searched yet so I’ll ask here first; Is there a known seller carrying the valve cover gasket and half moon? Dad? I think he’s back online. Link to comment Share on other sites More sharing options...
Dad Posted September 6, 2023 Report Share Posted September 6, 2023 I'm back! https://www.enginemachineservice.com/ems/conquest.php Clean all oil off cover, put a small amount of rtv in the cover groove, Put cover gasket in cover, put small amount of rtv at half moon seal and around rear cam cap, install cover and tighten alternating between bolts torque is 4 to 5 foot lbs. Let it set a bit before starting Dad Link to comment Share on other sites More sharing options...
Contsi Posted September 6, 2023 Author Report Share Posted September 6, 2023 Thank you Dad! Order placed Link to comment Share on other sites More sharing options...
TexasQuest Posted September 6, 2023 Report Share Posted September 6, 2023 A word from the wise, the rear cam bore plug gasket does not come in the valve cover gasket set. It is sold separately. 1987 CHRYSLER CONQUEST 2.6L 156cid L4 Turbocharged Camshaft Plug | RockAuto Link to comment Share on other sites More sharing options...
techboy Posted September 6, 2023 Report Share Posted September 6, 2023 Good catch Tex!! 1 Link to comment Share on other sites More sharing options...
Turbo Cary Posted September 7, 2023 Report Share Posted September 7, 2023 When installing the rear cam plug be sure to give it a good coating of RTV. I prefer using Three Bond 1217H RTV. We use it on GM vehicles where I work. Good stuff and very oil resistant. 1 Link to comment Share on other sites More sharing options...
Contsi Posted September 7, 2023 Author Report Share Posted September 7, 2023 Thanks guys…… good info I thought that was the semi circular plug in the gasket kit. I will order from RockAuto as advised. Link to comment Share on other sites More sharing options...
TexasQuest Posted September 7, 2023 Report Share Posted September 7, 2023 8 hours ago, Contsis said: Thanks guys…… good info I thought that was the semi circular plug in the gasket kit. I will order from RockAuto as advised. The front semi-circular or "half moon" comes in the valve cover kit, just not the rear cam bore plug gasket for some strange reason... Link to comment Share on other sites More sharing options...
Contsi Posted September 7, 2023 Author Report Share Posted September 7, 2023 Strange indeed……..maybe they figured you don’t have to replace it idk this my first time taking the valve cover off. I ordered from RockAuto already 1 Link to comment Share on other sites More sharing options...
techboy Posted September 8, 2023 Report Share Posted September 8, 2023 That plug is notorious for leaking on these cars. If you get a small mirror and hold it by the firewall you can see the condition of yours. It's really hard to get a visual on otherwise. 1 Link to comment Share on other sites More sharing options...
Contsi Posted September 8, 2023 Author Report Share Posted September 8, 2023 I’ll take a look Thanks Link to comment Share on other sites More sharing options...
tux Posted September 21, 2023 Report Share Posted September 21, 2023 A problem left from when these engines had mechanical fuel pumps. Link to comment Share on other sites More sharing options...
Contsi Posted September 21, 2023 Author Report Share Posted September 21, 2023 Wow, really? Before Starquest? What was the setup? Link to comment Share on other sites More sharing options...
tux Posted September 21, 2023 Report Share Posted September 21, 2023 Some Dodge caravans, probably the pickups, maybe Colt Link to comment Share on other sites More sharing options...
TexasQuest Posted September 23, 2023 Report Share Posted September 23, 2023 FWD vehicles using the G54B had a pulley running off the back of the camshaft. Link to comment Share on other sites More sharing options...
Contsi Posted September 23, 2023 Author Report Share Posted September 23, 2023 Ah makes more sense….engine transversely mounted I assume. Link to comment Share on other sites More sharing options...
TexasQuest Posted September 24, 2023 Report Share Posted September 24, 2023 13 hours ago, Contsis said: Ah makes more sense….engine transversely mounted I assume. Correct Link to comment Share on other sites More sharing options...
