- 10 replies
- 3667 views
- 1 reply
- 1395 views
- 607 views
Cylinder Wall Pitting/Damage
By GoldStar,
I've already talked to Dad about this a bit, posting here for a wider audience and to possibly help anyone else who may run into this.
In my quest to determine why my intercooler keeps collecting oil, I decided this weekend to do a cylinder leak down test. Prior to doing this, however, I decided to get my borescope and take some pictures of the cylinders while I had the spark plugs out. Lo and behold, it appears I have found the cause.
Cylinder 1:
Cylinder 2:
Cylinder 3:
Installing a mechanical boost gauge in the stock location.
By Caliber308,
First, you need to know how to remove the meter hood and gauge assembly. If you do not have a FSM, you will need to go here: www.starquestgarage.com download the fsm for the 1988. Then go to section 8 pages 166 and 168. O.K. Lets get started, when you remove the meter hood and gauge assembly be careful of the printed circuit plastic with the copper ribbons on the back of the meter case. You will need a dremel tool to widen the plastic to fit the brass connector. I drilled a small hole in the bac
Fuel Sending Unit for 88 needed
By norats,
Anybody have a fuel guage sending unit for an 88?
Thanks,
-norats
