TSIREX
Everything posted by TSIREX
Looking for a turbo online to fit stock 8cm exhaust manifold
TSIREX replied to TSIREX's topic in Just plain ol' B.S.
Me too. -
Dang -
It seems like there are more TD05h parts available than the TD05. -
Did you use a micrometer? -
That's with rebuild too. -
cool I took your advice and thanks. I talked to Gerald at gpops and it should arrive there today. Getting td06 exhaust wheel, 16g compressor wheel with machine work on exhaust side and new exhaust wheel with new compressor wheel for $640. I shipped the 16g compressor housing with turbo. Not a bad deal. -
And has it been cleaned out?
How much for a stock intercooler?
Under $800 -
I have stock injectors with afpr and stock exhaust manifold. Just wondering where the good deals are, maybe a td05 cartridge with 16g or a already modified td05 or td06. Just want a good reputable company that has a quick turn around with shipping for td05 -12a to upgrade. Possible a whole turbo charged with exhaust housing that is a direct bolt on for either td05 16g or td06 16g. Thanks in Advance, Rex
Turbo lab to me is by far more bang for your buck when keeping the 8cm exhaust and trying to shoot for 300hp. For now.
I seen a write up on sqc about porting the stock manifold and flange with smoothing out the inside for better flow. Just got to make sure the manifold has no cracks to invest time into it. When using bigger turbos on stock manifold and 8cm exhaust housing, have the wastegate smoothed out too.
Also make sure coolant fluid is 33% to 67% and use distilled water with two teaspoons of mild soap or use the wetter water solutions at any auto parts store.
Line the hole to the passage that goes to the turbo coolant line.
I did the same radiator upgrade, I ran 15 degrees hotter. Come to find out my fusible link box needed a cleaning and I bought new fusible links, now stays at 180 instead 195. I have both fans running at 180 so it drawed more voltage and you can get more voltage to it once resistance is gone. While I was at I changed the thermostat and drilled a 1/8 hole in the thermostat for added peace of mind.
Turbo mods for 87 with stock injectors using megasquirt2
TSIREX replied to TSIREX's topic in Virtual Mechanic
Sorry 16g. Thanks for a quick response warrior. Would two 1050 injectors work and do you know of a good brand that would work in stock tbi that doesn't consist of peak and hold? -
Wanting to know what the highest turbo and hp I can get with running stock TBI with aeromotive afpr. -
I want to go with a td06sl2, modifying the td05 12a stock turbo exhaust housing with waste hate being ported. My question is will the stock injectors be able to fuel a td06sl2 turbo and will the stock injectors be maxed out or will there still be some room? Trying to reach 275hp to 300hp with megasquirt2. Thank you in advance. Just wondering what others have experienced.
Lower Shores Performance Steel Braided Lines
TSIREX replied to brianpaul98's topic in Group Purchase Info
In black and also need turbo oil feed line in black. PayPal ready -
Still selling the lines for 8an coolant lines from thermo stat to stock turbo? -
When upgrading the oil catch can lines don't go with the spectra rubber o-rings if you have ovcp, in time the rubber o-ring will loosen it's tightness from heat, in my case with megasquirt2 it has a slight leak in metered in take air and when I lift up the plastic nipple that goes in to o ring you can here the difference in idling. Long story short go with a few millimeters in diameter larger nipple to intake and use aluminum nipples. Also put nipples close to bend of custom intake pipe, pretty much close to where stock was on accordian style OEM intake.
WTB Magna intake injectors, fuel regulator, throttle cable bracket
TSIREX replied to TSIREX's topic in Items Wanted
Just got I injectors but thanks sorry it took so long been tuning forever in a day -
Sorry it took so long yeah I'm interested how much for bracket? -
I got to hand it to scott87star. He tuned my car via emails. My car is running good. Thanks Scott87star.
Ordered bsek,m28 head,ARP studs, lifters,ajusa head gasket, hood latch,front grill clips. Fast shipping and took time out of his busy day to answer questions that I had. Thanks Dad
