Removing Motor With Head Bolts
BoostedBimmer
Ok, I have the whole head off the motor, and was wondering if it's ok to use my engine hoist/chain using two head bolts (with bigger washers) screwed into the block to pull the motor out? I won't ruin the threads in the block right? I plan on rebuilding the block down the road and just making sure I don't ruin it...
I wouldnt try it even though it should be strong enough. I did however lift the engine (minus transmission) using the distributor tab bolt and the rearmost threaded hole on the exhaust manifold and it worked quite well. If you have the head off the car then you can get a little creative with the ac/alt holes and the transmission bell housing holes as well.
You can lift it that way just fine. Been there, done that, I keep old bolts around just for that.
Dad
  • Like 1
X2 balance the bolt locations to 1 and 4 cylinders and make sure every thing else is disconnected
remove the hood if you can.
If you have an old seatbelt you can use that as a craddle for added support just don't pinch the pan.
Figure I should post here rather than starting a new topic.
Where would you guys suggest hoisting the engine from if the whole top end (head, manifolds, ect) is still on the engine?
-Justin
-Justin
There should be lift brackets, right front of head by idler pulley and left rear at the intake manifold.
Dad
Dad
Yep, stock from the factory.
MD000255 Engine Front Hanger.
MD026525 Engine Rear Hanger.
Bill
Edited by Caliber308
Great topic/post I will be pulling a short block with a 5 speed connected tomorrow using 4 used head bolts and some chains. Then I can scrap the rest of my parts car finally.
  • 3 weeks later...
Bill
Okay so I'm pulling the motor tomorrow. I looked at it today and couldn't find these hangers...Are they like a metal bracket with holes for hooks?
I tried to look in the VM parts locator and the engine section only has a single diagram and the rest are blank pages. Tried to get a pic on google and came up with nothing really.
-Justin
I lifted mine out with the rear intake bolt and the front bolt where the idler goes (my lift hooks were missing).
Worked like a charm. You'd be surprised at the strength of a 12mm bolt...I installed my datsun engine with it dangling from one so I could get enough angle...thing was stable as could be...haha.
Another thing you guys should be aware of - the lenght of the lifting chain across the engine. It should be a MINIMUM of 3 FT. and have AT LEAST 3/16ths IN. diameter welded links.
There is a good reason for the minimum lenght of the chain. If the chain is too short, the engine could slid forward or backwards through the cherry picker hook due to the small angle of the chain. More important, the shallow angle of the chain could place excessive loads on the chain & engine attaching lift bolts.To avoid this, don't hook the chain up any shorter than necessary, certainly no shorter than 3 feet, and use a large diameter washer with a small hole that JUST fits over the threaded bolt between each bolt head and nut.
I have seen "mechanics" not adhering to the above and a dropped engine back onto the car body is not a pretty sight especially if there is a person who has his hands on the engine helping to guide it out. One "mechanic" had all four of this fingers (missed the thumb) sheared off cuz the lifting chain across the engine snapped and the engine dropped down cuz the chain was made in china and was too short (almost flat) across the engine when lifting tension was applied to it and the engine was about 1 foot in the off of the engine mounts!!!. ;)
For What It's Worth.
KEN
