tsi_tom Posted November 4, 2013 Author Report Share Posted November 4, 2013 I replaced the fuel hose between the fuel filler neck and the gas tank with the two inch inner diameter hose that 89PalermoSHP recommended in a search that I did. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/NAPANBH1045hoseandstockfillerhose_zps82bce937.jpg Filler MB181707 -> NAPA NBH 1045 http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/NAPANBH1045fuelhosepartnumber_zps94823b91.jpg Installed the replacement gas tank and reconnected the lines. That part of the fuel system is ready. Onto the engine bay. I removed all the rust from the frame rail and primer it. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Frame%20rail/primerdriversideframerail_zps75388952.jpg Then I painted it with the paintscratch.com Y59 yellow spray can. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Frame%20rail/painteddriversideframerail_zpsf1e4ad5e.jpg While the steering box was out I decided to rebuild it. Getting the pitman arm was tough. I tried the autozone pitman arm puller that they loan out but it didn't work. Then I tried the pitman arm puller Kev used in his rebuild from Pepboys. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/pitmanarmpullerOEM27170_zpscfc605bb.jpg I tried hitting the bolt on the puller like it has been suggested but that didn't work for me. What worked for me was to hit the side of the pitman arm with a drift. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/driftandpitmanarm_zpsa65155f1.jpg There was some damage done to the pitman arm by the puller slipping off http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/damagefrompitmanarmremover_zps79ae518c.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/damagefrompitmanarmremover1_zps70121c56.jpg Quote Link to comment Share on other sites More sharing options...
importwarrior Posted November 4, 2013 Report Share Posted November 4, 2013 WoW seems to not want to come off. probably has not been off since the car was made.the paint job is looking good. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted December 5, 2013 Author Report Share Posted December 5, 2013 Bought an engine hoist from Pep Boys. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Engine%20Hoist/EngineHoist_zps07d9aa63.jpg I am getting close to installing the engine after I rebuild the power steering box and reseal the power steering pump. I ordered a clutch from Clutch City Online. I got the Exedy stock clutch. Quote Link to comment Share on other sites More sharing options...
randy Posted December 5, 2013 Report Share Posted December 5, 2013 I replaced the fuel hose between the fuel filler neck and the gas tank with the two inch inner diameter hose that 89PalermoSHP recommended in a search that I did. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/NAPANBH1045hoseandstockfillerhose_zps82bce937.jpg Filler MB181707 -> NAPA NBH 1045 http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Gas%20Tank/NAPANBH1045fuelhosepartnumber_zps94823b91.jpg Installed the replacement gas tank and reconnected the lines. That part of the fuel system is ready. Onto the engine bay. I removed all the rust from the frame rail and primer it. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Frame%20rail/primerdriversideframerail_zps75388952.jpg Then I painted it with the paintscratch.com Y59 yellow spray can. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Frame%20rail/painteddriversideframerail_zpsf1e4ad5e.jpg While the steering box was out I decided to rebuild it. Getting the pitman arm was tough. I tried the autozone pitman arm puller that they loan out but it didn't work. Then I tried the pitman arm puller Kev used in his rebuild from Pepboys. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/pitmanarmpullerOEM27170_zpscfc605bb.jpg I tried hitting the bolt on the puller like it has been suggested but that didn't work for me. What worked for me was to hit the side of the pitman arm with a drift. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/driftandpitmanarm_zpsa65155f1.jpg There was some damage done to the pitman arm by the puller slipping off http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/damagefrompitmanarmremover_zps79ae518c.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Steering%20box/damagefrompitmanarmremover1_zps70121c56.jpg Do you think if you had applied a little heat, and then used the puller it would have came off a little easier? Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted December 5, 2013 Author Report Share Posted December 5, 2013 (edited) I tried heat with the auto zone puller. It didn't work. However I only had propane to heat it. Also I soaked the threads for days with BG In-force, still it was being stubborn. Edited December 5, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted December 8, 2013 Author Report Share Posted December 8, 2013 (edited) Today I went to the garage to install the new Exedy clutch set that I got this week. As I went to clean up the flywheel I noticed heat stress cracks and purple coloring. Earlier I didn't look at the flywheel closely because the clutch friction material looked good. I almost reused the set I took off. So now I wonder if I need a new flywheel. Heat cracks on flywheel http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Stresscracksinflywheel4_zpsac23ff33.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Stresscracksinflywheel3_zps08e95055.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Stresscracksinflywheel2_zpsab8a841c.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Stresscracksinflywheel1_zpsd98cc5f3.jpg This is the clutch where the rivets were rubbing http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Rubbingrivetsonclutch_zps4367164e.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Rubbedrivetsonclutch1_zps35bf3be4.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/unkwownclutch2_zps02111741.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/unkwownclutch1_zps4ad2ecf4.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/unkwownclutch3_zpsd5bb5a13.jpg This is the ring that scored itself into the flywheel http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/newridgeinflywheel_zpsfb0ee598.jpg New Exedy clutch and old clutch http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/exedyandunknownclutchsidebyside_zpsdf94de5d.jpg Pressure plate manufacturer stamp http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Pressureplatename_zps53079f90.jpg The Exedy clutch set. Made in Japan. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Exedyclutchset_zps6c638b5b.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/clutchsetpartnumbers_zps22c739b5.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/BearingmadeinJapan_zps4ca89476.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/Bearing_zpsaa306278.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Flywheel/BearingmadeinJapan_zps4ca89476.jpg Edited December 27, 2013 by tsi_tom Quote Link to comment Share on other sites More sharing options...
cobralucci Posted December 8, 2013 Report Share Posted December 8, 2013 dooood amazing resto man! I bought my quest in February of 2011 with the same intentions and ive lingered on and off on this site ive even joined facebook groups with hopes to pick up tips and tricks and how tos and just to motivate me to actually start on it. I own a heavily modded Pontiac g8 gt and the plans was to garage the g8 and daily the quest and this progress of yours has really inspired mne to start driving my quest thanks and keep up the great work!Leo Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted December 8, 2013 Author Report Share Posted December 8, 2013 dooood amazing resto man! I bought my quest in February of 2011 with the same intentions and ive lingered on and off on this site ive even joined facebook groups with hopes to pick up tips and tricks and how tos and just to motivate me to actually start on it. I own a heavily modded Pontiac g8 gt and the plans was to garage the g8 and daily the quest and this progress of yours has really inspired mne to start driving my quest thanks and keep up the great work!Leo Hi Leo, Thanks for reply! I could not have come this far without the help of this site and http://starquest.i-x.net/. One piece of advice I heard from Stacey David of Gears was to do a little bit each day to the car. This I have tried to do. Take care, Tom Quote Link to comment Share on other sites More sharing options...
STARIONCONQUEST Posted January 19, 2014 Report Share Posted January 19, 2014 which wire is the positive wire on my ditributor? Quote Link to comment Share on other sites More sharing options...
STARIONCONQUEST Posted January 19, 2014 Report Share Posted January 19, 2014 which wire is the positive wire on the 87 Mitsubishi Starion distributor? Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted January 19, 2014 Author Report Share Posted January 19, 2014 (edited) I replied to your PM. Here is the link I sent you. Scroll down to the post from Indiana. http://www.starquest...=140009&hl=coil Edited January 19, 2014 by tsi_tom Quote Link to comment Share on other sites More sharing options...
techboy Posted January 20, 2014 Report Share Posted January 20, 2014 (edited) Tom you can have flywheels turned. I'm not sure where to have it done around here, but it can be done. I'd definitely have that done or get a new one. You got a bunch of heat cracks there as you noted. Luckily, when I did my build I had 2 spare flywheels laying around, b/c the one outta my car was cracked just like yours. Edited January 20, 2014 by techboy Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted January 21, 2014 Author Report Share Posted January 21, 2014 Hey techboy! Greg said he could do it but said sometimes the cracks don't come out so I got a used flywheel. I need to order the pins for the flywheel. It has just been too cold to go out into the garage. Quote Link to comment Share on other sites More sharing options...
techboy Posted January 21, 2014 Report Share Posted January 21, 2014 (edited) Pins? You mean the alignment pins for the pressure plate? It didn't know you could get a flywheel without them. Or are you talking about different pins? EDIT: Let me know when you're ready to put that motor in. Edited January 21, 2014 by techboy Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted January 21, 2014 Author Report Share Posted January 21, 2014 These are the alignment pins. They can be removed. I'll let you know when I am ready to install the engine. This flywheel issue was a setback for me and now the weather is bad. Quote Link to comment Share on other sites More sharing options...
Xtreme Industries Posted January 22, 2014 Report Share Posted January 22, 2014 with all the effort going into this, you should paint the whole engine bay. since the engine is out, no better time to do it than now. Quote Link to comment Share on other sites More sharing options...
markhansenconquest Posted February 2, 2014 Report Share Posted February 2, 2014 GOOD JOB when itook mine mine apart I broke the pit man arm puller from autozone no charge good info on injectors im going to send 5 over there next week and now I can see why I need to rebuield diss Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted February 2, 2014 Author Report Share Posted February 2, 2014 (edited) with all the effort going into this, you should paint the whole engine bay. since the engine is out, no better time to do it than now. I really want to but it is time to move things forward. I want to pressure wash the engine bay but the problem is that I have no way to get the car back in the garage without calling 5 of my friends over and they live far away. GOOD JOB when itook mine mine apart I broke the pit man arm puller from autozone no charge good info on injectors im going to send 5 over there next week and now I can see why I need to rebuield diss ucw458 would like the results of your test results from the injectors here: http://www.starquest...+injector +test Edited February 2, 2014 by tsi_tom Quote Link to comment Share on other sites More sharing options...
techboy Posted February 5, 2014 Report Share Posted February 5, 2014 Tom ... when the weather warms up and you want to pressure wash the engine bay let me know. I have 2 friends close by in Qtown. I'm sure between the 4 of us we could push it out and back in easily. I even have a pressure washer if you don't .... I actually pressure washed my bay before I painted it and almost decided not to paint it the pressure wash did such a nice job. I think I soaked it with Purple Power first and then hit it with the washer. I did end up painting it black anyway, but I almost didn't. Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted March 16, 2014 Author Report Share Posted March 16, 2014 (edited) I took the engine mount brackets to be blasted at Blastco. They also epoxy primed and poly urethane painted them. I was going to get them powered coated, but decided to try what Blastco could do. The engine mounts are new. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestenginemountscoated_zpsc770ad9e.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestenginemountleft_zps64827cde.jpg Darn...I forgot to get his piece done too.... http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestenginemountbracket_zps30f91766.jpg http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestenginemountright_zps930fabf8.jpg Update on the motor. I got the valve cover polished and put in a thermo valve from Techboy. http://i1069.photobucket.com/albums/u467/tsi_tom/The%20Missouri%20Project/Reassemble%20of%20the%20engine/conquestassembledengine2_zps5e7c6e29.jpg Edited March 16, 2014 by tsi_tom Quote Link to comment Share on other sites More sharing options...
randy Posted March 16, 2014 Report Share Posted March 16, 2014 Man that motor looks like a brand new unit, You did a great job on that build. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted March 16, 2014 Report Share Posted March 16, 2014 amazing. like off the assembly line. Quote Link to comment Share on other sites More sharing options...
Colin Posted March 19, 2014 Report Share Posted March 19, 2014 great build I love the detail you put into it Quote Link to comment Share on other sites More sharing options...
tsi_tom Posted March 19, 2014 Author Report Share Posted March 19, 2014 Man that motor looks like a brand new unit, You did a great job on that build.amazing. like off the assembly line.great build I love the detail you put into it Thanks guys. The thing that I don't like about the motor are the nuts and bolts. I am thinking about getting those yellow zinc plated. Quote Link to comment Share on other sites More sharing options...
randy Posted March 20, 2014 Report Share Posted March 20, 2014 Thanks guys. The thing that I don't like about the motor are the nuts and bolts. I am thinking about getting those yellow zinc plated. I hope ya have extra bolts and nuts to zinc plate to replace as ya take off. Quote Link to comment Share on other sites More sharing options...
