importwarrior Posted July 25, 2013 Report Share Posted July 25, 2013 (edited) Maybe i am wrong. BUT the whole idea of getting the 3 inch was to eliminate back pressure AFTER the turboto better spool.the presure between the head and turbo along with the heat of the exhaust spool the turbo buy openning the exhaust behind the turboyou help the flow of exhaust out of the system with less pressure to aid in faster spool by less back presssure and less restriction on the turbine.i think????? Edited July 25, 2013 by importwarrior Quote Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted July 25, 2013 Report Share Posted July 25, 2013 Yeah back pressure on a turbo car is a bad thing. Quote Link to comment Share on other sites More sharing options...
Cloud81918 Posted July 25, 2013 Report Share Posted July 25, 2013 (edited) Back pressure is widely know to be a myth anymore. The issue isn't backpressure, you want to avoid all back pressure is possible. The issue is velocity. Going too big will mean hot fast moving gasses will run into stagnant lazy cooling gases. I have 2.5 inch on non-NA cars under 2 liters in size. I will admit it is a bit too big, but more of an issue of weight than any other performance measure, There are lots o way to look at engines. It sometimes helps to look at a turbo engine as a NA engine. Basicly producing an extra atmosphere of pressure will double the total flow through an engine (not really, but it is a simple model). Playing with this model a 2.6 pushing nearly 15 PSI is basically moving the same amount of air as a 5.0 if both are at the same RPM. People run 2.5 inch dual exhaust on small block Fords all the time. So I think if you have plans for anything like that you are probably choking the engine a bit with a single 2.5. If you are at 7 PSI. Using that model practice again, a 2.6 at about 7 psi should be seen as about a 4 liter engine. Is 3 inch exhaust pipe a bit big. My goal is the 300+ club. I needed an new exhaust and didn't want to buy twice. In current stock tune all I see from it is faster spool and louder exhaust. I doubt I've added much power. Probably haven't broken 200hp, other mods in the mix as well. As I said gunning for 300, if I had got to 280 and was on a 2.5 inch I would have been kind of irritated with myself that I didn't go for 3. I think you will be happy with the MK1. Edited July 26, 2013 by Cloud81918 Quote Link to comment Share on other sites More sharing options...
RonnieJ Posted July 25, 2013 Report Share Posted July 25, 2013 (edited) Under 400whp 3" downpipe to 2.5" catback is fine. shop FRS made 400whp with a 3" downpipe 2.5" catback and high flow cat. If you dont want the added noise and drone do this Edited July 25, 2013 by RonnieJ Quote Link to comment Share on other sites More sharing options...
'87quest Posted July 26, 2013 Author Report Share Posted July 26, 2013 someday I too want to join the 300+ club as well Quote Link to comment Share on other sites More sharing options...
traps Posted July 26, 2013 Report Share Posted July 26, 2013 I am guessing turbo lag is a myth too.....but with new turbo technology and variable vanes and vane position sensors who needs lag with a 25 yr old car. bigger isn't always better when your looking for fast spool. Once again ask yourself...track car, daily or stoplight assasin. My porsche had open headers and after " no back pressure" the valves bent and even my mechanic warned my from running her the way I did all the time. Is restriction what we are gettin rid of from our overdone oem vehicles yes but am just adding two cents Quote Link to comment Share on other sites More sharing options...
Fuze Posted July 26, 2013 Report Share Posted July 26, 2013 I hear guys debating backpressure. All you have to do is bolt on a downpipe and see the difference created from the reduction in backpressure, it's obvious. When is too little backpressure a problem on a turbo car? Never. The faster the exhaust can leave the car, the faster the spool. 1 Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 9, 2013 Author Report Share Posted August 9, 2013 Installed my mk1 exhaust and downpipe and had my local guy build me the missing pipe. Love the 3in exhaust! Quote Link to comment Share on other sites More sharing options...
importwarrior Posted August 9, 2013 Report Share Posted August 9, 2013 Glad to hear itThanks for the update. did you notice anything better or worse now that you have a 3 inch? Quote Link to comment Share on other sites More sharing options...
Fuze Posted August 9, 2013 Report Share Posted August 9, 2013 Installed my mk1 exhaust and downpipe and had my local guy build me the missing pipe. Love the 3in exhaust! Good deal. It's the last exhaust you will probably need to buy regardless of whatever else you do. Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 9, 2013 Author Report Share Posted August 9, 2013 yeah you can really feel a pretty good power gain and acceleration is much better.. It totaled around $500 but i figured if I'm going to do it why have to do it twice.. I'm very happy with it.. looks better, sounds better, more power = happy owner Quote Link to comment Share on other sites More sharing options...
krudmuphin Posted August 9, 2013 Report Share Posted August 9, 2013 (edited) I might get the same setup as you after reading through this entire old thread today, lol Do you have a sound clip of you 3" setup?Although I'm assuming it sounds like a tractor just like every 2.6 Starion anyways (not a bad thing, haha) Edited August 9, 2013 by krudmuphin Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 10, 2013 Author Report Share Posted August 10, 2013 No I don't.. it sounds pretty good.. kinda cackles a bit when you let off which sounds cool haha Want me to go take a video of it for you? Or can I not even upload a video here? Quote Link to comment Share on other sites More sharing options...
Force Fed Mopar Posted August 10, 2013 Report Share Posted August 10, 2013 A video would be great I have a 2.5" turbo back exhaust on mine, no cat and a wore out Greddy muffler that drones bad. I'll leave the 2.5" pipe on it but need another muffler bad. A vid and description of yours would be helpful. I have been considering a Magnaflow. Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 10, 2013 Author Report Share Posted August 10, 2013 Alright I'll try to get a video up today Quote Link to comment Share on other sites More sharing options...
krudmuphin Posted August 10, 2013 Report Share Posted August 10, 2013 Sweet! YOu can always post it to youtube or another video site and just link the video. I'm not sure if this forum supports uploading video files... Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 11, 2013 Author Report Share Posted August 11, 2013 Well here goes.. I hope it works! Haha I don't know if it's my phone or what but it's much smoother in person http://i1321.photobucket.com/albums/u560/drakelehr/th_20130810_090215_zps5fe29f5d.jpg Quote Link to comment Share on other sites More sharing options...
Force Fed Mopar Posted August 11, 2013 Report Share Posted August 11, 2013 You need to stand 30-40 ft away when recording with a phone to get decent sound, the mics are too sensitive and make it buzz like that when close up. Quote Link to comment Share on other sites More sharing options...
Technology Posted August 11, 2013 Report Share Posted August 11, 2013 Here's a couple lame videos I made, it's interior, but you can hear the exhaust. It's 3" with only a magnaflow 3" offset in/out and the tip extends about 2-3" past the bumper. It was really reasonable inside. Don't mind that dang fuel pump or the commentary (lol) in the second video, but you do hear the sound from the hatch area since the camera was there. Setup was a 292 cam, larger turbo, MPI, but stock head and cast log manifold. For bigger power, remember, you drive the turbo, and no matter what people say, there's still a trade off, the bigger the turbo, the more lag you'll have, but for only 300 HP, you don't need a huge turbo, any 16G will get you there. It's always going to be easier with MPI, but just adding a big turbo will give you the right starting point. Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted August 11, 2013 Report Share Posted August 11, 2013 Wow 3 inch is a lot quieter with a muffler lol. What kind of fuel pump is that? Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 14, 2013 Author Report Share Posted August 14, 2013 Here's another video from a bit farther away.. you can hear the exhaust and you can see that it sounds good, not annoying like some other ones I've heard http://i1321.photobucket.com/albums/u560/drakelehr/th_20130813_141645_zps7859c179.jpg Quote Link to comment Share on other sites More sharing options...
Technology Posted August 15, 2013 Report Share Posted August 15, 2013 That was the Aeromotive A1000. I swapped to dual walbro 255s after that. It was a million times better. Quote Link to comment Share on other sites More sharing options...
krudmuphin Posted August 15, 2013 Report Share Posted August 15, 2013 Wow that's loud. But I probably want to get the same setup for mine! Loud is good I would get a different muffler though. I like the looks of the stock dual-tip muffler. Quote Link to comment Share on other sites More sharing options...
'87quest Posted August 17, 2013 Author Report Share Posted August 17, 2013 Yeah I like the dual tip better too but this came in the kit.. I'll change it when I find a few bucks haha Quote Link to comment Share on other sites More sharing options...
PhenomTSi Posted August 17, 2013 Report Share Posted August 17, 2013 My '87 has a 2.5" (no cat) with a Dynomax muffler and I can hardly hear it when cruising, but it gives you a nice growl when you get on it.My buddy's '83 has a 2.5" (no cat) with a Borla muffler and it's much louder, but still doesn't sound too droney (spelling? LOL). Either way will definitely give you a performance boost, but like most people have said, 2.5" is plenty unless you plan on doing quite a few more mods later on. Just my .02 cents Quote Link to comment Share on other sites More sharing options...
