Turbo_Addict Posted November 23, 2012 Author Report Share Posted November 23, 2012 Nevermind - found this in the megatune documentation: "Note that the scale in MS2-Extra is in %, so 100% = atmosphere (100KPa) in MAP mode, or 100% TPS in Alpha-N, etc. So obviously a boosted engine will go over 100%." Link to comment Share on other sites More sharing options...
BOHO Posted November 23, 2012 Report Share Posted November 23, 2012 So is it in Alpha-N mode or Map Mode? Or is it just like you said. 0 to 250%? Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 23, 2012 Author Report Share Posted November 23, 2012 Got it now... in baro mode, so using KPA, not speed density or alpha. I had the tables all jacked up. Still massively rich, but check it out - at least it stays running. Step 1 or 340 I'm sure. Link to comment Share on other sites More sharing options...
BOHO Posted November 23, 2012 Report Share Posted November 23, 2012 Sweet man. Is that 16an for your coolant or 20an? Thinking about going 16an for the JZ...From what I've read its plenty at the 1" Link to comment Share on other sites More sharing options...
Technology Posted November 24, 2012 Report Share Posted November 24, 2012 nice! Link to comment Share on other sites More sharing options...
StallionProject86 Posted November 24, 2012 Report Share Posted November 24, 2012 Insane........... Exactly, congrats.! Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 24, 2012 Author Report Share Posted November 24, 2012 Sweet man. Is that 16an for your coolant or 20an? Thinking about going 16an for the JZ...From what I've read its plenty at the 1" Not sure actually - I can get some measurements for you, outer diameters and what not. That was done prior to me purchasing the project. Link to comment Share on other sites More sharing options...
Starfyter Posted November 24, 2012 Report Share Posted November 24, 2012 Sexy doesn't even begin to describe it. Keep up the good work! Link to comment Share on other sites More sharing options...
Lizzord30 Posted November 24, 2012 Report Share Posted November 24, 2012 Sounds awsome! Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 25, 2012 Author Report Share Posted November 25, 2012 Thanks, getting pretty excited of the progress and can't wait to get the exhaust mounted up - this thing is way too loud with just downpipes. lol Upgraded the MS2 to the latest firmware yesterday, and I guess megatune is now no longer supported and need to use Tuner Studios solely... so redid everything in that and hopefully will be on the road to a fully running vehicle shortly. Tuner Studios has a VE Analyze Live option, and apparently with a wideband and that, it can pretty much automatically dial in your fuel VE tune within 5 or 10 minutes of running.... so for basic idling and driveability, that'll probably work out well. But for under boost conditions, we will definitely be going on the dyno for proper tuning. Here are the new tables - everything set to speed density again too: Fuel VE Table:http://www.26liter.us/gallery/albums/userpics/10156/Tunerstudios-VE.jpg Timing Table:http://www.26liter.us/gallery/albums/userpics/10156/Tunerstudios-Timing.jpg AFR Table:http://www.26liter.us/gallery/albums/userpics/10156/Tunerstudios-AFR.jpg Link to comment Share on other sites More sharing options...
Lizzord30 Posted November 26, 2012 Report Share Posted November 26, 2012 Your not reducing timing based on more load(boost)? or is their another setting for that? Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 26, 2012 Author Report Share Posted November 26, 2012 Your not reducing timing based on more load(boost)? or is their another setting for that? Actually hadn't done anything on timing table except for idling up til now. Someone over at the 3si forums saw that too He gave me a great table as reference so I made the below changes... should be safe starting point: http://www.26liter.us/gallery/albums/userpics/10156/Tunerstudios_Ignition.jpg Link to comment Share on other sites More sharing options...
Lizzord30 Posted November 26, 2012 Report Share Posted November 26, 2012 Actually hadn't done anything on timing table except for idling up til now. Someone over at the 3si forums saw that too He gave me a great table as reference so I made the below changes... should be safe starting point: Just dont want you blowing that awesome motor up if you get on it the first time and it does high boost and your at 30 timing! Altho your map may be a bit too conservative but i am not sure what load is for what PSI. Not enof timing can make problems also(like glowing turbos). So if you do run that map I would dyno tune it before driving any amount of time. Of course your going to see big gains with dyno tuning it! As far as money per hp dyno tuning is one of the best things you can do with a ECU like yours. Not to mention all the other benefits to the engine.... Make sure you have someone that is knows how to tune the 6g72. I am not so maybe it likes the low timing under boost. Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 26, 2012 Author Report Share Posted November 26, 2012 (edited) Definitely will be dyno tuning - probably have someone do it professionally if I have the funds available. I'll get it close, but then bring it in for the final dialed in tune. But the guy that gave me that reference timing table is making 883 AWHP, so I feel pretty confident in it as a starting point! LOL In that table, 250kpa is right about 20psi, and 100kpa is atmosphere, and I tried to just even it out in between. So thinking around 12 lbs of boost at 5000 rpms will be somewhere around 8 degrees or so. But I am like you... not by any stretch an expert in 6G72 motors, so really will need to find someone who is. Can't wait to see what it can do though. Getting closer and closer each week. Edited November 26, 2012 by Turbo_Addict Link to comment Share on other sites More sharing options...
BVMotorSports Posted November 28, 2012 Report Share Posted November 28, 2012 Now that is impressive... WOW Link to comment Share on other sites More sharing options...
Funky Phil Posted November 29, 2012 Report Share Posted November 29, 2012 Steve??? Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 29, 2012 Author Report Share Posted November 29, 2012 (edited) Steve's moved to a different area, not sure where, but a ways from where I am now. There's a guy close by but he's a Corvette guy mainly - may just go to T1 Racing out by Joe - we've seen their results. Oh - thanks to Gofastredstar, got the exhaust mounted up last night. I love the view from behind. ;-) http://www.26liter.us/gallery/albums/userpics/10156/backside.jpg Edited November 29, 2012 by Turbo_Addict Link to comment Share on other sites More sharing options...
importwarrior Posted November 29, 2012 Report Share Posted November 29, 2012 bet ya couldnt wait to get that down the road! Link to comment Share on other sites More sharing options...
Funky Phil Posted November 29, 2012 Report Share Posted November 29, 2012 oh sorry, i was replying to Brandon Vincent Motorsports Link to comment Share on other sites More sharing options...
Funky Phil Posted November 29, 2012 Report Share Posted November 29, 2012 you better make 800+ Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 30, 2012 Author Report Share Posted November 30, 2012 you better make 800+ Would love to get in that area... if its a 4 bolt block, I've been told that's certainly not a problem. If it's a 2 bolt block, then about 650 is max. Only way to tell for sure is pull the oil pan - but have some feelers out too, to see if the previous builder would know. Anyways, it's idling nice now, but getting backfiring from the drivers side only. Thought it was timing related, but then was feeling the exhaust and noticed that passenger side was nice and smooth, but drivers side was rougher - felt like it had a miss, and would backfire. Pulled the plugs, first two were blackened as expected, but last one by firewall, looks brand new - like it was just taken out of the box. Tested the wire to the shock tower bolt, and it is definitely getting good spark. So my guess is that the injector is not working on that one Would a dead injector cause occasional backfire? Link to comment Share on other sites More sharing options...
Turbo_Addict Posted November 30, 2012 Author Report Share Posted November 30, 2012 Resolved - bad injector clip on #6... no more backfiring at all, purs on idle. Woohoo! Link to comment Share on other sites More sharing options...
Turbo_Addict Posted December 2, 2012 Author Report Share Posted December 2, 2012 Running better now... exhaust is on and idling nicely. Transmission is working nicely too, goes through the gears great and I can watch the wheels finally spin on their own Just need to address an oil leak on the drivers side turbo return line and dial in the tune under a little load, and should be ready to pull out of the garage and see the light of day for the first time in over two years. hehe Link to comment Share on other sites More sharing options...
StarquestRescue Posted December 2, 2012 Report Share Posted December 2, 2012 I would not trust those injectors with out having them flow tested and the cleaning that go with it. Those motors are not cheep used, or to fix like 54's Link to comment Share on other sites More sharing options...
Turbo_Addict Posted December 4, 2012 Author Report Share Posted December 4, 2012 I would not trust those injectors with out having them flow tested and the cleaning that go with it. Those motors are not cheep used, or to fix like 54's Definitely will be doing that. Link to comment Share on other sites More sharing options...
