psu_Crash Posted March 15, 2011 Report Share Posted March 15, 2011 Map Daddy is just an upgrade map sensor for megasquirt. The stock MS map sensor only reads up to about 20 psi (2.5 bar), and doesn't allow for barometric correction without running a second one. Link to comment Share on other sites More sharing options...
Blue Posted March 15, 2011 Report Share Posted March 15, 2011 Map Daddy is just an upgrade map sensor for megasquirt. The stock MS map sensor only reads up to about 20 psi (2.5 bar), and doesn't allow for barometric correction without running a second one.Oooooooooh. Cooooooool. *facination ensues* Link to comment Share on other sites More sharing options...
VICE Posted March 16, 2011 Author Report Share Posted March 16, 2011 MAPDADDY4 Link to comment Share on other sites More sharing options...
VICE Posted March 19, 2011 Author Report Share Posted March 19, 2011 (edited) The trunk layout.. It's got some wire left over in case the battery box needs to be permanently mounted elsewhere.That air sealed aluminum battery box vents to the outside with rubber grommets housing all 3 holes in it for the 2 battery cables and the vent line in this case fuel line. Edited March 19, 2011 by VICE Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted March 20, 2011 Report Share Posted March 20, 2011 Add bungie cords to your list of good things to use on a car. Thank God you live in florida and I will never have to see this car in real life. Link to comment Share on other sites More sharing options...
VICE Posted March 20, 2011 Author Report Share Posted March 20, 2011 Add bungie cords to your list of good things to use on a car. Thank God you live in florida and I will never have to see this car in real life. Thank God I probably won't ever see your face either. Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted March 21, 2011 Report Share Posted March 21, 2011 ok listen, if you want some people around here to respect the car and the effort you put into it you might want to put a little more thought into how you do some things thats all I'm saying. It's obvious that you like the car and have a lot of time into it but alot of people will never get past some of the methods and materials used on your car. It's that simple. If you can graduate from using zip ties, bungie cords and JB weld to hold the car together many more people will give you props for the good work thats been done on the car, like the MPI and the supra trans swap. Until then, don't expect much. Link to comment Share on other sites More sharing options...
VICE Posted March 21, 2011 Author Report Share Posted March 21, 2011 (edited) Well she left me stranded today, the Clutch pedal got stuck to the Metal / caved in.. Checked the reservoir and it lost about half the fluid in there... I woulda drove it home with no clutch since I was nearby but the clutch was disengaged/stuck in neutral, the clutch slave cylinder appeared to be seized out all the way when it was removed but some pushing moved the cylinder also the boot was torn on it.. Another slave cylinder crapped out on me years ago and leaked all the fluid out so I thought it was something else that broke.. I have a Red Pressure plate from Clutchnet.com and it's real stiff and I replaced both Clutch Master and Slave Cylinders like a year ago, maybe the stiff clutch messed it up.. Edited March 21, 2011 by VICE Link to comment Share on other sites More sharing options...
Danka22a2in Posted March 26, 2011 Report Share Posted March 26, 2011 Almost dyno time Link to comment Share on other sites More sharing options...
VICE Posted March 27, 2011 Author Report Share Posted March 27, 2011 (edited) Well Folks, this is it for this rebuild. R.I.P. Cracked block in between 2 and 3 passage holes.Boosting 30 psi hard the T04E was taking it and the Tune said 10.4 at WOT and then pop.I strongly believe this cheap M28 Head gave out and didn't handle the pressure.. No substitute for a Marnel head =( and I should have got the block O ringed.. Edited March 27, 2011 by VICE Link to comment Share on other sites More sharing options...
BC_99 Posted March 27, 2011 Report Share Posted March 27, 2011 poor car. BC_99 Link to comment Share on other sites More sharing options...
Scotty Dont Posted March 27, 2011 Report Share Posted March 27, 2011 What a turd. The head did not cause that and o rings wouldn't have stopped it. You probably detonated the s*** out of it or put those arps in wrong. Link to comment Share on other sites More sharing options...
BOHO Posted March 27, 2011 Report Share Posted March 27, 2011 ....wow.... Link to comment Share on other sites More sharing options...
VICE Posted March 27, 2011 Author Report Share Posted March 27, 2011 (edited) MegaSquirt timing could have contributed in killing the motor, the ARP's we're assembled right and I've re torqued them a few times.. Maybe I should have kept checking the retorque, ultimately it was doomed and with it my ideas of making tremendous power out of the G54B engine and DD it.. MANY MANY performance parts will be listed up for sale soon! Billet Adjustable timing gear like $110, billet crank pulley with trigger wheel like $110, Magna MPI, etc... Edited March 27, 2011 by VICE Link to comment Share on other sites More sharing options...
BC_99 Posted March 27, 2011 Report Share Posted March 27, 2011 MegaSquirt timing could have contributed in killing the motor, the ARP's we're assembled right and I've re torqued them a few times.. Maybe I should have kept checking the retorque, ultimately it was doomed and with it my ideas of making tremendous power out of the G54B engine and DD it.. MANY MANY performance parts will be listed up for sale soon! Billet Adjustable timing gear like $110, billet crank pulley with trigger wheel like $110, Magna MPI with 7 tubes of jb weld already installed, bungee cords, some pre-cut zip ties, a couple of rubber bands, and one shoe string, etc... fixed it for ya. BC_99 Link to comment Share on other sites More sharing options...
19cturbo Posted March 27, 2011 Report Share Posted March 27, 2011 my guess is operator error.. prob ran the shizz out of it before dyno tune.. engine prob sucked up enough jb weld to kill it anyway.. Link to comment Share on other sites More sharing options...
BOOSTED88tsi Posted March 27, 2011 Report Share Posted March 27, 2011 what were the numbers at 30psi? Link to comment Share on other sites More sharing options...
Scotty Dont Posted March 28, 2011 Report Share Posted March 28, 2011 Can you just sell the whole car? Link to comment Share on other sites More sharing options...
VICE Posted March 28, 2011 Author Report Share Posted March 28, 2011 Maybe the ARP's needed more retorque'ing .. I thought about just selling the car but I wouldn't take less than 3 grand for the rolling chassis.. Plus it just has too much sentimental value, just gota replace the power train thats all. Already got a buyer for the Wisecos, Pauter Rods and MegaSquirt ... Possibly the good ol JB Magna as well.. =D Selling all G54B part will produce a good $1300 - $1500 that will go towards the next move. Link to comment Share on other sites More sharing options...
VICE Posted March 29, 2011 Author Report Share Posted March 29, 2011 Link to comment Share on other sites More sharing options...
Terminated Posted March 30, 2011 Report Share Posted March 30, 2011 What are you putting in there? Link to comment Share on other sites More sharing options...
The Rabbit1 Posted March 30, 2011 Report Share Posted March 30, 2011 (edited) What are you putting in there?just caught up on the thread, retorque ARP's several times huh? Just do us all a favor and don't ruin any more quests. keep this one and do whatever to it since it's beyond salvation. I tried counting how many times you said ebay, but it gave me a headache. Edited March 30, 2011 by The Rabbit1 Link to comment Share on other sites More sharing options...
VICE Posted March 30, 2011 Author Report Share Posted March 30, 2011 Yes Ebay, God Bless the Internet and forgive the Hate some people have burning deep inside of them.. Well I anticipate MY STARQUEST, yes my car, my ride that I do love, will be up and running better than ever by the end of the summer... Have our work cut out for us and an Extreme yet Epic idea on a Power Plant for MY CAR that will be supa cool. Nicely most of the parts that I am recycling here will boost up about $2500 for the new project and I think it will work just under 3 grand. Link to comment Share on other sites More sharing options...
BOHO Posted March 30, 2011 Report Share Posted March 30, 2011 ............ Link to comment Share on other sites More sharing options...
VICE Posted March 31, 2011 Author Report Share Posted March 31, 2011 (edited) and just like that... It's back in pieces.. Thanks Indiana for buying the brand new Wiseco .40 Pistons and the Pauter Rods for $525! Plus the MegaSquirt, Fidanza Fly Wheel and Stage 3 clutch wow that's more than a grand right there!Man it was easy taking this thing apart! I coulda put it all together.. Next time.. But dankness the G54B parts are selling like Hot Cakes, producing the cash for the next Power Plant, an Epic Drivetrain swap... To be Continued... Edited March 31, 2011 by VICE Link to comment Share on other sites More sharing options...
