About 87B71Brad
- Birthday 10/13/1986
Wheels
Fishin
Ski'n -
Harrison, Arkansas
72601
1989
Polar White
Dark Red
Restoring
87B71Brad's Achievements
This is what im end up doing. My cartridge had wear on the hotside where the seal rides. Keeping hot and cold sides factory. If I wanted to change downpipes and all I'd just go with a different already built turbo. This way I can rebuild with a mhi kit if needed. And everything looks stock. And using an EVOlll wheel will spool a bit faster than an 18g and will make almost same power supposedly.
15-40 Rotella here also! But I also run it in everything...lawnmowers...etc. good oil..plus its always on sale
Yeah same here. I daily my quest. In the last yr I've built 3 12a'a due to running them 14psi + on the daily and building from used parts ....lol I've got where it takes a hair over an hour to yank and rebuild, install....prime it and fire it up..haha Only think you really need is some really big internal snap ring pliers. I bought a ratcheting set...small set is also nice.
Thanks for the pictures. You say porting the wastegate bypass? I'll be sure to mention this to Chris also. I've never thought about that. Suppose that makes sense. I know it sounds silly but I wanted to keep everything as OEM looking as I can, so I was hoping using the td06 in this housing wasn't to far fetched. Where it mates the manifold is all ported out already. The factory lip and some more actually.
http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMG_5649_zpsqcd9eoff.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMAG1619_zpsou9phbpf.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMG_43348343639874_zps7mjwc5lc.jpeg
http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMG_5633_zpsxsmuddgz.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMG_5635_zpsxmah1n1v.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMG_5643_zpsgvnmra6s.jpg
Thank you. And no sir, they are both 25mm. With quarters rolled and -.06 camber I'm pretty close, but no rub.
I gotcha! I've been needing a good reason to buy a wideband! I've done got a gm maf. Guess I will pick up a translator while I'm at it. What wideband should I buy? And which ones to stay away from? I've heard that some are hard to calibrate and such. Should I use the original o2 bung or weld one in further downstream? Thanks!
http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMAG1563_zpsgiun8cmk.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMAG1571_zpspzcyxygg.jpg http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMAG1572_zpsbxdcmlav.jpg
Modify strut tower for Mookeeh rear camber plates??
87B71Brad replied to DMNDSTAR87's topic in Advanced Virtual Mechanic
http://i1325.photobucket.com/albums/u626/gtxbrad/Mobile%20Uploads/IMAG1619_zpsou9phbpf.jpg Im using the non pillow type tho. So your cut could be smaller to just allow nut to move instead of requiring washer like mine. -
Heck ya guys. Sounds like I'm gonna pull the trigger on this! Thanks a bunch! I'll post pics when he sends some.
That's how mine looked. I took my large carbide burr bit and notched that sucker out. Had to enlarge it big enough to let washers rest on the plate. Im tucking 225/50 now..lol If you want a pic of mine lmk -
I'm getting a turbo built and could use some advice. Talking to Chris Robbins from Turbos R Us. I got a quote to do a EVO 3 16g and leave my hotside stock. $450. I also priced him to machine my hotside out to accept a td06h4 (11 blade) and do the EVO 3 and a td06turbine. He hit me at $675. Has anyone ran the td06 in a machined factory hotside? Will it even work properly? Or should I just stay td05? Any help would be greatly appreciated!
Bought some rear camber plates from Joe. Little mix up with shipping but everything was just as promised. I appreciate doing business with ya. Thanks
