- 1122 views
- 1 reply
- 716 views
- 1 reply
- 798 views
- 4 replies
- 1148 views
Wierd coolant temp sensor/gauge behaviour
By ThisPhil,
Im figuring out a european 88 narrow body and stumbled upon a wierd coolant gauge behaviour.
Right below the thermostat housing on the intake manifold are 2 temp sensors:
1 acutal sensor with a T shaped connector
1 temp switch with just a ground connection
Here is what I dont understand:
The coolant temp gauge needle only moves if the temp switch is closed. If the switch is closed, the temp gauge needle instantly jumps as high as it goes. Even if the engine
Odd Rpm hang between shifts
By Logan0296,
Hello everyone,
Here again because I'm experiencing another odball issue that I can't seem to find a solution for. As stated above, my car "often in first gear" will hang the rpms from first to second for a good 3-4 seconds before they drop. If I just rev it up in neutral it works perfectly fine. I've tried adjusting the fuel settings with my maft, but the issue still seems to be persistant rich or not. Has anyone encountered this? could it be a vacuum leak or something fuel related? My isc
Motor Trend Article
By nc_beagle,
A reprint from their archives. Apologies if it's been posted elsewhere.
https://www.motortrend.com/features/mitsubishi-starion-chrysler-conquest/
Ok, I know all about offset and backspacing…. That still doesn’t change the fact that there are barely any “non-custom” wheels available for these cars.
By Mike7447,
Maybe it’s because I’m not looking in the right places, and I know I can custom order a set of wheels to fit the weird/quirky offset/backspacing limitations that the car forces on me, but who has had any luck finding an under 1000.00 set of 17” wheels for this car?
the fronts at 16x7 have 5” of backspacing, and the 8” rears have 4.25” of backspacing.
There are plenty of 17x8 wheels out there that have 4.5” of BS, and if I had to, I could make up for that with a 1/4” spacer, but the fro
