Funk Locks $125
Funky Phil
It is a little cramped in there. Just use box wrenches. That is your best bet. The 2 bolts in the cross member are pretty straight forward. The 2 on the block are a little more tricky. But very doable.
Either those or the straight open end box wrench. I used a 1/4 in flex head fine tooth ratchet after I got them broke loose and for install. Go back to the wrenches for final tightening.
Got it installed. The Funk Lock is SOOOO much easier and nicer to install than the stock mount. Only issue I had was I had to use shorter bolts on the chassis because of the design it didn't allow the bolt to go through easily. But that is minor. Unfortunately after putting the alternator back in, now that doesn't charge. Until I fix that I won't know how good the Funk Lock is.
  • 4 months later...
  • 2 months later...
  • 4 weeks later...
  • 4 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
