Earl Posted January 4, 2011 Report Share Posted January 4, 2011 Have we ever had any aftermarket for roller rockers besides the normal 1.6's? It'd be nice to see if we could get a hold of a good established company to make us some sets of Aluminum 1.6 rollers=P Has anyone though of this? And is there any rocker that is very similar to ours that would just need to be machined to work for our application? What do you guys think? Link to comment Share on other sites More sharing options...
Technology Posted January 4, 2011 Report Share Posted January 4, 2011 It can't be too hard to get something made. The question is where do you put the adjuster if both ends have rollers? Since that would be best. Link to comment Share on other sites More sharing options...
Earl Posted January 4, 2011 Author Report Share Posted January 4, 2011 hmm...idk=) do you think it would be a good idea to try and get some made? Would you use them? I'll do some more research and see what I can come up with=) Link to comment Share on other sites More sharing options...
Earl Posted January 5, 2011 Author Report Share Posted January 5, 2011 would it make more sense to make a set right away trying to use a roller on each side, or to just take a normal 1.6 roller rocker, blueprints it, and have them machine it to those specs and make an aluminum set of those? I think those would be better and can then be improved later by adding the other roller and figuring out the adjuster problem. What you think Tech? Does anyone have any ideas to throw in? Something to improve the base design of the original roller rocker before just making it aluminum? I think these would work awesome=) Link to comment Share on other sites More sharing options...
Komeuppance Posted January 5, 2011 Report Share Posted January 5, 2011 Roller rockers need roller cams. The profile of the slipper cams is different than one of a roller cam. -Robert Link to comment Share on other sites More sharing options...
Earl Posted January 5, 2011 Author Report Share Posted January 5, 2011 I know. lol I have a roller cam. Link to comment Share on other sites More sharing options...
Chad Posted January 5, 2011 Report Share Posted January 5, 2011 would it make more sense to make a set right away trying to use a roller on each side, or to just take a normal 1.6 roller rocker, blueprints it, and have them machine it to those specs and make an aluminum set of those? Something to improve the base design of the original roller rocker before just making it aluminum? I think these would work awesome=) You realize the 1.6 rockers are aluminum already, right? That seems to be your emphasis, the material they are made of, not some new design feature. If you want to get the best rocker, make a roller on the cam surface, and a mechanical adjuster on the valve end that will accept one of the aftermarket swivel food adjusters, like those found on some Porsche motors. That's the thing I don't like about the OEM rollers, which use hydraulic adjusters. Mechanicals can withstand a more aggressive profile, taller lift, and more spring pressure. If you want to get them made, use a 7075 or other 7XXX series aluminum, that stuff is easy to machine, not too expensive or hard to source, and just as strong as mild steel without the added weight. I'd be a buyer for a roller tip, manual adjusted, swivel foot, billet rocker set. Link to comment Share on other sites More sharing options...
Caliber308 Posted January 5, 2011 Report Share Posted January 5, 2011 You realize the 1.6 rockers are aluminum already, right? That seems to be your emphasis, the material they are made of, not some new design feature. If you want to get the best rocker, make a roller on the cam surface, and a mechanical adjuster on the valve end that will accept one of the aftermarket swivel food adjusters, like those found on some Porsche motors. That's the thing I don't like about the OEM rollers, which use hydraulic adjusters. Mechanicals can withstand a more aggressive profile, taller lift, and more spring pressure. If you want to get them made, use a 7075 or other 7XXX series aluminum, that stuff is easy to machine, not too expensive or hard to source, and just as strong as mild steel without the added weight. I'd be a buyer for a roller tip, manual adjusted, swivel foot, billet rocker set. Chad, You must be F.U. with all the misspelled words in your post Bill Link to comment Share on other sites More sharing options...
Chad Posted January 5, 2011 Report Share Posted January 5, 2011 Fixed, pending your approval... Link to comment Share on other sites More sharing options...
Funky Phil Posted January 5, 2011 Report Share Posted January 5, 2011 These what your talkin about chaddy poo??http://b2600turbo.com/elephant.htm I remembered Indiana sayin something about them a while back. But these are on the slippers. Couldnt you just weld up a hyd roller and tap it for these? Seems simple enough. It would seem hard to jack up. Link to comment Share on other sites More sharing options...
Chad Posted January 5, 2011 Report Share Posted January 5, 2011 Yah, that's the one. I'd like to see one with it all engineered to be that way instead of a frankenstein job. I have put some thought into making an insert that fits a hydraulic boss, but has internal threads for a manual adjuster. Making the top of the rocker flat enough for the jam-nut while leaving enough material to keep it strong enough would make it a little more difficult to pull off though. The threaded insert woudl be easy to make... Link to comment Share on other sites More sharing options...
Caliber308 Posted January 6, 2011 Report Share Posted January 6, 2011 Fixed, pending your approval... I was just kidding Bill Link to comment Share on other sites More sharing options...
Chad Posted January 6, 2011 Report Share Posted January 6, 2011 Yah, I know. I forgot to use the sarcasm font. Link to comment Share on other sites More sharing options...
Earl Posted January 7, 2011 Author Report Share Posted January 7, 2011 that sounds like a great idea Chad=) and Andrew (Tech) informed me that they were already=P lol I didn't pay attention enough to notice. But I've heard that mechanical rockers need a lot more attention and can chew a cam up good=/ So let me be sure of what you're proposing. You would like the rockers to be the same as the 1.6 roller rockers, except you'd want the valve side to be machined to accomodate a solid adjuster/ elephant foot? doesn't seem like it would be too hard to do=) Link to comment Share on other sites More sharing options...
Technology Posted January 7, 2011 Report Share Posted January 7, 2011 But if you're doing custom rockers, why not have a roller tip for the valve? I heard that's the new hotness for rocker-actuated valves. I dunno. Link to comment Share on other sites More sharing options...
Chad Posted January 7, 2011 Report Share Posted January 7, 2011 Then how will you adjust the lash? Link to comment Share on other sites More sharing options...
Komeuppance Posted January 7, 2011 Report Share Posted January 7, 2011 Eccentric bolt?? -Robert Link to comment Share on other sites More sharing options...
Technology Posted January 7, 2011 Report Share Posted January 7, 2011 No because that would change the distance from the pivot to the valve. Maybe a rolling tip on the adjustment screw. I just made this:http://www.starquestclub.com/forum/uploads/1293899617/gallery_3386_777_7785.jpg Link to comment Share on other sites More sharing options...
Komeuppance Posted January 7, 2011 Report Share Posted January 7, 2011 I just made this:I can tell... -Robert Link to comment Share on other sites More sharing options...
89PalermoSHP Posted January 7, 2011 Report Share Posted January 7, 2011 what about the cam? Link to comment Share on other sites More sharing options...
Technology Posted January 7, 2011 Report Share Posted January 7, 2011 I can tell... -Robert You're all over the place! As for the cam, it would need to be redesigned to compliment a roller tip. Doing this would need a bunch of testing and development. Link to comment Share on other sites More sharing options...
Chad Posted January 7, 2011 Report Share Posted January 7, 2011 You'll never get a roller adjuster of that design that will withstand the vertical and side loads that it will see. Not in a package that small anyway. It will also be quite heavy. Ity's a good thought, but not practical. The eccentiric bolt is a good idea, but that changes the pivot center as it's adjusted, that would change the rocker ratio in addition to the lash. Another good thought that is not practical and likely heavy. Adjustable center might sound nice, but it woudl be hell keepig all 8 valves at the same lift if that were adjustable. The pivot ball end is pretty simple, light, and proven to hold up under extreme pressures. Link to comment Share on other sites More sharing options...
Earl Posted January 7, 2011 Author Report Share Posted January 7, 2011 That idea looks great Andrew, but I see where Chad is coming from with the longevity problems and added weight. What about a rolling tip? like a ball bearing in the tip of the adjuster? would that work perhaps? Link to comment Share on other sites More sharing options...
89PalermoSHP Posted January 7, 2011 Report Share Posted January 7, 2011 You're all over the place! As for the cam, it would need to be redesigned to compliment a roller tip. Doing this would need a bunch of testing and development. ummm... i thought Shelby was all over that... Shelby???? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted January 7, 2011 Report Share Posted January 7, 2011 i have some mechanical roller rockers to donate to research Link to comment Share on other sites More sharing options...
