Got Any MITSU Tips or Tricks To Share?
20 replies to this topic
#21 Starfighterpilot
Starfighterpilot
    Dirty Old Man
  • 4,368 posts
  • Interests:Keeping my Starion reliably scootin' down the road
Posted 13 September 2006 - 05:36 PM
If you know the Starquest is going to sit for a while, invest in gas stabilizer, HEAT moisture absorber and fuel injector cleaner and put them in just before you do the final adding of gas. They help keeping moisture (rust) down and keeping the gas from turning into a gooey mess.
When you are going to shut down the engine, instead of turning the ignition switch off - goose her past 4k RPM's and have someone pull the  secondary then the primary injector clips off as she is spinning up past 4K.
Then pull the plugs and have someone spin the engine while you spray "copious" amounts of WD-40 (or similar) into each of the plug holes. Re-install the plugs hand tight.
Disconnect the battery and put it on maintenance charge.
For what it's worth.
KEN
88 Starion ESI-R SHP BSE/stock original owner 495K Miles
84 Starion ES RIP in 1987
66 Dodge Charger, Modified Original OEM 383/ 365 HP, 4-speed, Sure Grip, original owner, 113K HARD miles - Being Restored
76 Dodge PU, Modified 440/ 425 HP, 4 speed, Posi Dana 60 DIF, 675K Miles
