tsi_tom Posted July 3, 2013 Author Report Share Posted July 3, 2013 Cleaned up the intake manifold. Getting ready for the injection mixer rebuild soon. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/cleanedupintakemanifold_zps797a9f00.jpg Painted the AC compressor bracket http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/paintedaccompressormount_zpscf2b59d7.jpg Got the timing cover ready for the block http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/timinggaskets_zps369c2a0a.jpg This crankshaft seal was a real pain to install. I don't like how hard it was to put in. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/crankshaftoilseal2_zpscd373f55.jpg Got ready to put the head on http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/headandgasketkit_zps80c73027.jpg Semi assembled engine http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/semiassembledengine_zps72caef5f.jpg Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 3, 2013 Report Share Posted July 3, 2013 Very nice so clean!BUTmaybe you need to paint the crank pulley black if possible. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted July 3, 2013 Author Report Share Posted July 3, 2013 I will paint the pulleys. I just put that on there to look at. I will also paint the power steering bracket. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 3, 2013 Report Share Posted July 3, 2013 so close bet you cant wait to get it in and running. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted July 3, 2013 Author Report Share Posted July 3, 2013 I am getting antsy, but I do have a lot of work yet. Gasoline has eaten the paint off the drivers side engine bay. That needs to be taken care of. Plus I have to change the gas tank. I will polish the valve cover si the engine will look better. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted July 10, 2013 Author Report Share Posted July 10, 2013 I bought these injectors and sent them off to RC Engineering for cleaning. http://www.starquest...31#entry1359640 The black injector was externally leaking and the green injector was good. Look at the flow numbers. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Fuel%20System/ConquestGreenInjector_zpsd4309fac.jpg Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted August 5, 2013 Author Report Share Posted August 5, 2013 I got the pulleys and brackets for the engine sand blasted at a company called Blastco. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/Blastco_zps489a1db1.jpg Sand blasted parts http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/Sandblastedparts_zps1088bd90.jpg I painted and installed the parts onto the engine http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/engineassembled1_zps0562439f.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/engineassembled2_zpsd43dc37c.jpg Back in the engine bag http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/backintheenginebag_zps48f427d5.jpg I started to rebuild the distributor following PQ's instructions http://starquest.i-x...der=asc&start=0 I tested the vacuum advance. It doesn't hold vacuum. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/vacuumncontroltestedandleaking_zpsdbc8a178.jpg I tested another vacuum advance I had on another motor. It held vacuum but for a very short time http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/vacuumcontrolbarelyholdingvacuum_zpsa2424719.jpg Here is a video of the vacuum bleading off http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/th_vacuumcontrolbleedoff_zpsb71a8f52.jpg The advance was sticking. I started to take the distributor apart. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/markedtheweightsandsprings_zps7cc7034b.jpg Dry grease on the weights http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/driedupgrease_zps901f92a2.jpg Very dry grease on the shaft http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/driedupgreaseontheadvance2_zps55d996de.jpg Distributor all apart. The advance section needs to have the stub filed so it can come apart to be greased. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributorapart_zpsb5753bbf.jpg All the parts are clean now. I am ordering a new seal for the shaft. I probably would have been ok with the original one. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributorapartandclean_zpsfa2d29b7.jpg Now I am waiting for the shaft seal. Next I am onto rebuilding the throttle body. Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted August 5, 2013 Report Share Posted August 5, 2013 Very nice build thread! Keep up the good work. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted August 5, 2013 Author Report Share Posted August 5, 2013 (edited) Very nice build thread! Keep up the good work. Thanks! I like the feedback from the community. Edited August 5, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted August 18, 2013 Author Report Share Posted August 18, 2013 (edited) Reassembly of the distributor. I replaced the shaft seal since I was already there. I also replaced the vacuum advance with one from RockAuto. When I took apart the advance I put it together wrong which caused the vacuum advance not to line up. Took a little bit to figure out. Good I took pictures. This time I bought the parts from mitsparts.com. They are in NJ and are closer to me. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/reassembleddistributor_zps68675f36.jpg Timing line up. I followed Indiana's instructions: http://b2600turbo.com/distributor.htm http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributortimingmark_zps5a0efcad.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/distributorandcamtiming_zps523a9395.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Distributor%20rebuild/rotoranddistributoralignment_zps368b6c53.jpg Edited August 18, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted August 18, 2013 Author Report Share Posted August 18, 2013 I started to rebuild the injection mixer. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/Injectionmixerbeforerebuild_zps18a410a5.jpg I wanted to replace the throttle shaft seals I got from Lower Shores. I stripped one of the butterfly screws. The drill just broke the metal. It didn't skip either. Just started to spin. From now on I will grind the stamping in the screw on the other side of the butterfly. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injectionmixerscrews_zpsb4dbb9ac.jpg Quote Link to comment Share on other sites More sharing options...
TexasQuest Posted August 18, 2013 Report Share Posted August 18, 2013 They make special Japanese screwdrivers "no joke" for those screws on the mixer housing. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted August 18, 2013 Author Report Share Posted August 18, 2013 (edited) They make special Japanese screwdrivers "no joke" for those screws on the mixer housing. I have a Kowa Seiki t-handle that works great. The t-handles are used for working on Japanese motorcycles. The set I bought at a motorcycle dealership about 15 years ago. http://www.kowa-seik...p/english_site/ Edited September 3, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted September 2, 2013 Author Report Share Posted September 2, 2013 Since stripped the butterfly screw I switched to another injection mixer. I'll work on that later. Winter is coming and I am in a hurry to put the engine back in. I replaced the throttle shaft seals that I got from Lower Shores. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/replacedthrottleshaftseal_zpsc5e809e7.jpg Red Thread locked the butteryfly screws. I hope I don't regret that decision. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/threadlockedbutteryflyscrews_zpsa561217f.jpg Peened the butterfly screws http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/peenedscrews_zpsff3a7005.jpg Installed a new o-ring http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/oringset_zps48d4f733.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/lemonoringinstalled_zpsfe948da4.jpg Someone was working on this injection mixer before. Those screws are not stock. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/notstockfuelregulator_zpsfd058bc6.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/fueldiaphram3_zpsff86a323.jpg The regulator has some not stock washers on it. I wondered why. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/washersonthebolttothefuelpressureregulator_zps9f8994b4.jpg Now I know why. The bolts are stripped. Anyway to save this regulator? http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Injection%20Mixed%20Rebuild/injection%20mixer%202/strippedboltonthefuelpressureregulator_zps19177cb4.jpg Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted September 2, 2013 Author Report Share Posted September 2, 2013 I ordered a spray can of Y59 paint from paintscratch.com. I also ordered some primer. This is what came in: http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20bay/primerandpaint_zpsdf9c811c.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20bay/spraycanY59label_zps47979253.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20bay/spraycanY59_zps9c998fe8.jpg This is what the paint is for: Paint was eaten by leaking gasoline http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20bay/painteatenbyfuelleaking_zpscf6b8e60.jpg Ugly engine bay...barf! http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20bay/uglyenginebay_zps8b9eaa6d.jpg Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted September 21, 2013 Author Report Share Posted September 21, 2013 I tried to remove the steering box to paint the frame rail that has been eaten away by gasoline, but I don't have the MB991113 steering link removal tool. So I moved onto replacing the gas tank. There was a lot of mud under the back of the car where the gas tank is. I got a lot of dirt in my eyes, however removal wasn't too bad. Access plate in trunk http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/fuelpumpcover_zps0e4936b7.jpg Access plate removed. See all that mud/dirt? http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/fuelpumpcoverremoved_zpsc1f0c95e.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/fuelpumpcoverremoved1_zpsdbb52035.jpg Gas tank removed http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/gastankremoved_zps3a504eea.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/upcloseofthefueltank1_zps47a7cea2.jpg Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted September 21, 2013 Author Report Share Posted September 21, 2013 (edited) I was looking for the funnel that is used to fill up the rear washer fluid. Someone stated to stick your arm down the fender well to see if it is there. Take a look at this surprise! Red velvet! http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Fender%20well/fenderwellsurprise_zps636a8e89.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Fender%20well/fenderwellsurprise2_zpsd5c70ccc.jpg Edited September 22, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
88-cnqst-tsi Posted September 21, 2013 Report Share Posted September 21, 2013 hahahahahaaha your car defiantly has a story Quote Link to comment Share on other sites More sharing options...
techboy Posted September 22, 2013 Report Share Posted September 22, 2013 Ya know Tom ... this is going to raise a lot of questions w/ your wife as to what exactly you've been doing out in the garage all this time. Wish I could have made it down today to help you out, that definitely would have been worth a good chuckle. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted September 22, 2013 Report Share Posted September 22, 2013 LOL goes well with the Banana Yellow!!! Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted September 22, 2013 Author Report Share Posted September 22, 2013 (edited) I don't know..naughty miss santa or some valentines outfit is what I think it was a part of. My wife was pretty skeeved out. So I put it back in the fender well! Today I opened the gas tank...it is rusty inside. Now I already had a replacement tank so now I need the filler neck. Edited September 22, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted October 14, 2013 Author Report Share Posted October 14, 2013 (edited) I tested the oil cooler by-pass valve in a 5 dollar toaster oven. Ready for the test http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Oil%20Cooler%20By-pass%20Test/testingtheoilcoolerby-passvalve_zps087a6131.jpg By-pass valve open before the test http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Oil%20Cooler%20By-pass%20Test/beforebeingheated2_zps725336e5.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Oil%20Cooler%20By-pass%20Test/beforebeingheated_zps35c12634.jpg By-pass valve closed. Heated the oil filter bracket up to 250 degrees F for about 20 minutes. The valve moves to the closed position quite slowly. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Oil%20Cooler%20By-pass%20Test/afterbeingheated_zps4e4e541c.jpg I have been busy on a few things lately. The gas tank that was shipped to me is bent on the fuel neck side. I needed to get a body hammer and try to straighten it. Also I took out the steering box to paint under it. That was a real pain in the *** to get out. Edited October 14, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
importwarrior Posted October 15, 2013 Report Share Posted October 15, 2013 good info here. like the pics.any ETA when you will be done? Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted October 15, 2013 Author Report Share Posted October 15, 2013 I am hoping to have the engine installed and running by December. There is a lot of little things that need to be addressed before turning the key. I wasn't planning on rebuilding the steering box, but since it is out of the car now might as well. I also need to get an engine hoist since my neighbor sold his . Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted October 21, 2013 Author Report Share Posted October 21, 2013 The tank I bought was damaged in shipping. The side that the filler neck connects to was bent. Being bent under the fuel opening made the repair a little challenging. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/filltubeopening_zps9737e9b2.jpg I purchased these auto body tools at a flea market. I never did sheet metal repair before. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/autobodytools_zps663c68f6.jpg I flattened the bend and tried to get the bracket as straight as I could. I don't know how to get the bend in the bracket correct. I used an adjustable wrench and bent the bracket into position. I had to have the lip of the tank a little lower so that the filler neck would align correctly. Painted the top of the tank that took the abuse of the hammer. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/repairedgastank1_zpsfee492c7.jpg Quote Link to comment Share on other sites More sharing options...
