nathan89quest Posted May 30, 2009 Report Share Posted May 30, 2009 (edited) Our stock system it is true dude. Real power you go a form of EDIS. im not sayin a distributor is the best, im just sayin it gets the job done and its simple (no computer or tunning needed) a edis system has some major adantages, ie boost retard for high boost setups. but msd 6462 gives me 15 deg. of retard with a distributor. Edited May 30, 2009 by nathan89quest Link to comment Share on other sites More sharing options...
Minagera Posted May 30, 2009 Report Share Posted May 30, 2009 im not sayin a distributor is the best, im just sayin it gets the job done and its simple (no computer or tunning needed) a edis system has some major adantages, ie boost retard for high boost setups. but msd 6462 gives me 15 deg. of retard with a distributor. I am telling you I have busted two motors on detonation and MPI with just running stock ignition. Been there done that, have the freaking ring lands to prove it. Unless you keep coolant temp, Mass Air, and RPM going to the Stock ECU, your stock dizzy is fecked. Even a modified dizzy with slightly heavier springs is going to screw you. Link to comment Share on other sites More sharing options...
jahjah Posted May 30, 2009 Report Share Posted May 30, 2009 I am telling you I have busted two motors on detonation and MPI with just running stock ignition. Been there done that, have the freaking ring lands to prove it. Unless you keep coolant temp, Mass Air, and RPM going to the Stock ECU, your stock dizzy is fecked. Even a modified dizzy with slightly heavier springs is going to screw you. I ran my MPI setup with the FIP fuel/ignition on a distributor and had zero problems.... are you saying the stock controlled distributor? or any method of using a distributor? Link to comment Share on other sites More sharing options...
Minagera Posted May 30, 2009 Report Share Posted May 30, 2009 I ran my MPI setup with the FIP fuel/ignition on a distributor and had zero problems.... are you saying the stock controlled distributor? or any method of using a distributor? Stock controlled. FIP doesn't could :-P you had ignition control, kinda. Link to comment Share on other sites More sharing options...
Casey_L Posted May 31, 2009 Report Share Posted May 31, 2009 I am not saying there is a big problem with the stock dist. Its just that edis is dirt cheap, incredibly reliable, and will revert to 10* btdc if your megasquirt blows up. Also, a monkey could install eids on one or our cars. Mookeh already made the trigger wheel and pickup sensor bracket for you! 101- Looking good. Keep up the good work Link to comment Share on other sites More sharing options...
soulja620 Posted June 1, 2009 Report Share Posted June 1, 2009 Im in Link to comment Share on other sites More sharing options...
franco101 Posted June 4, 2009 Report Share Posted June 4, 2009 sounds good to me when and how much Link to comment Share on other sites More sharing options...
hdam Posted June 4, 2009 Report Share Posted June 4, 2009 This would be super as a compleete packet with a ecu... ex.. http://wolfems.cart.net.au/details/635751.html Link to comment Share on other sites More sharing options...
thagremlin Posted June 8, 2009 Report Share Posted June 8, 2009 If this kits available before vegas nationals next year I'll most definetly consider it. Link to comment Share on other sites More sharing options...
jjooc Posted June 9, 2009 Report Share Posted June 9, 2009 is this still in the making... Link to comment Share on other sites More sharing options...
D_Venable Posted June 14, 2009 Report Share Posted June 14, 2009 any idea on a price yet for just the manifold? or are you not that far a long This looks very promising Derek Link to comment Share on other sites More sharing options...
rosengrant826 Posted June 16, 2009 Report Share Posted June 16, 2009 any updates ? Link to comment Share on other sites More sharing options...
michael knight Posted June 26, 2009 Report Share Posted June 26, 2009 Looks good 101. Link to comment Share on other sites More sharing options...
Funky Phil Posted June 26, 2009 Report Share Posted June 26, 2009 (edited) my ignition is doing fine..... Hey Mookeeh, you want me to test this thing for you? We can see right off the bat how it does under 30+psi. Engine is gettin O-ringed the minute I get home. Edited June 26, 2009 by phinko Link to comment Share on other sites More sharing options...
yokomo Posted August 3, 2009 Report Share Posted August 3, 2009 id like to make my 4B explode using your intake better excuse to swap somthing new in. Link to comment Share on other sites More sharing options...
BrazilBoy Posted August 3, 2009 Report Share Posted August 3, 2009 My bro SubZero and I may want one each...the interesting bit is his car is bone stock and mine is very modded it would be a good real test I think... Keep us updated.. ~Roberto Link to comment Share on other sites More sharing options...
Dcrasta Posted August 11, 2009 Report Share Posted August 11, 2009 I am telling you I have busted two motors on detonation and MPI with just running stock ignition. Been there done that, have the freaking ring lands to prove it. Unless you keep coolant temp, Mass Air, and RPM going to the Stock ECU, your stock dizzy is fecked. Even a modified dizzy with slightly heavier springs is going to screw you. If you dont have boost retard you will end up with too much timing at high boost levels. Everyone that doesnt know how to figure out how much total timing they are running should stick with stock boost levels / stock fuel system until they learn to read or correct their problem. (notice, not saying 'this was your specific problem' ) but alot of people running the stock distributor (As opposed to a modified/locked distributor and seperate timing control) will end up in the same boat. The problem is you need a source of vacuum/boost that is off the idle (Ie -is not referenced at idle). to allow the vacuum advance/boost retard mechanism to work correctly. Since it only will pull 7~10 degrees of timing if you are running over 10PSI boost you are already sliding to the 'danger zone'. FWIW Link to comment Share on other sites More sharing options...
Scotty Dont Posted August 12, 2009 Report Share Posted August 12, 2009 The problem is you need a source of vacuum/boost that is off the idle (Ie -is not referenced at idle). to allow the vacuum advance/boost retard mechanism to work correctly. I disagree, I and a few other are running full vacuum at idle to the adv/retart canister and have no problems except for a smoother idle :party0009: Link to comment Share on other sites More sharing options...
boostsi Posted August 12, 2009 Report Share Posted August 12, 2009 i want one of these intake manifolds for my fiji blue tsi keep us updated and good work Link to comment Share on other sites More sharing options...
Dcrasta Posted August 17, 2009 Report Share Posted August 17, 2009 I disagree, I and a few other are running full vacuum at idle to the adv/retart canister and have no problems except for a smoother idle :party0009: If you are running full vacuum at idle then you will be likely advancing timing at idle. Try setting your timing with '0' vacuum and then adding the vacuum source. the timing will change. So unless you are compensating with ignition control you are probably starting off with timing advanced beyond 10bdc . But what ever works for you man.. Link to comment Share on other sites More sharing options...
pyro_nate Posted May 13, 2010 Report Share Posted May 13, 2010 Hey is there any news on the manifold ? Link to comment Share on other sites More sharing options...
dstar88 Posted May 13, 2010 Report Share Posted May 13, 2010 ......how dare you bump this old thread.... Daniel Link to comment Share on other sites More sharing options...
QuestFan Posted July 28, 2011 Report Share Posted July 28, 2011 Wish it would let me see the pics! I'll stick to the intake in my sig though. Link to comment Share on other sites More sharing options...
TSIREX Posted June 29, 2014 Report Share Posted June 29, 2014 Any news? Link to comment Share on other sites More sharing options...
Tman Posted June 29, 2014 Report Share Posted June 29, 2014 WOW talk about a old thread Link to comment Share on other sites More sharing options...
