OPTIMUSPRIME Posted September 13, 2010 Report Share Posted September 13, 2010 I am running 15W-50 MOBIL 1 Synthetic Courious to see what everyone else is running on the Starions/Conquest Link to comment Share on other sites More sharing options...
MoltoMario Posted September 13, 2010 Report Share Posted September 13, 2010 Kendall 20w/50 non synthetic... Link to comment Share on other sites More sharing options...
Alsandr Posted September 13, 2010 Report Share Posted September 13, 2010 I've been following Ken's numbers: 10w-40 when it's cold and 20w-50 when it's hot. Link to comment Share on other sites More sharing options...
JDean Posted September 13, 2010 Report Share Posted September 13, 2010 mobil 1 0w-40 synthetic Link to comment Share on other sites More sharing options...
ColdScrip Posted September 13, 2010 Report Share Posted September 13, 2010 5w30 Royal Purple Synthetic Link to comment Share on other sites More sharing options...
Minagera Posted September 13, 2010 Report Share Posted September 13, 2010 Good Cheap Fossil oil about 20w50 when hot and 10w40 when cold. Link to comment Share on other sites More sharing options...
strang3majik Posted September 13, 2010 Report Share Posted September 13, 2010 I always ran Rotella 15w-40 in mine. I run Rotella 10w-30 in everything else. Basically, I run Rotella in everything. Supposedly one of the few oils that still has all the additives in it for flat-tappet cams...regardless if my stuff is roller or flat-tappet, I figure the added wear protection never hurts. Link to comment Share on other sites More sharing options...
MoltoMario Posted September 13, 2010 Report Share Posted September 13, 2010 The new Kendall stuff as the additives such as Zinc as well. I dont know for how long but it does. Kendall is damn cheap too. Link to comment Share on other sites More sharing options...
Minagera Posted September 13, 2010 Report Share Posted September 13, 2010 I will have to check out the Kendall stuff when I get back. Link to comment Share on other sites More sharing options...
importwarrior Posted September 13, 2010 Report Share Posted September 13, 2010 castrol 20 ~ 50 Link to comment Share on other sites More sharing options...
dmyers151 Posted September 13, 2010 Report Share Posted September 13, 2010 Mobil-1 10w30. Link to comment Share on other sites More sharing options...
Dad Posted September 13, 2010 Report Share Posted September 13, 2010 Shell 5W30 Link to comment Share on other sites More sharing options...
Starfighterpilot Posted September 13, 2010 Report Share Posted September 13, 2010 I have used Castrol GTX 10W-40 in the Winter and 20W- 50 in the Summer since my Starion was brandy new. In the Spring of 2008 I switched to Castrol GTX Diesel, 15W-40 in Winter and 20W-50 in the Summer. Since that time, I have put 34,000 miles on the Old Girl and I have never had an oil pressure or problem with the engine caused by oil. I made the switch cuz the diesel engine oil conforms to API Classification SJ & SL, has more and better varnish & acid neutralizers, keeps particulte matter suspended in the oil better and has the minimum required amount of ZDDP additive in it, unlike the API Service Classification SM which is what you get when buying engine oil now off the shelf of auto parts stores now. For What It's Worth. KEN Link to comment Share on other sites More sharing options...
taquito Posted September 13, 2010 Report Share Posted September 13, 2010 MAZZOLA Corn Oil. Link to comment Share on other sites More sharing options...
nickireson Posted September 13, 2010 Report Share Posted September 13, 2010 shall we discuss the potential to mix different oil weights? Link to comment Share on other sites More sharing options...
TexasQuest Posted September 13, 2010 Report Share Posted September 13, 2010 Casrol GTX 10w40 Link to comment Share on other sites More sharing options...
Cobalt60 Posted September 13, 2010 Report Share Posted September 13, 2010 Castrol GTX, 20W50 in the summer, and 10W30 in the winter in Connecticut. Link to comment Share on other sites More sharing options...
Caliber308 Posted September 14, 2010 Report Share Posted September 14, 2010 20w/50 Castrol GTX. A lot of the choices depend on your engine set up and weather conditions.Warm weather stock: 10w/30. Built: 20w/50. Cold weather stock: 5w/30. Cold weather built: 10w/30 or 10w/40. I myself chose to use conventional oil. CALIBER 308 Link to comment Share on other sites More sharing options...
Caliber308 Posted September 14, 2010 Report Share Posted September 14, 2010 (edited) I always ran Rotella 15w-40 in mine. I run Rotella 10w-30 in everything else. Basically, I run Rotella in everything. Supposedly one of the few oils that still has all the additives in it for flat-tappet cams...regardless if my stuff is roller or flat-tappet, I figure the added wear protection never hurts. Just so you know. Shell Rotella is about the cheapest and lowest viscosity oil around. But if you like it, who am I to criticize it. How do I know this?? I have ran both different oils in my tractor. Pour a quart of 10w/30wt Rotella and a quart of 10w/30wt Castrol GTX in two separate containers. Look at both of them, stick your fingers in them and rub them together. Now allow both of them separately, to run down off your fingers.Then you tell me which one you would use in your engine. Just letting the members know my experiences. CALIBER 308 Edited September 14, 2010 by Caliber308 Link to comment Share on other sites More sharing options...
OPTIMUSPRIME Posted September 14, 2010 Author Report Share Posted September 14, 2010 MAZZOLA Corn Oil. Just so you know. Shell Rotella is about the cheapest and lowest viscosity oil around. But if you like it, who am I to criticize it. How do I know this?? I have ran both different oils in my tractor. Pour a quart of 10w/30wt Rotella and a quart of 10w/30wt Castrol GTX in two separate containers. Look at both of them, stick your fingers in them and rub them together. Now allow both of them separately, to run down off your fingers.Then you tell me which one you would use in your engine. Just letting the members know my experiences. CALIBER 308At least is better than what TAQUITO is running Link to comment Share on other sites More sharing options...
Caliber308 Posted September 14, 2010 Report Share Posted September 14, 2010 At least is better than what TAQUITO is running Well, at least he's not running Olive Oil....That is only good to run in Ferraris and Lamborghinis CALIBER 308 Link to comment Share on other sites More sharing options...
