allen405 Posted March 28, 2012 Report Share Posted March 28, 2012 Where do you get them from? I looked on Rockauto.com but I didn't see it under drivetrain or manual tranny. Was I looking in the wrong area?I looked at some old posts but couldn't get a clear answer on where to get them from. Link to comment Share on other sites More sharing options...
Dad Posted March 28, 2012 Report Share Posted March 28, 2012 ulrich wolf sells them Link to comment Share on other sites More sharing options...
allen405 Posted March 28, 2012 Author Report Share Posted March 28, 2012 I thought so, I just wasn't sure. Thanks for the info. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 28, 2012 Report Share Posted March 28, 2012 (edited) We need a good torque tube rebuild write up with part #'sI vote allen405 for the job Edited March 28, 2012 by JohnnyWadd Link to comment Share on other sites More sharing options...
allen405 Posted March 28, 2012 Author Report Share Posted March 28, 2012 Lol, well I welcome the challenge. I have to tear it to see if it's worth it first. Link to comment Share on other sites More sharing options...
ucw458 Posted March 28, 2012 Report Share Posted March 28, 2012 Not much to write up honestly. Remove TT, pull out TT shaft, remove snap ring holding bearing in, tap bearing out from rear to front, assemble in reverse order with grease on TT shaft splines. Replacement Nachi brand TT bearing, 6206-2NSE #s off OEM bearing DG306216WRK-1 Link to comment Share on other sites More sharing options...
Lance_S Posted March 28, 2012 Report Share Posted March 28, 2012 ^^^^^^^^^^What he said. I did mine this winter, pretty easy. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 28, 2012 Report Share Posted March 28, 2012 Not much to write up honestly. Remove TT, pull out TT shaft, remove snap ring holding bearing in, tap bearing out from rear to front, assemble in reverse order with grease on TT shaft splines. Replacement Nachi brand TT bearing, 6206-2NSE #s off OEM bearing DG306216WRK-1 Do the write up then. And what about the other parts like the gear on the differential and the actual tube if its got bad teeth. Available? Link to comment Share on other sites More sharing options...
ucw458 Posted March 28, 2012 Report Share Posted March 28, 2012 Replacement shafts are NLA. You either find a good used one or live with the clunking. The shaft fits inside the tube and is small. The tube just supports the shaft and diff. I have a diff in my backyard I could do a writup on if I wanted to. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 28, 2012 Report Share Posted March 28, 2012 (edited) Replacement shafts are NLA. Oh did you actually look into that? From what i'm finding its a part number MB160582 for the shaft, MB290746 for the intercooled assembly, MB160900 for the non intercooled assembly, and available from mitsubishi parts dot net. I recall this happened with the center links tons of people thought NLA because one guy said so and then a buch of us got them from www.mitsubishiparts.netThis is the shaft, the torque tube for intercooled and non intercooled.http://i1187.photobucket.com/albums/z388/starionkiller/th_2012-03-27195944.jpg The tube just supports the shaft and diff. Um ya that why i wonder if the tube is available alone. You either find a good used one or live with the clunking. Well obviously. I have a diff in my backyard I could do a writup on if I wanted to. Ok sweet. Good info. I thought we where talking torque tubes. Source..Part numbers http://www.starquestgarage.com/partsloc/conquest/1988/88_conquest_parts_locator_-_group_03_-_rear_axle.pdf Edited March 28, 2012 by JohnnyWadd Link to comment Share on other sites More sharing options...
ucw458 Posted March 28, 2012 Report Share Posted March 28, 2012 I was the one who told the club centerlinks were still available. But only 10 in the US. I bought a few to store on my shelf. I was told by my friend that he bought the last new TT shaft in the US a few years ago. He showed it to me. He bought it to have as a spare. Link to comment Share on other sites More sharing options...
JohnnyWadd Posted March 28, 2012 Report Share Posted March 28, 2012 (edited) I was the one who told the club centerlinks were still available. But only 10 in the US. I bought a few to store on my shelf. I was told by my friend that he bought the last new TT shaft in the US a few years ago. He showed it to me. He bought it to have as a spare. I remember that. You where collecting parts to build one and never did. I'm glad yo ugot some for your shelf. He showed it to me. Im jealous Edited March 28, 2012 by JohnnyWadd Link to comment Share on other sites More sharing options...
ucw458 Posted March 28, 2012 Report Share Posted March 28, 2012 I lost the drive to build one once I found they were still available. Link to comment Share on other sites More sharing options...
vbrad511 Posted March 28, 2012 Report Share Posted March 28, 2012 http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=6206-2NSE&_sacat=See-All-Categories Link to comment Share on other sites More sharing options...
Wakeman17 Posted May 29, 2012 Report Share Posted May 29, 2012 What all comes with the intercooled assembly from mitsubishiparts.net? Link to comment Share on other sites More sharing options...
StarquestRescue Posted May 29, 2012 Report Share Posted May 29, 2012 I have seen a lot of these where the bearing is loose in the boar and sliding front to back in the housing. I think that's where a lot of the clanging come from. I would suggest green lock tight and a shim under the snap ring. Link to comment Share on other sites More sharing options...
Gormzz Posted June 14, 2012 Report Share Posted June 14, 2012 that ebay link.. came up the top with what looks like the bearing.. very cheap option and looks to be easy to replace. i've replaced the grease on the spline of my TT.. it looked half decent but i put so much grease in there it didn't solve the issue. so from my actions i believe that bearing has alot more play in the clunking of gears. just to confirm this is definitely the right replacement bearing for the TT? http://www.ebay.com/itm/6206-2NSE-Nachi-30x62x16-C3-30mm-62mm-16mm-Japan-Ball-Radial-Ball-Bearings-/360392069180?pt=LH_DefaultDomain_0&hash=item53e90a903c Link to comment Share on other sites More sharing options...
Shelby Posted June 15, 2012 Report Share Posted June 15, 2012 if you have the old bearing and numbers a readable,,most towns have a comercial bearing and drives store,, you go buy size and dementions not aplication , and all bearings are metric , i've found them to be a great sourse for finding hard to find metal clad seals also Link to comment Share on other sites More sharing options...
Gormzz Posted June 24, 2012 Report Share Posted June 24, 2012 going to order that nachi one i think.. cheap enough and from what i've read it fits like oem. can't go wrong! pity there is no tubes anymore but oh well... Link to comment Share on other sites More sharing options...
kev Posted June 24, 2012 Report Share Posted June 24, 2012 National 206FF Link to comment Share on other sites More sharing options...
kev Posted June 24, 2012 Report Share Posted June 24, 2012 We need a good torque tube rebuild write up with part #'s Coming soon...very soon. Along with a differential rebuild write up Link to comment Share on other sites More sharing options...
mstieg Posted September 29, 2012 Report Share Posted September 29, 2012 (edited) Good stuff. I also wonder what's included in the MB290746 "Assembly"? It would seem to infer the whole shibang? GREAT FAQ writeup btw Kev. Thanks! Hope the teeth on mine are still decent. Edited September 29, 2012 by mstieg Link to comment Share on other sites More sharing options...
The Rabbit1 Posted September 30, 2012 Report Share Posted September 30, 2012 I was the one who told the club centerlinks were still available. But only 10 in the US. I bought a few to store on my shelf. I just bought one like 2 months ago, I doubt there were only 10 left, the same centerlink works on d-50, mighty max... Link to comment Share on other sites More sharing options...
ucw458 Posted September 30, 2012 Report Share Posted September 30, 2012 I just bought one like 2 months ago, I doubt there were only 10 left, the same centerlink works on d-50, mighty max... That's what I was told when I ordered mine. Link to comment Share on other sites More sharing options...
