- 939 views
- 7 replies
- 848 views
- 400 views
- 11 replies
- 855 views
Evo III 16g. Is a restrictor needed?
By doomviillain,
So when putting my engine together I bought a steel braided turbo oil feed line and it looks like it comes with a restrictor. http://www.ebay.com/...=item20b9412c16 I've been trying to do some research on this matter and cant get a solid answer. Some have said to run a restrictor, some say to run a restrictor if the balance shafts have been eliminated, resulting in higher oil pressure. If I run a restrictor, will a 0.70 be too small? The one I have is just as small as whats pictured if not s
Primary Fan Emergency
By jonboyb,
Long story short, getting car buttoned up to leave for Pigeon Forge Friday and decided to give it a good trial in Atlanta rush hour today and 95 degrees to make sure all was well. Noticed temps were creeping to about 190-195 so flipped my fans on and noticed it wouldn't bring it back to 180 like it has for the past 10 years. Fast forward, got home and parked the car. Popped the hood with my manual fan switch on and only the secondary and AC fans running. For 10 years now, I've had a manual
Stock cam or stock duration roller?
By movin on,
My car: 8:1 wisecos, o-ringed block, hd springs, ARP hardware, 292/280 (stock valves), tdo5h 18g Currently I am trying to decide which cam to choose: stock hydraulic, or send in a stock cam to have it ground to the same powerband of the stocker, but as a roller. I might take the car to the strip a couple of times, but nothing serious. 99% will be the joy in the pants feel of power . I would like to run at least 18lbs on the turbo (maybe low 20s), and am not afraid to rev the motor a bi
has anyone took apart ING switch to fix contacts???
By markhansenconquest,
have 86.... thinking ING switch is bad (no start pulse to injectors... only power to pump when cranking )........philps screw is loose or broken on back of ING switch...have whole steering (tilt) Colum from 87 ....can it work for 86........ or should I just take out switch and put in 86 colum???
