starhunter Posted January 17, 2011 Report Share Posted January 17, 2011 Im ordering a walbro but cant find the wix filters needed. I saw them in a few posts a while back but not through search. Any help? Link to comment Share on other sites More sharing options...
Dad Posted January 17, 2011 Report Share Posted January 17, 2011 If you are talking about the wix filter you use at the fuel pump to replace the cone filter, it is #33278 From what i understand it has been discontinued..... You might try a filter with 7/16 inlet and outlets or for whatever size hose you are using. Dad Link to comment Share on other sites More sharing options...
Richie_Rich Posted January 17, 2011 Report Share Posted January 17, 2011 (edited) 33278 is the correct number. I found a couple doing some searching.I have since sold them. Do some internet searching and you may find one. http://www.framcatalog.com/PartDetail.aspx?b=F&pn=G6399 This may help. Using the link above, I found this:http://www.amazon.com/Beck-Arnley-043-0852-Fuel-Filter/dp/B000CAZ5N0 Edited January 17, 2011 by Richie_Rich Link to comment Share on other sites More sharing options...
Caliber308 Posted January 18, 2011 Report Share Posted January 18, 2011 (edited) Napa fuel filter. Part no. FIL3278.$7.29 each. Bill Edited January 18, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
substock Posted January 19, 2011 Report Share Posted January 19, 2011 Napa fuel filter. Part no. FIL3278.$7.29 each. Bill the napa one is made by wix and is also discontinued rockauto says they have the fram, but it comes from the uk Link to comment Share on other sites More sharing options...
Caliber308 Posted January 19, 2011 Report Share Posted January 19, 2011 (edited) the napa one is made by wix and is also discontinued Could be? It doesn't take a fuel expert to figure out how to buy a different fuel filter. Measure your inlet hose I.D., then measure your outlet hose I.D., then measure the distance between the two on the length Sometimes you guys have to do some thinking Instead of us giving you part numbers.Bill Edited January 19, 2011 by Caliber308 Link to comment Share on other sites More sharing options...
89PalermoSHP Posted January 19, 2011 Report Share Posted January 19, 2011 or when you see that something is hard to find, buy the rest of them and horde em! Link to comment Share on other sites More sharing options...
substock Posted January 20, 2011 Report Share Posted January 20, 2011 Sometimes you guys have to do some thinking Instead of us giving you part numbers.Bill and i was only giving current information as i had researched this before.why send someone on a wild goose chase if you are able to help them out so they don't waste their time Link to comment Share on other sites More sharing options...
Shelby Posted January 20, 2011 Report Share Posted January 20, 2011 (edited) all i do is walk in to advance and tell him i need a couple 3/8 in 3/8 out carb clear plastic filters, he always has them metal will also work , plastic is just easier to see if they are dirty Edited January 20, 2011 by Shelby Link to comment Share on other sites More sharing options...
Dodge2004srt4 Posted March 24, 2011 Report Share Posted March 24, 2011 Use NAPA FIL 3299, its around $12.50, metal canister filter 1/2" in and out. Its about .2" longer and .3" less diameter but should work and is available. Ive searched the NAPA FIL 3278 and Wix 33278 and Fram G6399 and all are obsolete. The Fiat guys that were running these part numbers now use the one I listed...FIL 3299. Cant see inside it but just change it when you change your pump, or when you know yours is dirty. You can always look at the in tank filter's condition and then know you need to change both. Chris. Link to comment Share on other sites More sharing options...
89PalermoSHP Posted March 30, 2011 Report Share Posted March 30, 2011 I was able to find one Wix 33278 in stock at rockauto. I ordered it so we'll see if it shows up. Link to comment Share on other sites More sharing options...
Richie_Rich Posted March 30, 2011 Report Share Posted March 30, 2011 The Amazon link I posted above shows 1 in stock there too. Link to comment Share on other sites More sharing options...
