The Missouri Project
tsi_tom
Took the transmission out because I needed to clean out the oil that was caked in the bell housing.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/removedtransmission_zps8dd1df88.jpg
Before the engine bay cleaning I needed to move the car outside. It hasn't seen the outside in 10 years. The brakes didn't work anymore. I bled them with the help of my wife. Look at the nasty fluid. This was clean 10 years ago when I put new hoses, pads, and rebuild calipers. Time is tough on the car even though it is covered in a garage.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/badbrakefluid_zps0b3fb8f4.jpg
Outside
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestoutside_zps41d9c8da.jpg
Techboy came over with his pressure washer and we got to work.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/dirtyenginebay2_zpsf252c6be.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/cleanenginebay_zpsabb475ad.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/dirtydriverssideenginebay2_zpsf0cf79cd.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/cleandriverssideenginebay_zps6e7bc363.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/dirtydrivessideenginebay_zps4ef1b340.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/cleanpassengersideenginebay_zps81c2fe69.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/cleanfrontenginebay_zps36e4bd93.jpg
Gettting ready for the flywheel installation. I supported the engine on a chair. The hoist is bearing much of the load. I did this so the engine didn't spin when torquing the flywheel bolts.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/engineonchair_zpsca9dab8b.jpg
Warmed up the flywheel for installation
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/warminguptheflywheel_zps8b6e27cf.jpg
Installed the flywheel with Randy's(Dad) trick...
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/flywheelholdingsetup_zpsdf2f32b5.jpg
Ready for installation tomorrow!
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/endofthedayengine_zpsb3e55682.jpg
Today I installed the pilot bearing
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/newpilotbearing_zps8f542c45.jpg
And put in the new clutch
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/newclutch_zps3dcb57e7.jpg
Got the hoist out
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/motorreadytobeinstalled_zps99f176b4.jpg
And installed the engine
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/motorinstalled_zpsa189a8d9.jpg
It is a surreal experience to see the engine installed.
I need to thank Techboy for helping out again. I couldn't have installed the engine without him.
BuGG this happened quick today when I called Techboy. Perhaps we can meet up when installing the transmission.
Quick work is right ... if you take away the BS chat time, I think we did it a/b an hour. ;) I love that valve cover ... makes me want to take my powdercoated one off and polish my spare. Edited by techboy
Now that's a clean install and quick work.
Great job! This project is coming together great. Love me a yellow quest.
Thanks guys!
Today I cleaned up the transmission. It was covered in oil. There was a lot of oil in the bell housing. So not contaminate the new clutch it was cleaned.
Before cleaning
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/transmissionbeforecleaning_zps6a52b1c9.jpg
After cleaning
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/cleanuptransmission_zps62eadde7.jpg
Dropped the pan to clean it also
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/transmissionpan_zpscf475555.jpg
Crud on the inside. Not too bad I think.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/crudinthetransmissionpan_zps2221c0ed.jpg
Inside look.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/insidethetransmission_zps775b8180.jpg
Transmission upright
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Transmission/DSC03415_zpsd0bafb2a.jpg
3 mm ID vacuum line has come in from boostcontroller.com
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/3mmvacuumline_zpsd743f37c.jpg
I am looking for a picture on how the vacuum lines route to the left side of the engine(near the aircan) and the factory way of mounting them.
I replaced the rear transmission seal today. That was a little more work than I expected. I tried to get the seal out with a Snap On seal puller
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Putting%20the%20Conquest%20back%20together/Snaponsealpuller_zps75c16d3a.jpg
The seal was in very tight so I removed the rear cover on the transmission
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Putting%20the%20Conquest%20back%20together/Reartransmissioncover_zps7328fc5a.jpg
Then I tried again with the seal puller. That didn't work either. Then I tapped with a screwdriver like this... being careful not to hit the aluminum.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Putting%20the%20Conquest%20back%20together/Howtoremovetheseal_zps019e399f.jpg
That worked great!
Tools used and seal part number.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Putting%20the%20Conquest%20back%20together/Toolstopulltherearsealonthetransmission_zps2a203c86.jpg
I got the transmission installed and was feeling great until I went to put on the flywheel cover. I noticed this part wasn't installed. Shoot!!!
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Putting%20the%20Conquest%20back%20together/Enginetotransmissionplate_zpsce5337ec.jpg
So after 30 minutes of sorrow I figured there was no reason to belly ache over the mistake and remove the transmission, clutch and flywheel.
Whoa dude are you gonna drop the trans again to put that in now?
Yea....I had to drop the transmission again. I least I didn't fill it up with oil, have the drive shaft installed, and shifter installed. After a year I forgot about that plate. It was one of the first things I took off the engine a year ago.
Edited by tsi_tom
Almost back to life
I bought a new battery and connected all the electrical back up. I got a new ground bolt and washer. Washer are no longer available in the U.S.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Mainenginegroundandwasher_zpsd1b0b64f.jpg
Just to be sure there wasn't a fire as soon as I connected the battery I tested the positive connection with a 5 amp fuse. I've come too far to risk a fire or harness melt down.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/5amptest_zps094e5a0b.jpg
Nothing major occurred. So I turned on the headlights and popped the fuse. Too much current to raise the lights.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Conquestopeninghereyes_zps780689d1.jpg
Using my Fluke, I measured the current draw. 450 milliamps.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Currentdrawat450milliamps_zps5d97db78.jpg
I wondered why it was that much. I then noticed that the drivers side interior light was on. Turned that off and got 30 mills.
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Currentdrawat40milliamps_zpsede56e85.jpg
She is coming back to life!
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Awake_zps06c08d80.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Illuminatedbrakelights_zps47969165.jpg
http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Electrical/Dashpanelcomingbacktolife_zps462798c3.jpg
Now I will go get oil to fill her up.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
